© EAO - Automotive GmbH & Co. KG
Streng vertraulich. Alle Rechte ausdrücklich vorbehalten. Die Vervielfältigung und insbesondere die Verarbeitung in elektronischen Systemen ist ohne schriftliche Genehmigung der EAO - Automotive GmbH & Co. KG nicht gestattet.
Strictly confidential. All rights strictly reserved. Reproduction and processing of data in electronical systems or in any form whatever is not permitted without written authority of EAO - Automotive GmbH & Co. KG.
1
A
2
3
4
5
Design In Kits for S09 Rugged Keypads
exemplary representation of individual variants
6
7
revision zone
date
01
10.01.2022 initial edition
8
description
RP - no.
1026
B
A
B
sheet 1: cover
sheet 2: scope of delivery CAN keypad
sheet 3: scope of delivery CAN RCC
sheet 4: scope of delivery hardwired keypad 12 V
sheet 5: scope of delivery hardwired keypad 24 V
sheet 6: mounting specifications - assembly CAN keypad
sheet 7: mounting specifications - assembly CAN RCC
sheet 8: mounting specifications - assembly hardwired
sheet 9: circuit diagrams - electrical connection
C
D
E
C
D
E
description
drawing no.
S09 outdoor Design-In Kits
F
EAO Automotive GmbH & Co. KG
Richard-Wagner-Straße 3
08209 Auerbach
GERMANY
1
2
3
4
5
scale
format
weight
1:2
A3
1st angle projection
6
revision
2002940001
document type
status
product information
all dimensions are in
millimeters
7
01
only for information
date
drawn 10.01.2022
approved 17.01.2022
name
EBJ
SCR
8
sheet no.
1/9
F
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
revision zone
date
01
24
description
RP - no.
1026
A
A
B
B
C
C
D
D
CANopen safety Design- in kit - 09-0A32.1111
J1939 Design- in kit - 09-0A12.1111
CANopen Design- in kit - 09-0A22.1111
E
E
1
1
2
6
1
1
3
12
11
1
F
2
6
1
1
3
12
11
1
4
4
5
4
G
3
12
11
1
4
4
4
4
5
4
5
4
8
1
8
1
2
6
F
G
8
1
6
1
6
1
6
1
H
H
9
1
9
1
12
1
13
1
I
10
1
7
10
13
1
10
1
pos.
J
K
description
qty.
12
1
7
10
13
1
10
1
pos.
description
qty.
pos.
comment
description
qty.
CAN IP67 keypad; CANopen; Screw-in;
LoadDump B; RGB
1
1
CAN IP67 keypad; J1939; Screw-in;
LoadDump B; RGB
1
1
CAN IP67 keypad; CANopen Safety - BS 10
s; Screw-in; LoadDump B; RGB
1
2
retaining clip for 2 mm panel
6
2
6
2
6
3
rubber washer 4,8x15x1
12
3
12
3
12
4
washer DIN9021 stainless A2
4
4
4
4
4
5
nut
4
5
nut
4
5
nut
4
6
coupler
1
6
coupler
1
6
coupler
1
7
symbol insert
10
7
symbol insert
10
7
symbol insert
10
quantity depending on panel thickness:
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
graphical symbols:
1x 09-0S12.5005 acc. to IEC 60417
1x 09-0S12.5006 acc. to IEC 60417
1x 09-0S12.1388 acc. to DIN ISO 7000
1x 09-0S12.0244 acc. to DIN ISO 7000
1x 09-0S12.2810 acc. to DIN ISO 7000
1x 09-0S12.2811 acc. to DIN ISO 7000
1x 09-0S12.1387 acc. to DIN ISO 7000
1x 09-0S12.0085 acc. to DIN ISO 7000
2x 09-0S12.0251 acc. to DIN ISO 7000
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
graphical symbols:
8
power supply
1
8
power supply
1
8
power supply
1
9
plug adapter
1
9
plug adapter
1
9
plug adapter
1
10
adapter cable keypad
1
10
1
10
1
11
mounting frame aluminium 2 mm
1
11
1
11
1
12
insert tool
1
12
insert tool
1
12
insert tool
1
13
USB-Stick
1
13
USB-Stick
1
13
USB-Stick
1
09-0A00.0001
I
comment
7
10
1
L
M
9
1
12
1
09-0A00.0001
comment
J
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
K
graphical symbols:
L
M
09-0A00.0001
N
N
O
O
description
drawing no.
P
08209 Auerbach
GERMANY
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
scale
format
weight
1:2
A0
2002940001
document type
01
status
product information
millimeters
22
revision
date
drawn 10.01.2022
approved 17.01.2022
23
name
EBJ
SCR
sheet no.
2/9
24
P
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
revision zone
date
01
24
description
RP - no.
1026
A
A
B
B
C
C
D
D
RCC CANopen Design- in kit - 09-1A22.1111
RCC J1939 Design- in kit - 09-1A12.1111
RCC CANopen safety Design- in kit - 09-1A32.1111
E
E
1
1
2
6
1
1
3
12
11
1
F
2
6
1
1
3
12
11
1
3
12
11
1
4
4
4
4
4
4
8
1
F
5
4
5
4
5
4
G
2
6
8
1
G
8
1
6
1
6
1
6
1
H
H
9
1
9
1
12
1
13
1
I
10
1
7
4
13
1
10
1
J
K
L
description
qty.
12
1
7
4
13
1
10
1
pos.
comment
description
qty.
7
4
pos.
comment
description
qty.
1
CAN IP67 RCC; CANopen; Screw-in;
LoadDump B; RGB
1
1
CAN IP67 RCC; J1939; Screw-in;
LoadDump B; RGB
1
1
CAN IP67 RCC; CANopen Safety - BS 10 s;
1
2
6
2
6
2
6
3
12
3
12
3
12
4
4
4
4
4
4
5
nut
4
5
nut
4
5
nut
4
6
coupler
1
6
coupler
1
6
coupler
1
7
symbol insert
4
7
symbol insert
4
7
symbol insert
4
8
power supply
1
8
power supply
1
8
power supply
1
9
plug adapter
1
9
plug adapter
1
9
plug adapter
1
10
1
10
1
10
1
11
1
11
1
11
1
12
insert tool
1
12
insert tool
1
12
insert tool
1
13
USB-Stick
1
13
USB-Stick
1
13
USB-Stick
1
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
graphical symbols:
09-0A00.0001
I
pos.
9
1
12
1
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
graphical symbols:
09-0A00.0001
comment
J
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
K
graphical symbols:
L
09-0A00.0001
M
M
N
N
O
O
description
drawing no.
P
08209 Auerbach
GERMANY
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
scale
format
weight
1:2
A0
2002940001
document type
01
status
product information
millimeters
22
revision
date
drawn 10.01.2022
approved 17.01.2022
23
name
EBJ
SCR
sheet no.
3/9
24
P
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
revision zone
date
01
A
16
description
RP - no.
1026
B
B
Keypad Design-in kit 12V with Namur - 09-0A72.3152
Keypad Design-in kit 12V - 09-0A72.3132
1
1
2
6
1
1
2
6
C
C
3
12
11
1
3
12
11
1
4
4
D
4
4
5
4
5
4
8
1
D
8
1
E
E
6
1
6
1
F
F
9
1
12
1
9
1
12
1
7
10
10
1
10
1
7
10
G
A
G
pos.
H
I
description
qty.
comment
pos.
description
qty.
1
CAN IP67 keypad; hardwired; Screw-in;
12V; LED red
1
1
CAN IP67 keypad; hardwired; Screw-in; 12V
with Namur; LED red
1
2
6
2
6
3
12
3
12
4
4
4
4
5
nut
4
5
nut
4
6
coupler
1
6
coupler
1
7
symbol insert
10
7
symbol insert
10
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
graphical symbols:
J
K
8
power supply
1
8
power supply
1
9
plug adapter
1
9
plug adapter
1
10
1
10
1
11
1
11
1
12
insert tool
1
12
insert tool
1
09-0A00.0001
comment
H
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
I
graphical symbols:
J
K
09-0A00.0001
description
drawing no.
L
08209 Auerbach
GERMANY
1
2
3
4
5
6
7
8
9
10
11
12
13
scale
format
weight
1:2
A1
14
revision
2002940001
document type
status
product information
millimeters
15
01
date
drawn 10.01.2022
approved 17.01.2022
16
name
EBJ
SCR
sheet no.
4/9
L
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
revision zone
date
01
A
16
description
RP - no.
1026
B
B
Keypad Design-in kit 24V with Namur - 09-0A72.3162
Keypad Design-in kit 24V - 09-0A72.3142
1
1
2
6
1
1
2
6
C
C
3
12
3
12
11
1
4
4
4
4
11
1
5
4
5
4
D
8
1
D
8
1
E
E
6
1
6
1
F
F
9
1
9
1
12
1
10
1
12
1
7
10
10
1
7
10
G
A
G
pos.
H
I
description
qty.
description
qty.
1
24V; LED red
1
1
CAN IP67 keypad; hardwired; Screw-in; 24V
with Namur; LED red
1
2
6
2
6
3
12
3
12
4
4
4
4
5
nut
4
5
nut
4
6
coupler
1
6
coupler
1
7
symbol insert
10
7
symbol insert
10
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
graphical symbols:
J
K
pos.
comment
8
power supply
1
8
power supply
1
9
plug adapter
1
9
plug adapter
1
10
1
10
1
11
1
11
1
12
insert tool
1
12
insert tool
1
09-0A00.0001
comment
H
1 mm: 0 per stud
2 mm: 1 per stud
3 mm: 2 per stud
4 mm: 3 per stud
I
graphical symbols:
J
K
09-0A00.0001
description
drawing no.
L
08209 Auerbach
GERMANY
1
2
3
4
5
6
7
8
9
10
11
12
13
scale
format
weight
1:2
A1
14
revision
2002940001
document type
status
product information
millimeters
15
01
date
drawn 10.01.2022
approved 17.01.2022
16
name
EBJ
SCR
sheet no.
5/9
L
1
2
3
4
assembly CAN IP67 KEYPADS
A
5
6
7
revision zone
date
01
8
description
RP - no.
1026
A
exemplarly representation of the symbols
B
B
C
C
D
D
E
E
description
drawing no.
F
mounting and demounting of the symbol inserts with insert tool 09-0A00.0001
1
2
3
4
08209 Auerbach
GERMANY
5
scale
format
weight
1:2
A3
6
revision
2002940001
document type
status
product information
millimeters
7
01
date
drawn 10.01.2022
approved 17.01.2022
name
EBJ
SCR
8
sheet no.
6/9
F
1
2
3
4
assembly CAN IP67 RCC
A
5
6
7
revision zone
date
01
8
description
RP - no.
1026
A
B
B
C
C
D
D
E
E
description
drawing no.
F
1
2
3
4
08209 Auerbach
GERMANY
5
scale
format
weight
1:2
A3
6
revision
2002940001
document type
status
product information
millimeters
7
01
date
drawn 10.01.2022
approved 17.01.2022
name
EBJ
SCR
8
sheet no.
7/9
F
1
2
3
4
A
assembly hardwired IP67 KEYPADS
5
6
7
revision zone
date
01
8
description
RP - no.
1026
B
A
B
C
C
D
D
E
E
description
drawing no.
F
08209 Auerbach
GERMANY
1
2
3
4
5
scale
format
weight
1:2
A3
6
revision
2002940001
document type
status
product information
millimeters
7
01
date
drawn 10.01.2022
approved 17.01.2022
name
EBJ
SCR
8
sheet no.
8/9
F
2
1
A
3
4
circuit diagramm IP67 keypad 6PB hardwired
R
P1
B
5
R
P2
V
P11
P8
P9
V
P4
R
V
P5
R
V
RP - no.
1026
Rs
P13
Rs
A
CAN IP67 keypads and RCC
P10
B
S
vent hole and
pressure compensation
do not puncture or plug
A
Rp
B
S
Rp
P14
P6
R
V
P7
R
V
R
V
R
V
R
V
R
V
R
S
8
Rp
P12
P3
7
description
hardwired IP67 keypads
V
R
C
Rs
6
revision zone
date
01
Rs
S
pushbutton number
Rp
P15
Rs
S
C
Rp
P16
Rs
S
detail B
Rp
variants with NAMUR
Rs = 120 Ω
Rp = 1 kΩ
V
2:1
variants without NAMUR
Rs = 0 Ω
Rp = not placed
detail A
2:1
D
E
F
connections WR-MPC3 16
connections 6 - DT ( DT04-6P)
mating plug: Wuerth 662 016 113 322
pin no. signal
comment
pin 1 supply voltage haloring button 1 12 VDC or 24 VDC **
pin 2 supply voltage haloring button 2 12 VDC or 24 VDC **
pin 3 supply voltage haloring button 3 12 VDC or 24 VDC **
pin 4 supply voltage haloring button 4 12 VDC or 24 VDC **
pin 5 supply voltage haloring button 5 12 VDC or 24 VDC **
pin 6 supply voltage haloring button 6 12 VDC or 24 VDC **
pin 7 supply voltage symbol lighting
12 VDC or 24 VDC **
pin 8 GND lighting
pin 9 GND lighting
pin 10 common potential buttons
pin 11 signal button 1
max. current 30 mA
pin 12 signal button 2
max. current 30 mA
pin 13 signal button 3
max. current 30 mA
pin 14 signal button 4
max. current 30 mA
pin 15 signal button 5
max. current 30 mA
pin 16 signal button 6
max. current 30 mA
** depending on purchased variant
mating plug: Deutsch DT06-6S
matching contacts: e.g. 1062-16-0122
matching wedge: W6-S
pin no. signal
wire
comment
pin 1 GND
black
pin 2 CAN High
yellow
pin 3 WakeUp_Out grey
pin 4 WakeUp_In blue
pin 5 CAN Low
green
pin 6 Vcc
red
8 - 32 VDC
description
2
3
4
5
E
drawing no.
08209 Auerbach
GERMANY
1
D
scale
format
weight
1:1
A3
6
revision
2002940001
document type
status
product information
millimeters
7
01
date
drawn 10.01.2022
approved 17.01.2022
name
EBJ
SCR
8
sheet no.
9/9
F
很抱歉,暂时无法提供与“09-0A72.3132”相匹配的价格&库存,您可以联系我们找货
