84-5130.0040 - Emergency-stop switch complete, foolproof EN IEC 60947-5-5
Mounting
Mounting cut-out
Design
Front
Front dimension
Front shape
Other Attributes
Weight
Ø 22.5 mm
raised
Ø 32 mm
round
0.036 kg
Operating-/Indication part
Attention: The preview is based on a sample product. This can
differ from your current configuration.
Lens material
Lens colour
Lens profile
Lens optics
IP-Rating
Front protection
Connection Method
Terminal
Actuator
Switching action
Switching element
Switching voltage
Switching current
Switching system
Contacts
Contact material
Illumination
LED colour
Function
Emergency stop switch
Stand: 24.10.2013
Plastic
red
Mushroom
opaque
IP 65
Flat ribbon cable
Maintained
250 V AC/DC
5A
Slow-make switching element
1 NC + 1 NO
Gold
Dimensions
Additional information
Twist to unlock clockwise
Position indication ring green
Application as per DIN EN ISO 13850 and EN 60204-1
Standard version: Flat ribbon-cable length 300 mm or plug-in
terminal 2.8 x 0.5 mm
Other options on request: Customisation of flat ribbon-cable and
connectors
Legend
F1 = Flat ribbon cable
Mounting cut-outs
Wiring diagram
Component layout
Stand: 24.10.2013
Powered by TCPDF (www.tcpdf.org)
Contacts: NC = Normally closed, NO = Normally open
很抱歉,暂时无法提供与“84-5130.0040”相匹配的价格&库存,您可以联系我们找货
