84-5030.0040
84-5030.0040
    EAO
    SWITCH EMERGENCY-STOP, 1NC+1NO,
84-5030.0040 数据手册
84-5030.0040 - Emergency-stop switch complete, foolproof EN IEC 60947-5-5 84-5030.0040 - Emergency-stop switch complete, foolproof EN IEC 60947-5-5 Mounting Mounting cut-out Design Behind panel depth Front Front dimension Front shape Other Attributes Weight Ø 22,3 mm raised 13,5 mm Ø 32 mm round 0,036 kg Operating-/Indication part Attention: The preview is based on a sample product. This can differ from your current configuration. Lens material Lens colour Lens profile Lens optics Lens illumination IP-Rating Front protection Connection Method Terminal Actuator Switching action Housing colour Housing material Switching element Switching voltage Switching current Switching system Contacts Contact material Plastic red Mushroom opaque non-illuminative IP65 Flat ribbon cable Maintained yellow Plastic 250 V AC/DC 5A Slow-make switching element 1 NC + 1 NO gold-plated silver Illumination LED colour Cable Version Cable type Function Stand: 05.01.2021 Flat ribbon cable 84-5030.0040 - Emergency-stop switch complete, foolproof EN IEC 60947-5-5 Emergency stop switch Stand: 05.01.2021 84-5030.0040 - Emergency-stop switch complete, foolproof EN IEC 60947-5-5 Dimensions Additional information Twist to unlock clockwise Position indication ring black Application as per DIN EN ISO 13850 and EN 60204-1 Standard version: Flat ribbon-cable length 300 mm or plug-in terminal 2.8 x 0.5 mm Other options on request: Customisation of flat ribbon-cable and connectors Legend F1 = Flat ribbon cable Mounting cut-outs Wiring diagram Component layout Stand: 05.01.2021 Powered by TCPDF (www.tcpdf.org) Contacts: NC = Normally closed, NO = Normally open
84-5030.0040 价格&库存
很抱歉,暂时无法提供与“84-5030.0040”相匹配的价格&库存,您可以联系我们找货
    • 1+1019.181581+131.85835
    • 5+615.524475+79.63452
    • 10+549.9225510+71.14716
    • 25+500.0556125+64.69554
    库存:36
