10-2H24.2052
10-2H24.2052
    EAO
    可配置开关灯 LED 红色 130V
10-2H24.2052 数据手册
EAO – Your Expert Partner for Human Machine Interfaces Switches Unlimited Contact: sales@switchesunlimited.com Phone: 800-221-0487 * Fax: 718-672-6370 www.switchesunlimited.com EAO Product Information Series 10 LED 10 Contents Description ...................................................................................................... 3 Illumination...................................................................................................... 4 Accessories..................................................................................................... 8 Technical Data................................................................................................. 9 Drawings........................................................................................................ 10 Index............................................................................................................... 11 2 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Description Product Information General notes The LEDs have decisive advantages: 1. Optimum of illumination 2. Low power consumption 3. Used on DC voltage and AC voltage 4. Low heat generation 5. Extrem long lifetime 6. Shock and vibration proof Design The LEDs are built with an integrated resitor and they are available in three versions: Without rectifier Only for use on DC voltage. Please be aware of the polarity! With half-wave rectifier These LEDs are built with a protection diode in series with the resitor and the LED. They can be used without any problems on DC voltage and AC voltage. The typical light reduction on AC voltage against DC voltage operation is round 25%. With bridge rectifier Can be used without any problems on a DC voltage and AC voltage with the same light output. Bipolarity on DC voltage! Illumination Single-Chip LEDs in red, blue, green, yellow and white gives superb illumination and can be supplied in 6 VDC, 12, 24, 28, 48 VAC/DC, 130 VDC, 130 VAC and 230 VAC. Due to production tolerances, colour temperature variations may be detected within individual consignments. Lamp remover for T1 3/4 MG LED Typ-Nr. 61-9740.0 (series 22, 31, 41, 51, 61, 71) Typ-Nr. 300-0002-00 (series Swisstac) for T5.5 LED Typ-Nr. 02-906 (series 01, 14) Typ-Nr. 300-0002-00 (series Swisstac) for T6.8 LED Typ-Nr. 03-996 (series 02, 03) for T3 1/4 BA9s LED Typ-Nr. 700.006.0 (series 04) Typ-Nr. 44-935 (series 44) Used in series T1 3/4 MG: 22, 31, 41, 51, 61, 71, Swisstac T5.5: 01, 14, Swisstac T6.8: 02, 03 T3 1/4 BA9s: 04, 44 We reserve the right to modify technical data All dimensions in mm 3 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Illumination Single-LED T1 3/4 (6mm) MG green red white diffuse yellow Lumi. Intensity 650 mcd 650 mcd 650 mcd 400 mcd 680 mcd 1050 mcd 1050 mcd 1050 mcd 600 mcd 1050 mcd 330 mcd 330 mcd 330 mcd 200 mcd 350 mcd 700 mcd 700 mcd 700 mcd 400 mcd 750 mcd 280 mcd 280 mcd 280 mcd 180 mcd 300 mcd Dom. Wavelength 470 nm 470 nm 470 nm 470 nm 470 nm 525 nm 525 nm 525 nm 525 nm 525 nm 630 nm 630 nm 630 nm 630 nm 630 nm x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 nm x=0.31 / y=0.32 x=0.31 / y=0.32 587 nm 587 nm 587 nm 587 nm 587 nm HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR Typ-Nr. 10-2J09.1066 10-2J12.1066 10-2J13.1066 10-2J19.1046 10-2J06.3146 10-2J09.1065 10-2J12.1065 10-2J13.1065 10-2J19.1045 10-2J06.3145 10-2J09.1062 10-2J12.1062 10-2J13.1062 10-2J19.1042 10-2J06.3142 10-2J09.1069 10-2J12.1069 10-2J13.1069 10-2J19.1049 10-2J06.3149 10-2J09.1064 10-2J12.1064 10-2J13.1064 10-2J19.1044 10-2J06.3144 Component layout Operating voltage/-current 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 12 VAC/DC, 4/7 mA 24 VAC/DC, 4/7 mA 28 VAC/DC, 4/7 mA 48 VAC/DC, 2/4 mA 6 VDC, 7 mA 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 1 1 1 1 1 Technical drawing Single-LED T1 3/4 (6mm) MG Light colour blue Version Continuation see next page e 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 Electrical and optical data are measured at 25°C. Luminous intensity data of the LEDs on direct voltage. The specified versions are built with a protection diode in series and the LED. A suitable lamp remover Part No. 61-9740.0 (Series Swisstac Part No. 300-0002-00). Version: HR = With half-wave rectifier, WR = Without rectifier Component layout from page 10, Technical drawing from page 10 4 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Illumination Single-LED T5.5 green red white diffuse yellow Operating voltage/-current 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 12 VAC/DC, 4/7 mA 24 VAC/DC, 4/7 mA 28 VAC/DC, 4/7 mA 48 VAC/DC, 2/4 mA 6 VDC, 7 mA 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA 12 VAC/DC, 7/14 mA 24 VAC/DC, 7/14 mA 28 VAC/DC, 7/14 mA 48 VAC/DC, 4/8 mA 6 VDC, 15 mA Lumi. Intensity 650 mcd 650 mcd 650 mcd 400 mcd 680 mcd 1050 mcd 1050 mcd 1050 mcd 600 mcd 1050 mcd 330 mcd 330 mcd 330 mcd 200 mcd 350 mcd 700 mcd 700 mcd 700 mcd 400 mcd 750 mcd 280 mcd 280 mcd 280 mcd 180 mcd 300 mcd Dom. Wavelength 470 nm 470 mm 470 nm 470 nm 470 nm 525 mm 525 mm 525 nm 525 nm 525 nm 630 nm 630 nm 630 nm 630 nm 630 nm x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 587 nm 587 nm 587 nm 587 nm 587 nm HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR Component layout Light colour blue Typ-Nr. 10-2109.1066 10-2112.1066 10-2113.1066 10-2119.1046 10-2106.3146 10-2109.1065 10-2112.1065 10-2113.1065 10-2119.1045 10-2106.3145 10-2109.1062 10-2112.1062 10-2113.1062 10-2119.1042 10-2106.3142 10-2109.1069 10-2112.1069 10-2113.1069 10-2119.1049 10-2106.3149 10-2109.1064 10-2112.1064 10-2113.1064 10-2119.1044 10-2106.3144 1 1 1 1 1 Electrical and optical data are measured at 25°C. Luminous intensity data of the LEDs on direct voltage. The specified versions are built with a protection diode in series and the LED. A suitable lamp remover Part No. 02-906 (Series Swisstac Part No. 300-0002-00). Version: HR = With half-wave rectifier, WR = Without rectifier Component layout from page 10, Technical drawing from page 10 5 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 Technical drawing Single-LED T5.5 Version Continuation see next page e 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 10 Illumination Single-LED T6.8 green red white diffuse yellow Operating voltage/-current 12 VAC/DC, 9/17 mA 24 VAC/DC, 9/17 mA 28 VAC/DC, 9/17 mA 48 VAC/DC, 4/8 mA 6 VDC, 17 mA 12 VAC/DC, 4/7 mA 24 VAC/DC, 4/7 mA 28 VAC/DC, 4/7 mA 48 VAC/DC, 2/4 mA 6 VDC, 7 mA 12 VAC/DC, 9/17 mA 24 VAC/DC, 9/17 mA 28 VAC/DC, 9/17 mA 48 VAC/DC, 4/8 mA 6 VDC, 17 mA 12 VAC/DC, 9/17 mA 24 VAC/DC, 9/17 mA 28 VAC/DC, 9/17 mA 48 VAC/DC, 4/8 mA 6 VDC, 17 mA 12 VAC/DC, 9/17 mA 24 VAC/DC, 9/17 mA 28 VAC/DC, 9/17 mA 48 VAC/DC, 4/8 mA 6 VDC, 17 mA Lumi. Intensity 780 mcd 780 mcd 780 mcd 400 mcd 780 mcd 1050 mcd 1050 mcd 1050 mcd 600 mcd 1050 mcd 400 mcd 400 mcd 400 mcd 200 mcd 400 mcd 850 mcd 850 mcd 850 mcd 400 mcd 850 mcd 340 mcd 340 mcd 340 mcd 180 mcd 340 mcd Dom. Wavelength 470 nm 470 nm 470 nm 470 nm 470 nm 525 nm 525 nm 525 nm 525 nm 525 nm 630 nm 630 nm 630 nm 630 nm 630 nm x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 340 nm 340 nm 340 nm 340 nm 340 nm HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR HR HR HR HR WR Typ-Nr. 10-2K09.1076 10-2K12.1076 10-2K13.1076 10-2K19.1056 10-2K06.3156 10-2K09.1075 10-2K12.1075 10-2K13.1075 10-2K19.1055 10-2K06.3155 10-2K09.1072 10-2K12.1072 10-2K13.1072 10-2K19.1052 10-2K06.3152 10-2K09.1079 10-2K12.1079 10-2K13.1079 10-2K19.1059 10-2K06.3159 10-2K09.1074 10-2K12.1074 10-2K13.1074 10-2K19.1054 10-2K06.3154 Component layout Light colour blue 1 1 1 1 1 Technical drawing Single-LED T6.8 Version Continuation see next page e 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 Electrical and optical data are measured at 25°C. Luminous intensity data of the LEDs on direct voltage. The specified versions are built with a protection diode in series and the LED. A suitable lamp remover Part No. 03-996. Version: HR = With half-wave rectifier, WR = Without rectifier Component layout from page 10, Technical drawing from page 10 6 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Illumination Single-LED T3 1/4 (10x25mm) BA9s green red white diffuse yellow Lumi. Intensity 720 mcd 230 mcd 200 mcd 200 mcd 680 mcd 590 mcd 400 mcd 780 mcd 1050 mcd 450 mcd 300 mcd 300 mcd 1050 mcd 1050 mcd 600 mcd 1050 mcd 390 mcd 180 mcd 120 mcd 120 mcd 350 mcd 300 mcd 200 mcd 400 mcd 800 mcd 250 mcd 150 mcd 150 mcd 750 mcd 650 mcd 400 mcd 850 mcd 340 mcd 160 mcd 110 mcd 110 mcd 300 mcd 270 mcd 180 mcd 340 mcd Dom. Wavelength 470 nm 470 nm 470 nm 470 nm 470 nm 470 nm 470 nm 470 nm 525 nm 525 nm 525 nm 525 nm 525 nm 525 nm 525 nm 525 nm 630 nm 630 nm 630 nm 630 nm 630 nm 630 nm 630 nm 630 nm x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 x=0.31 / y=0.32 587 nm 587 nm 587 nm 587 nm 587 nm 587 nm 587 nm 587 nm BR BR BR BR BR BR BR WR BR BR BR BR BR BR BR WR BR BR BR BR BR BR BR WR BR BR BR BR BR BR BR WR BR BR BR BR BR BR BR WR Comp. layout Operating voltage/-current 12 VAC/DC, 16 mA 130 VAC, 5 mA 130 VDC, 3 mA 230 VAC, 3 mA 24 VAC/DC, 15 mA 28 VAC/DC, 13 mA 48 VAC/DC, 8 mA 6 VDC, 17 mA 12 VAC/DC, 7 mA 130 VAC, 3 mA 130 VDC, 2 mA 230 VAC, 2 mA 24 VAC/DC, 7 mA 28 VAC/DC, 7 mA 48 VAC/DC, 4 mA 6 VDC, 7 mA 12 VAC/DC, 16 mA 130 VAC, 5 mA 130 VDC, 3 mA 230 VAC, 3 mA 24 VAC/DC, 15 mA 28 VAC/DC, 13 mA 48 VAC/DC, 8 mA 6 VDC, 17 mA 12 VAC/DC, 16 mA 130 VAC, 5 mA 130 VDC, 3 mA 230 VAC, 3 mA 24 VAC/DC, 15 mA 28 VAC/DC, 13 mA 48 VAC/DC, 8 mA 6 VDC, 17 mA 12 VAC/DC, 16 mA 130 VAC, 5 mA 130 VDC, 3 mA 230 VAC, 3 mA 24 VAC/DC, 15 mA 28 VAC/DC, 13 mA 48 VAC/DC, 8 mA 6 VDC, 17 mA Typ-Nr. 10-2509.1146 10-2H24.2056 10-2524.3046 10-2H25.2046 10-2512.1146 10-2513.1146 10-2519.1056 10-2506.1086 10-2509.1145 10-2H24.2055 10-2524.3045 10-2H25.2045 10-2512.1145 10-2513.1145 10-2519.1055 10-2506.1085 10-2509.1142 10-2H24.2052 10-2524.3042 10-2H25.2042 10-2512.1142 10-2513.1142 10-2519.1052 10-2506.1082 10-2509.1149 10-2H24.2059 10-2524.3049 10-2H25.2049 10-2512.1149 10-2513.1149 10-2519.1059 10-2506.1089 10-2509.1144 10-2H24.2054 10-2524.3044 10-2H25.2044 10-2512.1144 10-2513.1144 10-2519.1054 10-2506.1084 1 1 1 1 1 1 1 1 Techn. drawing Single-LED T3 1/4 (10x25mm) BA9s Light colour blue Version Continuation see next page e 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 0.002 Electrical and optical data are measured at 25°C. Luminous intensity data of the LEDs on direct voltage. The specified 6 VDC, 130 VAC, 130 DC und 230 VAC versions are built with a protection diode. The specified 12, 24, 28, 48 VAC/DC versions are built with a bridge rectifier. The specified 130 VAC types are developed to run on a supply voltage of 130 VAC only. An operation at a higher supply voltage using commercial lampholders with integrated resistors, is not approved. A suitable lamp remover Part No. 700.006.0 (Series 44 Part No. 44-935). Version: BR = With bridge rectifier, WR = Without rectifier Component layout from page 10, Technical drawing from page 10 7 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Accessories Illumination Lamp remover for T1 3/4 MG LED Continuation see next page Lamp remover for T1 3/4 MG LED For series 22, 31, 41, 51, 61, 71 Swisstac e Typ-Nr. 61-9740.0 300-0002-00 0.003 0.003 Typ-Nr. 02-906 0.002 CAUTION A switching process might be released when replacing the LED! Lamp remover for T5.5 LED Continuation see next page Lamp remover for T5.5 LED For series 01, 14 e CAUTION A switching process might be released when replacing the LED! Lamp remover for T6.8 LED Continuation see next page Lamp remover for T6.8 LED For series 02, 03 e Typ-Nr. 03-996 0.027 Typ-Nr. 700.006.0 44-935 0.003 0.037 CAUTION A switching process might be released when replacing the LED! Lamp remover for T3 1/4 BA9s LED Continuation see next page For series 04 44 Lamp remover for T3 1/4 BA9s LED e CAUTION A switching process might be released when replacing the LED! 8 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Technical Data Technical Data Electrical characteristics Voltage tolerance +10 % Mechanical characteristics Standards Lamp base 0 Base T1 3/4 MG T5.5 T6.8 BA9s Standard DIN EN 60061-1: S5,7s DIN 49601 DIN 49601 DIN EN 60061-1: BA9s Environmental conditions Storage temperature -25 °C ... +80 °C Service temperature -20 °C ... +60 °C 9 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 10 Drawings Component layout 1 Single-LED T1 3/4 (6mm) MG page 4 | Single-LED T5.5 page 5 | Single-LED T6.8 page 6 | Single-LED T3 1/4 (10x25mm) BA9s page 7 Typical luminous spectrum for white LED Intensität / Intensity [%] 100 80 TA = 25 °C IF = 20 mA 60 40 20 0 400 500 600 700 800 Wellenlänge / Wavelength [nm] Colour coordinates IF = 20 mA; TA = 25 °C x = 0.31 ±0.06 y = 0.32 ±0.08 Technical drawing 1 Single-LED T1 3/4 (6mm) MG page 4 Ø6.1 max. 16 max. 2 Single-LED T5.5 page 5 Ø6 max. 30 max. 3 Single-LED T6.8 page 6 Ø7.1 max. 45 max. 4 Single-LED T3 1/4 (10x25mm) BA9s page 7 Ø10 max. 25 max. 10 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370 Index from Typ-Nr. Typ-Nr. Page 02-906 .......................................... 8 03-996 .......................................... 8 10-2106.3142 ............................... 5 10-2106.3144 ............................... 5 10-2106.3145 ............................... 5 10-2106.3146 ............................... 5 10-2106.3149 ............................... 5 10-2109.1062 ............................... 5 10-2109.1064 ............................... 5 10-2109.1065 ............................... 5 10-2109.1066 ............................... 5 10-2109.1069 ............................... 5 10-2112.1062 ............................... 5 10-2112.1064 ............................... 5 10-2112.1065 ............................... 5 10-2112.1066 ............................... 5 10-2112.1069 ............................... 5 10-2113.1062 ............................... 5 10-2113.1064 ............................... 5 10-2113.1065 ............................... 5 10-2113.1066 ............................... 5 10-2113.1069 ............................... 5 10-2119.1042 ............................... 5 10-2119.1044 ............................... 5 10-2119.1045 ............................... 5 10-2119.1046 ............................... 5 10-2119.1049 ............................... 5 10-2506.1082 ............................... 7 10-2506.1084 ............................... 7 10-2506.1085 ............................... 7 10-2506.1086 ............................... 7 10-2506.1089 ............................... 7 10-2509.1142 ............................... 7 10-2509.1144 ............................... 7 10-2509.1145 ............................... 7 10-2509.1146 ............................... 7 10-2509.1149 ............................... 7 10-2512.1142 ............................... 7 10-2512.1144 ............................... 7 10-2512.1145 ............................... 7 10-2512.1146 ............................... 7 10-2512.1149 ............................... 7 10-2513.1142 ............................... 7 10-2513.1144 ............................... 7 10-2513.1145 ............................... 7 10-2513.1146 ............................... 7 10-2513.1149 ............................... 7 10-2519.1052 ............................... 7 10-2519.1054 ............................... 7 10-2519.1055 ............................... 7 10-2519.1056 ............................... 7 10-2519.1059 ............................... 7 10-2524.3042 ............................... 7 10-2524.3044 ............................... 7 10-2524.3045 ............................... 7 10-2524.3046 ............................... 7 10-2524.3049 ............................... 7 10-2H24.2052 .............................. 7 10-2H24.2054 .............................. 7 10-2H24.2055 .............................. 7 10-2H24.2056 .............................. 7 10-2H24.2059 .............................. 7 10-2H25.2042 .............................. 7 Typ-Nr. Page Typ-Nr. Page 10-2H25.2044 .............................. 7 10-2H25.2045 .............................. 7 10-2H25.2046 .............................. 7 10-2H25.2049 .............................. 7 10-2J06.3142 ............................... 4 10-2J06.3144 ............................... 4 10-2J06.3145 ............................... 4 10-2J06.3146 ............................... 4 10-2J06.3149 ............................... 4 10-2J09.1062 ............................... 4 10-2J09.1064 ............................... 4 10-2J09.1065 ............................... 4 10-2J09.1066 ............................... 4 10-2J09.1069 ............................... 4 10-2J12.1062 ............................... 4 10-2J12.1064 ............................... 4 10-2J12.1065 ............................... 4 10-2J12.1066 ............................... 4 10-2J12.1069 ............................... 4 10-2J13.1062 ............................... 4 10-2J13.1064 ............................... 4 10-2J13.1065 ............................... 4 10-2J13.1066 ............................... 4 10-2J13.1069 ............................... 4 10-2J19.1042 ............................... 4 10-2J19.1044 ............................... 4 10-2J19.1045 ............................... 4 10-2J19.1046 ............................... 4 10-2J19.1049 ............................... 4 10-2K06.3152 ............................... 6 10-2K06.3154 ............................... 6 10-2K06.3155 ............................... 6 10-2K06.3156 ............................... 6 10-2K06.3159 ............................... 6 10-2K09.1072 ............................... 6 10-2K09.1074 ............................... 6 10-2K09.1075 ............................... 6 10-2K09.1076 ............................... 6 10-2K09.1079 ............................... 6 10-2K12.1072 ............................... 6 10-2K12.1074 ............................... 6 10-2K12.1075 ............................... 6 10-2K12.1076 ............................... 6 10-2K12.1079 ............................... 6 10-2K13.1072 ............................... 6 10-2K13.1074 ............................... 6 10-2K13.1075 ............................... 6 10-2K13.1076 ............................... 6 10-2K13.1079 ............................... 6 10-2K19.1052 ............................... 6 10-2K19.1054 ............................... 6 10-2K19.1055 ............................... 6 10-2K19.1056 ............................... 6 10-2K19.1059 ............................... 6 300-0002-00 ................................. 8 44-935 .......................................... 8 61-9740.0 ..................................... 8 700.006.0 ..................................... 8 11 03.2010 For Info: sales@switchesunlimited.com www.switchesunlimited.com Phone: 800-221-0487 Fax: 718-672-6370
10-2H24.2052 价格&库存
很抱歉,暂时无法提供与“10-2H24.2052”相匹配的价格&库存,您可以联系我们找货
10-2H24.2052
  • 1+74.149861+9.60500
  • 25+53.9985525+6.99470
  • 50+51.2070250+6.63310
  • 100+48.93891100+6.33930
库存:5
