413-K14-FN2-45A
413-K14-FN2-45A
    E-T-A
    CIRC BRKR THRM
413-K14-FN2-45A 数据手册
High Performance Thermal Circuit Breaker 413-... Description Single pole high performance thermal circuit breaker with tease-free, trip-free, snap action mechanism and push/pull on/off manual actuation (M-type TO CBE to EN 60934). An indicator band on the push button shows clearly the tripped/off position. Threadneck panel mounted and available in tracked vehicle, aircraft and general purpose versions. Typical applications Extra low voltage wiring systems on all types of vehicles for land, sea and air; defence equipment; battery powered machines. 413-... Technical data Ordering information Type No. 413 threadneck panel mounting Terminal design K14 screw terminals M6 (to aircraft specs.) K34 reinforced screw terminals M6 (to vehicle specs.) K54 as K34, but housing sealed Version FN2 vehicle application, nickel-plated LN2 aircraft application, black finish N2 general application, nickel-plated Current ratings 30...55 A (-FN2) 30...90 A (-LN2/N2) 413 - K14 - LN2 - 40 A ordering example Voltage rating AC 115 V (400 Hz); DC 28 V Current rating range 30...55 A (-FN2) 30...90 A (-LN2/-N2), Typical life 2,000 operations at 1 x IN Ambient temperature -55...+75 °C (-67...+167 °F) Insulation co-ordination (IEC 60664 and 60664A) Rated impulse Pollution withstand voltage degree 1.5 kV 3 Dielectric strength (IEC 60664 and 60664A) operating area Test voltage AC 1,500 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn AC 115 V (400 Hz): 1,000 A DC 28 V: 6,000 A Packaging quantity: 75 pcs. Standard current ratings and typical voltage drop values Current rating (A) Voltage drop (mV) -LN/N -FN Current rating (A) Voltage drop (mV) -LN/N -FN 30 ≤ 250 ≤ 250 55 - ≤ 200 35 ≤ 250 ≤ 250 60 ≤ 200 - 40 ≤ 200 ≤ 200 70 ≤ 200 - 45 ≤ 200 ≤ 200 80 ≤ 200 - 50 ≤ 200 ≤ 200 90 ≤ 200 - Interrupting capacity (UL 1077) DC 28 V: 6,000 A Degree of protection (IEC 60529/DIN 40050) operating area IP 40 terminal area IP 00 Vibration 10 g (56-500 Hz) ±0.76 mm (10-55 Hz) to VG 95210, sheet 19/ MIL-STD-202, meth. 204/ IEC 60068-2-6, test Fc Shock 50 g (11 ms) to VG 95210, sheet 28/ MIL-STD-202, meth. 213/ IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to VG 95210, sheet 2/ MIL-STD-202, meth. 101/ IEC 60068-2-11, Test Ka Humidity 240 hours at 95 % RH to VG 95210, sheet 7/ MIL-STD-202, meth. 106/ IEC 60068-2-3, test Ca Mass approx. 65 g Approvals Test authority Voltage ratings Current ratings UL DC 28 V 30...80 A LRoS, BV DC 28 V 30...70 A QPL Sweden DC 28 V 30...50 A Issue D ☎ 4 USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 221 High Performance Thermal Circuit Breaker 413-... Dimensions Internal connection diagram 413-K14-... line 1 black white 6.5 .256 lock washer 1.5 .059 4 .157 ON 12.2 .480 6 .236 2 max. 63 max. 2.48 49 1.93 55 2.17 max. 64 max. 2.52 OFF ø10.6 .417 tightening torque max. 4 Nm M12x1 Typical time/current characteristics 413-...-FN2 30...55 A 3.5 x. 38 ma x.1 ma 23 .906 screw ISO1580-M6x8 (-N/-FN) M6x10 (-LN) lock washer DIN 137-B6 tightening torque max. 2.5 Nm 18.5 .728 50 2.7 .106 ø12.5 +0.2 SW14 .551 32 1.26 location pin 413-K34/K54-... -55°C -67°F 100 10 1 thickness 1.5 - 3 mm .059 - .118 in. 0.01 tightening torque max. 4 Nm M12x1 black 0.001 1 2 4 6 810 20 40 6080100 … times rated current white 1.5 .059 4 .157 lock washer 413-..LN2/N2 30...90 A 10000 +75°C +167°F +23 °C +73.4 °F 3.5 x. 38 ma x.1 ma 35° 23 .906 Trip time in seconds 49 1.93 55 2.17 max. 64 max. 2.52 1000 max. 63 max. 2.48 35° +23 °C +73.4 °F 0.1 6.5 .256 ON OFF ø10.6 .417 12.2 .480 6 .236 9.5 ±0.2 .374 ±.008 min. ø3.2 min .126 9.5 .374 .492 +.008 current rating in A +75°C +167°F 1000 mounting holes 413-K14-LN2 4 10000 Trip time in seconds 35° 35° -55°C -67°F 100 10 1 0.1 screw ISO1580-M6x8 (-N/-FN) M6x10 (-LN) lock washer DIN 137-B6 tightening torque max. 2.5 Nm 0.01 mounting holes current rating in A 1 2 4 6 810 20 40 6080100 … times rated current .492 +.008 ø12.5 +0.2 2.7 .106 50 location pin SW14 .551 32 1.26 0.001 18.5 .728 9.5 .374 9.5 ±0.2 .374 ±.008 413-K34/K54-FN2/-N2 thickness 1.5 - 3 mm .059 - .118 in. min. ø3.2 min .126 mm This is a metric design and millimeter dimensions take precedence ( inch ) 222 ☎ USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 Issue D High Performance Thermal Circuit Breaker 413-... Accessories Splash cover/hex nut assembly with O ring (IP 66) X 200 801 08 – nickel plated nut, transparent cover X 200 801 03 – matt black finish nut, black cover Identification collar Y 307 004 01 black Y 307 004 02 white Y 307 004 03 red Y 307 004 04 green Y 307 004 05 blue 1.1 .043 Accessories (approved to VG 95345, part 23) ø13.97 .550 ø6.85 .270 45 6.4 .252 ° 4 .157 M12x1 Splash cover black/hex nut assembly with O ring (IP 54) X 200 802 01 – nickel plated nut X 200 802 02 – matt black finish nut ° 45 ø8.7 .343 ø12.35 .486 0.65 .026 Lock out ring Y 307 005 01 red 4 ø14.6 .575 7.7 .303 1.1 .043 Actuator extension (black) X 200 803 01 ø8.6 .339 ø10.9 .429 0.8 .031 All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. Issue D ☎ USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 223
413-K14-FN2-45A 价格&库存
很抱歉,暂时无法提供与“413-K14-FN2-45A”相匹配的价格&库存,您可以联系我们找货
