84-5140.0020
84-5140.0020
    EAO
    SWITCH PUSH DPST-NC 5A 250V
84-5140.0020 数据手册
HMI Components Edition 12/2012 Series 84 Characteristics Functions Market segments The compact 22.5 mm Series 84 is especially suited for: The Series 84 incorporates the following functions: The EAO Series 84 is especially suited for applications in the segments: ■■ ■■ ■■ Flush design Raised design PCB mounting ■■ ■■ ■■ ■■ The extremely small mounting depth makes this series highly suited for installation in flat, narrow casings. In combination with PCB fitting, Series 84 offers optional HALO illumination with attractive combination options and a wide variety of designs. Indicator Pushbutton Illuminated pushbutton E-STOP switch ■■ ■■ ■■ ■■ ■■ ■■ ■■ Public transport Machinery and Automation Construction machines and special-purpose vehicles Lifting and moving Panel building Medicinal technology Laboratory and measuring equipment Please refer to the EAO website to obtain detailed information regarding this series www.products.eao.com Configure a product to your exact needs and request a quotation. Content 84 01 Overview 02 Flush design Indicator 758 Illuminated pushbutton 760 Pushbutton 764 Indicator with halo illumination 768 Pushbutton with halo illumination 770 Indicator with halo illumination (multi-colour) 772 Pushbutton with halo illumination (multi-colour) 773 03 04 10 14 17 Raised design Emergency-stop switch 774 Stop switch 776 Accessories 778 Drawings 803 Technical data 805 Application guidelines 809 Index 810 18 19 22 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 757 84 01 Flush design Indicator standard 02 Equipment consisting of (schematic overview) Ø25 03 P1 M1 M2 M5 F1 2 300 ±10 23 6 max. 10 M1 M5 M2 Ø32 Product can differ from the current configuration. 18 NJO ±NN • Illuminated lens, non-illuminated bezel NJO ±NN 51 PLQ PLQ • The colour of anodized aluminium parts can vary due to technical production reasons  44 To obtain a complete unit, please select the red components from the pages shown. Additional Information ±  41 page 785 Each Part Number listed below includes all the black components shown in the 3D-drawing. Dimensions [mm] F1 = Flat ribbon cable, P1 = Plug-in terminal 2.8 x 0.8 mm, M1 = Lens level with bezel, M2 = Lens raised above bezel M5 = Mushroom-head cap 22 Fixing nut Illumination element 9.5 4 19 Actuator 23 14 31 page 778 9 04 17 Lens 3NBY  56   Mounting cut-outs [mm] 57 61 70 Front protection Front ring Part No. Weight 71 82 84 Indicator actuator standard, Front dimension Ø 25 mm IP 40 Plastic black 84-3100.0 0.004 kg IP 67 Plastic black 84-0100.0 0.003 kg Aluminium natural anodized 84-0200.7 0.008 kg 92 95 96 97 99 ST 758 Flush design 84 01 Indicator PCB standard Equipment consisting of (schematic overview) 02 M5 M2 03 Ø32 page 778 Ø25 Lens M1 04 Actuator Fixing nut 2 Mounting flange page 791 LED page 793 Illumination element 18 10 9.5 4 4max. 3.6 14 Dimensions [mm] M1 = Lens level with bezel, M2 = Lens raised above bezel M5 = Mushroom-head cap Product can differ from the current configuration. 17 18 page 790 NJO ±NN Additional Information NJO ±NN • Illuminated lens, non-illuminated bezel Each Part Number listed below includes all the black components shown in the 3D-drawing. PLQ  PLQ • The colour of anodized aluminium parts can vary due to technical production reasons ±  To obtain a complete unit, please select the red components from the pages shown. 19 22 31 3NBY 41    44 Mounting cut-outs [mm] 51 Front protection Front ring Part No. Weight 56 57 61 Indicator actuator PCB standard, Front dimension Ø 25 mm IP 40 Plastic black 84-3100.0 0.004 kg IP 67 Plastic black 84-0100.0 0.003 kg Aluminium natural anodized 84-0200.7 0.008 kg 70 71 82 84 92 95 96 97 99 ST 759 84 01 Flush design Illuminated pushbutton standard 02 Equipment consisting of (schematic overview) Ø25 03 P1 F1 9 04 300 ±10 23 6 max. Lens page 778 Actuator 23 2 10 Fixing nut Ø40 14 17 M1 M2 M5 Product can differ from the current configuration. P1 F1 M1 Switching element page 787 9 18 19 Each Part Number listed below includes all the black components shown in the 3D-drawing. 300 ±10 21 3 max. 21 4 M1 Ø32 22 To obtain a complete unit, please select the red components from the pages shown. M5 M2 31 Dimensions [mm] F1 = Flat ribbon cable, P1 = Plug-in terminal 2.8 x 0.8 mm, M1 = Lens level with bezel, M2 = Lens raised above bezel, M5 = Mushroom-head cap 44 51 NJO ±NN • Illuminated lens, non-illuminated bezel NJO ±NN NJO ±NN • The colour of anodized aluminium parts can vary due to technical production reasons 70 3NBY    71 NJO ±   61 PLQ 57 Additional Information PLQ 56 9.5 4 41  ±  Mounting cut-outs [mm] 82 92 Front protection Front ring Switching action Part No. Wiring diagram 84 Weight 84-1221.7 1 0.022 kg 95 96 IP 67 Illuminated pushbutton standard, Front dimension Ø 40 mm Aluminium natural anodized B 97 99 ST Illuminated pushbutton standard, Front dimension Ø 25 mm IP 40 Plastic black B 84-2101.0 1 0.004 kg IP 67 Plastic black B 84-1101.0 1 0.003 kg Aluminium black anodized B 84-1201.0 1 0.008 kg Aluminium red anodized B 84-1201.2 1 0.008 kg 760 84 01 Front protection Front ring Switching action Part No. Wiring diagram Flush design Weight IP 67 Aluminium gold anodized B 84-1201.4 1 0.008 kg Aluminium olive-green anodized B 84-1201.5 1 0.008 kg Aluminium blue anodized B 84-1201.6 1 0.008 kg Aluminium natural anodized B 84-1201.7 1 0.008 kg Switching action: B = Momentary 02 03 04 10 14 17 18 19 Wiring diagram 1 22 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 761 84 01 Flush design Illuminated pushbutton PCB standard 02 M1 M2 M5 M1 Equipment consisting of (schematic overview) 03 04 Actuator 10 4max. 18 2 14 M1 3max. 3.6 19 M5 M2 9.5 4 31 Additional Information NJO ±NN • Illuminated lens, non-illuminated bezel NJO ±NN Mounting flange page 791 LED page 793 Switching element page 789 Each Part Number listed below includes all the black components shown in the 3D-drawing. Dimensions [mm] M1 = Lens level with bezel, M2 = Lens raised above bezel, M5 = Mushroom-head cap 22 To obtain a complete unit, please select the red components from the pages shown. NJO ±NN 56 3NBY    57 NJO ±   51 PLQ • The colour of anodized aluminium parts can vary due to technical production reasons PLQ 44 Fixing nut 3.6 Product can differ from the current configuration. 18 41 16 4 Ø32 17 page 778 Ø40 Ø25 Lens  ±  Mounting cut-outs [mm] 70 Front protection Front ring Switching action Part No. Wiring diagram 61 Weight 84-1221.7 1 0.022 kg 84-2101.0 1 0.004 kg 71 82 84 Illuminated pushbutton actuator PCB standard, Front dimension Ø 40 mm IP 67 Aluminium natural anodized B 92 95 96 Illuminated pushbutton actuator PCB standard, Front dimension Ø 25 mm IP 40 IP 67 Plastic black B Plastic black B 84-1101.0 1 0.003 kg Aluminium black anodized B 84-1201.0 1 0.008 kg 97 Aluminium red anodized B 84-1201.2 1 0.008 kg Aluminium gold anodized B 84-1201.4 1 0.008 kg 99 Aluminium olive-green anodized B 84-1201.5 1 0.008 kg Aluminium blue anodized B 84-1201.6 1 0.008 kg Aluminium natural anodized B 84-1201.7 1 0.008 kg ST Switching action: B = Momentary 762 Flush design 84 01 02 03 04 Wiring diagram 1 10 14 17 18 19 22 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 763 84 01 Flush design Pushbutton standard 02 Ø25 03 P1 F1 9 04 300 ±10 23 6 max. Equipment consisting of (schematic overview) Lens page 779 Actuator 23 2 10 Product can differ from the current configuration. Ø40 Fixing nut 14 17 M1 M2 M3 M4 M5 P1 F1 M1 Switching element page 789 9 18 4 19 M1 Each Part Number listed below includes all the black components shown in the 3D-drawing. 300 ±10 21 3 max. 21 M2 M4 M3 M5 Ø32 22 To obtain a complete unit, please select the red components from the pages shown. 31 4 41 51 56 Additional Information NJO ±NN • Non-illuminated lens and bezel NJO ±NN NJO ±NN 71 3NBY    82 NJO ±   70 PLQ • The colour of anodized aluminium parts can vary due to technical production reasons PLQ 61 9.5 7 Dimensions [mm] F1 = Flat ribbon cable, P1 = Plug-in terminal 2.8 x 0.8 mm, M1 = Lens level with bezel, M2 = Lens raised above bezel, M3 = Lens konvexe level with bezel, M4 = Lens convexe raised above bezel, M5 = Mushroom-head cap 44 57 5  ±  Mounting cut-outs [mm] 92 Front protection Front ring Switching action Part No. Wiring diagram 84 Weight 84-1221.7 1 0.022 kg 95 96 97 IP 67 99 ST 764 Pushbutton actuator standard, Front dimension Ø 40 mm Aluminium natural anodized B Front protection Front ring Switching action Part No. Wiring diagram Flush design 84 01 Weight 02 03 Pushbutton actuator standard, Front dimension Ø 25 mm IP 40 IP 67 Plastic black B 84-2101.0 1 0.004 kg Plastic black B 84-1101.0 1 0.003 kg Aluminium black anodized B 84-1201.0 1 0.008 kg Aluminium red anodized B 84-1201.2 1 0.008 kg Aluminium gold anodized B 84-1201.4 1 0.008 kg Aluminium olive-green anodized B 84-1201.5 1 0.008 kg Aluminium blue anodized B 84-1201.6 1 0.008 kg Aluminium natural anodized B 84-1201.7 1 0.008 kg Switching action: B = Momentary 04 10 14 17 18 19 22 31 41 44 Wiring diagram 1 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 765 84 01 Flush design Pushbutton PCB standard 02 M1 M2 M3 M4 M5 M1 Equipment consisting of (schematic overview) 03 04 Actuator 10 4max. 18 2 14 M1 M2 3max. 3.6 16 4 M4 M3 M5 Product can differ from the current configuration. 18 19 9.5 7 41 Additional Information NJO ±NN • Non-illuminated lens and bezel NJO ±NN Fixing nut Mounting flange page 791 Switching element page 789 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Dimensions [mm] F1 = Flat ribbon cable, P1 = Plug-in terminal 2.8 x 0.8 mm, M1 = Lens level with bezel, M2 = Lens raised above bezel, M3 = Lens konvexe level with bezel, M4 = Lens convexe raised above bezel, M5 = Mushroom-head cap 31 NJO ±NN 57 3NBY    61 NJO ±   56 PLQ • The colour of anodized aluminium parts can vary due to technical production reasons PLQ 51 5 4 22 44 3.6 Ø32 17 page 779 Ø40 Ø25 Lens  ±  Mounting cut-outs [mm] Part No. Wiring diagram 70 Weight 84-1221.7 1 0.022 kg 71 Front protection Front ring Switching action 82 84 92 IP 67 95 96 97 99 ST 766 Pushbutton actuator PCB standard, Front dimension Ø 40 mm Aluminium natural anodized B Front protection Front ring Switching action Part No. Wiring diagram Flush design 84 01 Weight 02 03 Pushbutton actuator PCB standard, Front dimension Ø 25 mm IP 40 IP 67 Plastic black B 84-2101.0 1 0.004 kg Plastic black B 84-1101.0 1 0.003 kg Aluminium black anodized B 84-1201.0 1 0.008 kg Aluminium red anodized B 84-1201.2 1 0.008 kg Aluminium gold anodized B 84-1201.4 1 0.008 kg Aluminium olive-green anodized B 84-1201.5 1 0.008 kg Aluminium blue anodized B 84-1201.6 1 0.008 kg Aluminium natural anodized B 84-1201.7 1 0.008 kg Switching action: B = Momentary 04 10 14 17 18 19 22 31 41 44 Wiring diagram 1 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 767 84 01 Flush design Indicator with halo illumination standard, IP 67 02 Equipment consisting of (schematic overview) Ø25 03 P1 M2 M4 F1 Lens 9 04 2 300 ±10 23 6 max. 10 Actuator 23 M4 M2 Fixing nut 14 Product can differ from the current configuration. 18 4 22 41 page 785 Each Part Number listed below includes all the black components shown in the 3D-drawing. 7 Dimensions [mm] F1 = Flat ribbon cable, P1 = Plug-in terminal 2.8 x 0.8 mm, M2 = Lens raised above bezel, M4 = Lens convexe raised above bezel 19 31 Illumination element To obtain a complete unit, please select the red components from the pages shown. Additional Information NJO • Front bezel illuminated • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A ±   44 PLQ 17 page 780 51 3NBY    56 Mounting cut-outs [mm] 57 61 70 Front ring 71 82 92 95 96 97 99 ST 768 Weight 84-0090.7 0.006 kg Indicator actuator with halo illumination standard, Front dimension Ø 25 mm Plastic colourless translucent 84 Part No. Flush design 84 01 Indicator with halo illumination PCB standard, IP 67 Equipment consisting of (schematic overview) 02 M4 03 page 780 Ø25 Lens M2 M2 M4 04 Actuator 4 4max. Fixing nut 2 Mounting flange page 791 LED page 793 Illumination element 18 10 7 3.6 14 Dimensions [mm] M2 = Lens raised above bezel, M4 = Lens convexe raised above bezel Product can differ from the current configuration. 17 18 Additional Information NJO page 790 • Front bezel illuminated  ±  To obtain a complete unit, please select the red components from the pages shown. PLQ Each Part Number listed below includes all the black components shown in the 3D-drawing. • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A 19 22 31 3NBY    41 Mounting cut-outs [mm] 44 51 Front ring Part No. Weight 56 57 Indicator actuator with halo illumination PCB standard, Front dimension Ø 25 mm Plastic colourless translucent 84-0090.7 0.006 kg 61 70 71 82 84 92 95 96 97 99 ST 769 84 01 Flush design Pushbutton actuator with halo illumination standard, IP 67 02 Equipment consisting of (schematic overview) Ø25 03 P1 M2 M4 F1 Lens 9 04 300 ±10 23 6 max. Actuator 23 2 10 M4 M2 Fixing nut 14 Product can differ from the current configuration. Switching element 18 4 22 31 41 Each Part Number listed below includes all the black components shown in the 3D-drawing. 7 Dimensions [mm] F1 = Flat ribbon cable, P1 = Plug-in terminal 2.8 x 0.8 mm, M2 = Lens raised above bezel, M4 = Lens convexe raised above bezel 19 page 787 To obtain a complete unit, please select the red components from the pages shown. Additional Information NJO • Front bezel illuminated • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A ±   44 PLQ 17 page 780 51 3NBY    56 Mounting cut-outs [mm] Part No. Wiring diagram 57 Weight 84-1091.7 1 0.006 kg 61 70 Front ring 71 82 84 Switching action Switching action: B = Momentary 92 95 96 97 Pushbutton actuator with halo illumination standard, Front dimension Ø 25 mm Plastic colourless translucent Wiring diagram 1 99 ST 770 B Flush design 84 01 Pushbutton with halo illumination PCB standard, IP 67 Equipment consisting of (schematic overview) 02 M4 03 page 780 Ø25 Lens M2 M2 M4 04 Actuator 4 4max. Fixing nut 18 2 Mounting flange page 791 LED page 793 10 7 3.6 14 Dimensions [mm] M2 = Lens raised above bezel, M4 = Lens convexe raised above bezel Product can differ from the current configuration. 17 18 Additional Information NJO page 789 • Front bezel illuminated ±   Each Part Number listed below includes all the black components shown in the 3D-drawing. PLQ Switching element To obtain a complete unit, please select the red components from the pages shown. • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A 19 22 31 3NBY    41 Mounting cut-outs [mm] Switching action Part No. Wiring diagram Front ring 44 51 Weight 56 57 Pushbutton actuator with halo illumination PCB standard, Front dimension Ø 25 mm Plastic colourless translucent B 84-1091.7 1 0.006 kg Switching action: B = Momentary 61 70 71 82 84 92 Wiring diagram 1 95 96 97 99 ST 771 84 01 Flush design Indicator with halo illumination (multi-colour) PCB, IP 67 02 M1 M2 M3 M4 Equipment consisting of (schematic overview) 03 04 Actuator 10 4max. 18 2 14 17 M1 M2 Befestigungsmutter 3.6 M4 M3 Product can differ from the current configuration. 18 7 Dimensions [mm] M1 = Lens level with bezel, M2 = Lens raised above bezel, M3 = Lens konvexe level with bezel, M4 = Lens convexe raised above bezel 22 31 Mounting flange page 791 Single-LED page 793 Illumination element page 790 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Additional Information NJO • The LEDs are not part of delivery. Recommendation: Osram Hyper Mini TOPLED ±   51 PLQ 44 5 4 19 41 page 778 Ø25 Lens 56 3NBY    57 Mounting cut-outs [mm] 61 70 Front ring Part No. Weight 84-0080.7 0.006 kg 71 82 84 Indicator actuator with halo illumination (multi-colour) PCB, Front dimension Ø 25 mm Plastic colourless transparent 92 95 96 97 99 ST 772 Flush design 84 01 Pushbutton actuator with halo illumination (multi-colour) PCB, IP 67 03 page 778 Ø25 Lens 02 M1 M2 M3 M4 Equipment consisting of (schematic overview) 04 Actuator 10 4max. 18 2 Fixing nut M1 Mounting flange page 791 LED page 793 Switching element page 789 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. M2 3.6 14 M4 M3 Product can differ from the current configuration. 17 18 5 4 7 19 Dimensions [mm] M1 = Lens level with bezel, M2 = Lens raised above bezel, M3 = Lens konvexe level with bezel, M4 = Lens convexe raised above bezel 22 31 Additional Information NJO ±   PLQ • The LEDs are not part of delivery. Recommendation: Osram Hyper Mini TOPLED 41 44 51 3NBY 56    57 Mounting cut-outs [mm] Front ring Switching action Part No. Wiring diagram 61 Weight 70 71 82 Pushbutton actuator with halo illumination (multi-colour) PCB, Front dimension Ø 25 mm Plastic colourless transparent B 84-1081.7 1 0.006 kg 84 Switching action: B = Momentary 92 95 96 97 99 Wiring diagram 1 ST 773 84 01 Raised design Emergency-stop switch complete, foolproof EN IEC 60947-5-5, IP 65 1...4 03 P Equipment consisting of (schematic overview) Ø 32 02 04 10 26 Actuator 9.5 18 14 17 Fixing nut F1 Product can differ from the current configuration. Each Part Number listed below includes all the black components shown in the 3D-drawing. 18 Dimensions [mm] F1 = Flat ribbon cable, P = Plug-in terminal 2.8 x 0.5 mm 22 51 • Lens plastic red  • Switching action maintain   3NBY • Twist to unlock clockwise • Application as per DIN EN ISO 13850 and EN 60204-1 • Standard version: Flat ribbon-cable length 300 mm or plug-in terminal 2.8 x 0.5 mm 56 • Other options on request: Customisation of flat ribbon-cable and connectors 57 • Luminosity and wave length scattering caused by LED manufacturing processes may cause slight variations in the illumination NJO 44 NJO  41 Additional Information   31 300 ± 10 13.5 19  ±  Mounting cut-outs [mm] 71 Product attribute LED colour Contacts Terminal Part No. Wiring diagram 70 Component layout 61 Weight 82 84 Emergency-stop switch complete, foolproof EN IEC 60947-5-5, Front dimension Ø 32 mm Position indication ring green 92 Single-LED red 95 96 Position indication ring black 97 Single-LED red 99 ST 774 1 NC Flat ribbon cable 84-5120.0040 1 1 0.036 kg 1 NC + 1 NO Flat ribbon cable 84-5130.0040 1 2 0.036 kg 2 NC Flat ribbon cable 84-5140.0040 1 3 0.036 kg 1 NC Flat ribbon cable 84-5121.2B40 1 4 0.036 kg 1 NC + 1 NO Flat ribbon cable 84-5131.2B40 1 5 0.036 kg 2 NC Flat ribbon cable 84-5141.2B40 1 6 0.036 kg 1 NC Flat ribbon cable 84-5020.0040 1 1 0.036 kg 1 NC + 1 NO Flat ribbon cable 84-5030.0040 1 2 0.036 kg 2 NC Flat ribbon cable 84-5040.0040 1 3 0.036 kg 1 NC Flat ribbon cable 84-5021.2B40 1 4 0.036 kg 1 NC + 1 NO Flat ribbon cable 84-5031.2B40 1 5 0.036 kg 2 NC Flat ribbon cable 84-5041.2B40 1 6 0.036 kg LED colour Contacts Terminal Part No. Wiring diagram Product attribute Component layout Raised design 84 01 Weight 02 03 Emergency-stop switch complete, foolproof EN IEC 60947-5-5, Front dimension Ø 32 mm Position indication ring green 1 NC Single-LED red Position indication ring black Single-LED red 84-5120.0020 Plug 2.8 x 0.5 mm 2 1 0.028 kg 1 NC + 1 NO Plug 2.8 x 0.5 mm 84-5130.0020 2 2 0.028 kg 2 NC Plug 2.8 x 0.5 mm 84-5140.0020 2 3 0.028 kg 1 NC Plug 2.8 x 0.5 mm 84-5121.2B20 2 3 0.028 kg 1 NC + 1 NO Plug 2.8 x 0.5 mm 84-5131.2B20 2 5 0.028 kg 2 NC Plug 2.8 x 0.5 mm 84-5141.2B20 2 6 0.028 kg 1 NC Plug 2.8 x 0.5 mm 84-5020.0020 2 1 0.028 kg 1 NC + 1 NO Plug 2.8 x 0.5 mm 84-5030.0020 2 2 0.028 kg 2 NC Plug 2.8 x 0.5 mm 84-5040.0020 2 3 0.028 kg 1 NC Plug 2.8 x 0.5 mm 84-5021.2B20 2 4 0.028 kg 1 NC + 1 NO Plug 2.8 x 0.5 mm 84-5031.2B20 2 5 0.028 kg 2 NC Plug 2.8 x 0.5 mm 84-5041.2B20 2 6 0.028 kg Contacts: NC = Normally closed, NO = Normally open The component layouts you will find from page 803 11 11 04 10 14 17 18 19 22 31 23 11 21 11 X2+ 11 41 23 X2+ 44 12 Wiring diagram 1 11 12 Wiring diagram 2 24 12 Wiring diagram 3 22 12 Wiring diagram 4 X1– 12 51 24 X1– 56 Wiring diagram 5 57 21 X2 + 61 12 70 22 X1– 71 Wiring diagram 6 82 84 92 95 96 97 99 ST 775 84 01 Raised design Stop switch complete grey, IP 65 02 1...4 03 Equipment consisting of (schematic overview) Ø32 P 04 10 26 Actuator 9.5 18 14 17 Fixing nut Product can differ from the current configuration. F1 Each Part Number listed below includes all the black components shown in the 3D-drawing. 18 300 ± 10 13.5 19 Dimensions [mm] F1 = Flat ribbon cable, P = Plug-in terminal 2.8 x 0.5 mm 22 31 Additional Information 41 • Switching action maintain NJO • Lens plastic grey 3NBY • Position indication ring black 51 56 57  • Twist to unlock clockwise   44 NJO    • Standard version: Flat ribbon-cable length 300 mm or plug-in terminal 2.8 x 0.5 mm • Other options on request: Customisation of flat ribbon-cable and connectors • Luminosity and wave length scattering caused by LED manufacturing processes may cause slight variations in the illumination  ±  Mounting cut-outs [mm] LED colour Wiring diagram 70 Component layout 61 Weight 1 NC Flat ribbon cable 84-6820.0040 1 1 0.036 kg 1 NC + 1 NO Flat ribbon cable 84-6830.0040 1 2 0.036 kg 2 NC Flat ribbon cable 84-6840.0040 1 3 0.036 kg 1 NC Flat ribbon cable 84-6821.2B40 1 4 0.036 kg 1 NC + 1 NO Flat ribbon cable 84-6831.2B40 1 5 0.036 kg 2 NC Flat ribbon cable 84-6841.2B40 1 6 0.036 kg Contacts Terminal Part No. 71 82 84 92 Single-LED red 95 96 97 99 ST 776 Stop switch complete grey, Front dimension Ø 32 mm Contacts Terminal Part No. Wiring diagram LED colour Component layout Raised design 84 01 Weight 02 03 Stop switch complete grey, Front dimension Ø 32 mm Single-LED red 1 NC Plug 2.8 x 0.5 mm 84-6820.0020 2 1 0.028 kg 1 NC + 1 NO Plug 2.8 x 0.5 mm 84-6830.0020 2 2 0.028 kg 2 NC Plug 2.8 x 0.5 mm 84-6840.0020 2 3 0.028 kg 1 NC Plug 2.8 x 0.5 mm 84-6821.2B20 2 4 0.028 kg 1 NC + 1 NO Plug 2.8 x 0.5 mm 84-6831.2B20 2 5 0.028 kg 2 NC Plug 2.8 x 0.5 mm 84-6841.2B20 2 6 0.028 kg Contacts: NC = Normally closed, NO = Normally open The component layouts you will find from page 803 11 11 04 10 14 17 18 23 11 21 11 X2+ 11 19 23 X2+ 22 12 Wiring diagram 1 11 12 Wiring diagram 2 24 12 Wiring diagram 3 22 12 Wiring diagram 4 X1– 12 31 24 X1– 41 Wiring diagram 5 44 21 X2 + 51 12 56 22 X1– 57 Wiring diagram 6 61 70 71 82 84 92 95 96 97 99 ST 777 84 Accessories 01 Front 02 Lens plastic 03 04 Additional Information • Lens profile flat 10 14 Product attribute Dimension Lens Mounting type Part No. Weight 17 18 19 Lens plastic illuminative Ø 19.7 mm red transparent level with bezel 84-7111.200 0.001 kg orange transparent level with bezel 84-7111.300 0.001 kg 22 yellow transparent level with bezel 84-7111.400 0.001 kg green transparent level with bezel 84-7111.500 0.001 kg 31 blue transparent level with bezel 84-7111.600 0.001 kg colourless transparent level with bezel 84-7111.700 0.001 kg 41 44 non-illuminative Ø 19.7 mm illuminative Ø 19.7 mm 51 56 57 61 70 71 non-illuminative Ø 19.7 mm black opaque level with bezel 84-7121.000 0.001 kg grey opaque level with bezel 84-7121.800 0.001 kg red transparent raised above bezel 84-7115.200 0.001 kg orange transparent raised above bezel 84-7115.300 0.001 kg yellow transparent raised above bezel 84-7115.400 0.001 kg green transparent raised above bezel 84-7115.500 0.001 kg blue transparent raised above bezel 84-7115.600 0.001 kg colourless transparent raised above bezel 84-7115.700 0.001 kg black opaque raised above bezel 84-7125.000 0.001 kg grey opaque raised above bezel 84-7125.800 0.001 kg Marking plate Additional Information • Can be hot stamped 82 84 Marking plate Part No. Weight 61-9707.7 0.001 kg 92 95 96 Legend plate for lens plastic Plastic colourless transparent 97 99 ST 778 Accessories 84 01 Lens plastic with symbol 02 Additional Information • Lens profile flat 03 • Illuminative • The silvery coat is being applied on the lens (screen print) with an additional protective lacquer. Further information see «Technical data» 04 10 14 Dimension Lens Mounting type Symbol Part No. Weight 17 18 Lens plastic with symbol Ø 19.7 mm red transparent level with bezel Ring 84-7111.201 0.002 kg orange transparent level with bezel Ring 84-7111.301 0.002 kg yellow transparent level with bezel Ring 84-7111.401 0.002 kg green transparent level with bezel Ring 84-7111.501 0.002 kg blue transparent level with bezel Ring 84-7111.601 0.002 kg colourless transparent level with bezel Ring 84-7111.701 0.002 kg 19 22 31 41 44 Lens plastic with symbol Ø 19.7 mm red transparent level with bezel ON/OFF 84-7111.202 0.002 kg green transparent level with bezel ON/OFF 84-7111.502 0.002 kg blue transparent level with bezel ON/OFF 84-7111.602 0.002 kg colourless transparent level with bezel ON/OFF 84-7111.702 0.002 kg 51 56 57 61 Lens plastic with symbol Ø 19.7 mm red transparent level with bezel Stand by 84-7111.203 0.002 kg green transparent level with bezel Stand by 84-7111.503 0.002 kg blue transparent level with bezel Stand by 84-7111.603 0.002 kg colourless transparent level with bezel Stand by 84-7111.703 0.002 kg 70 71 82 Lens metal 84 Additional Information 92 • The colour of anodized aluminium parts can vary due to technical production reasons 95 96 Product attribute Dimension Lens Mounting type Part No. 97 Weight 99 flat Lens metal Ø 25 mm Aluminium black anodized level with bezel 84-7201.000 0.003 kg Ø 19.7 mm Aluminium red anodized level with bezel 84-7201.200 0.003 kg ST 779 84 Accessories 01 02 Product attribute Dimension Lens Mounting type Part No. Weight flat Ø 19.7 mm Aluminium gold anodized level with bezel 84-7201.400 0.003 kg Aluminium olive-green anodized level with bezel 84-7201.500 0.003 kg Aluminium blue anodized level with bezel 84-7201.600 0.003 kg Aluminium natural anodized level with bezel 84-7201.800 0.003 kg Aluminium black anodized raised above bezel 84-7205.000 0.003 kg Aluminium red anodized raised above bezel 84-7205.200 0.003 kg 03 04 10 14 17 Aluminium gold anodized raised above bezel 84-7205.400 0.003 kg Aluminium olive-green anodized raised above bezel 84-7205.500 0.003 kg Aluminium blue anodized raised above bezel 84-7205.600 0.003 kg Aluminium natural anodized raised above bezel 84-7205.800 0.003 kg 18 19 Lens metal convex (domed) Ø 19.7 mm 22 31 41 44 51 56 57 Aluminium black anodized level with bezel 84-7202.000 0.003 kg Aluminium red anodized level with bezel 84-7202.200 0.003 kg Aluminium gold anodized level with bezel 84-7202.400 0.003 kg Aluminium olive-green anodized level with bezel 84-7202.500 0.003 kg Aluminium blue anodized level with bezel 84-7202.600 0.003 kg Aluminium natural anodized level with bezel 84-7202.800 0.003 kg Lens Mounting type Part No. Weight Lens for halo illumination Additional Information • Lens profile flat or convex (domed)) • The colour of anodized aluminium parts can vary due to technical production reasons 61 70 Product attribute Dimension 71 82 flat Lens metall for halo illumination Ø 19.7 mm 84 92 95 Aluminium black anodized raised above bezel 84-7205.000A 0.003 kg Aluminium red anodized raised above bezel 84-7205.200A 0.003 kg Aluminium gold anodized raised above bezel 84-7205.400A 0.003 kg Aluminium olive-green anodized raised above bezel 84-7205.500A 0.003 kg Aluminium blue anodized raised above bezel 84-7205.600A 0.003 kg Aluminium natural anodized raised above bezel 84-7205.800A 0.003 kg 96 97 convex (domed) 99 ST 780 Lens metall for halo illumination Ø 19.7 mm Aluminium black anodized raised above bezel 84-7202.000A 0.004 kg Aluminium red anodized raised above bezel 84-7202.200A 0.004 kg Aluminium gold anodized raised above bezel 84-7202.400A 0.004 kg Aluminium olive-green anodized raised above bezel 84-7202.500B 0.004 kg Aluminium blue anodized raised above bezel 84-7202.600A 0.004 kg Aluminium natural anodized raised above bezel 84-7202.800A 0.004 kg Accessories 84 01 Lens for stop request pushbutton 02 Additional Information • Lens profile flat • With raised labelling symbol, TSI compliant 03 • The colour of anodized aluminium parts can vary due to technical production reasons 04 10 Dimension Lens Mounting type Symbol Part No. 14 Weight 17 Ø 19.7 mm 18 Lens metal for halo illumination with raised symbol Aluminium natural anodized raised above bezel Door open 84-7205.804A 0.003 kg 19 22 Ø 19.7 mm Lens metal for halo illumination with raised symbol Aluminium natural anodized raised above bezel Wheelchair 84-7205.805A 31 0.003 kg 41 Ø 19.7 mm 44 Lens metal for halo illumination with raised symbol Aluminium natural anodized raised above bezel Baby carriage 84-7205.806A 0.003 kg 51 56 Ø 19.7 mm Lens metal for halo illumination with raised symbol Aluminium natural anodized raised above bezel Bell 84-7205.808A 57 0.003 kg 61 70 71 82 84 92 95 96 97 99 ST 781 84 01 02 03 Accessories Lens metal with dot Additional Information • Lens profile flat • The colour of anodized aluminium parts can vary due to technical production reasons 04 10 14 Product attribute Dimension Lens Mounting type Part No. Weight 17 18 illuminative 19 Lens metal with dot Ø 19.7 mm Aluminium black anodized level with bezel 84-7211.000 0.002 kg Aluminium red anodized level with bezel 84-7211.200 0.002 kg Aluminium gold anodized level with bezel 84-7211.400 0.002 kg 22 Aluminium olive-green anodized level with bezel 84-7211.500 0.002 kg Aluminium blue anodized level with bezel 84-7211.600 0.002 kg 31 Aluminium natural anodized level with bezel 84-7211.800 0.002 kg Aluminium black anodized raised above bezel 84-7215.000 0.002 kg 41 Aluminium red anodized raised above bezel 84-7215.200 0.002 kg Aluminium gold anodized raised above bezel 84-7215.400 0.002 kg 44 Aluminium olive-green anodized raised above bezel 84-7215.500 0.002 kg Aluminium blue anodized raised above bezel 84-7215.600 0.002 kg Aluminium natural anodized raised above bezel 84-7215.800 0.002 kg 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 782 Accessories 84 01 Mushroom-head cap 02 Product attribute Mushroom-head cap Part No. 03 Weight 04 10 Mushroom-head cap, Front dimension Ø 32 mm illuminative Plastic blue 84-7114.600A 0.004 kg non-illuminative Plastic black 84-7124.000A 0.004 kg Plastic red 84-7124.200A 0.004 kg Plastic yellow 84-7124.400A 0.004 kg Plastic green 84-7124.500A 0.004 kg Plastic blue 84-7124.600A 0.004 kg 14 17 18 19 Front protective cap, IP 68 22 Additional Information 31 • For flat lense profil only • When using the front protection cover the external sealing in the actuator has to be removed 41 44 Material Colour Optics Part No. 51 Weight 56 57 Front protective cap Silicone colourless transparent 84-9103.7 0.001 kg 61 Legend frame 70 71 Additional Information • For devices with front dimension Ø 25 mm, flush design 82 • The colour of anodized aluminium parts can vary due to technical production reasons 84 92 Dimension Material Colour Mounting type Part No. 95 Weight 96 Legend frame 30 x 50 x 0.75 mm Aluminium black anodized adhesive 61-9980.0 97 0.001 kg 99 ST 783 84 01 02 03 Accessories Legend plate Additional Information • For legend frame Part No. 61-9980.0 • The colour of anodized aluminium parts can vary due to technical production reasons 04 10 14 Dimension Material Colour Mounting type Part No. Weight 17 Legend plate for legend frame 19 22 Blind plug, IP 65 31 Additional Information 44 • Please note that bigger minimum distances are necessary adhesive 704.968.0 0.001 kg adhesive 704.968.1 0.001 kg 16.5 ... 20.5 Ø25 41 2 • The dimensions of the mounting cut-outs are shown in the product details natural anodized black anodized 51 2.6 14 Ø 35.6 Aluminium Ø 36.2 14.5 x 23.5 mm 23.5 18 1 ... 5 2…6 56 Dimensions [mm] 57 61 70 Product attribute Dimension Mounting cut-out Material Colour Part No. Weight Ø 25 mm Ø 22.5 mm Plastic black 61-9453.0 0.006 kg Ø 36 mm Ø 30.5 mm Plastic black 704.964.8 0.007 kg 71 82 Blind plug with this print version of the panel thickness is reduced to 2.5 mm max. 84 92 95 96 97 99 ST 784 Blind plug Accessories 84 Rear side 01 Illumination element, IP 40 02 03 Additional Information 04 • LED and built-in resistor included • Standard version: Cable length 300 mm with insulated ferrule, plug-in terminal 2.8 x 0.8 mm 10 • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) 14 • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 17 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination 18 Protection degree LED colour Operating voltage Operation current Terminal Part No. Wiring diagram 19 22 Weight 31 41 IP 40 Illumination element Single-LED red 12 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.2320 1 0.005 kg Single-LED orange 12 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.3320 1 0.005 kg Single-LED yellow 12 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.4320 1 0.005 kg Single-LED green 12 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.5320 1 0.005 kg Single-LED blue 12 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.6320 1 0.005 kg Single-LED white 12 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.9320 1 0.005 kg Single-LED red 24 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.2620 1 0.005 kg Single-LED orange 24 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.3620 1 0.005 kg Single-LED yellow 24 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.4620 1 0.005 kg Single-LED green 24 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.5620 1 0.005 kg Single-LED blue 24 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.6620 1 0.005 kg Single-LED white 24 VDC ±10 % 10 mA Plug 2.8 x 0.8 mm 84-8001.9620 1 0.005 kg 44 51 56 57 61 70 71 IP 40 82 Illumination element Single-LED red 12 VDC ±10 % 10 mA Flat ribbon cable 84-8001.2340 1 0.010 kg Single-LED orange 12 VDC ±10 % 10 mA Flat ribbon cable 84-8001.3340 1 0.010 kg Single-LED yellow 12 VDC ±10 % 10 mA Flat ribbon cable 84-8001.4340 1 0.010 kg Single-LED green 12 VDC ±10 % 10 mA Flat ribbon cable 84-8001.5340 1 0.010 kg Single-LED blue 12 VDC ±10 % 10 mA Flat ribbon cable 84-8001.6340 1 0.010 kg Single-LED white 12 VDC ±10 % 10 mA Flat ribbon cable 84-8001.9340 1 0.010 kg Single-LED red 24 VDC ±10 % 10 mA Flat ribbon cable 84-8001.2640 1 0.010 kg Single-LED orange 24 VDC ±10 % 10 mA Flat ribbon cable 84-8001.3640 1 0.010 kg Single-LED yellow 24 VDC ±10 % 10 mA Flat ribbon cable 84-8001.4640 1 0.010 kg Single-LED green 24 VDC ±10 % 10 mA Flat ribbon cable 84-8001.5640 1 0.010 kg Single-LED blue 24 VDC ±10 % 10 mA Flat ribbon cable 84-8001.6640 1 0.010 kg Single-LED white 24 VDC ±10 % 10 mA Flat ribbon cable 84-8001.9640 1 0.010 kg 84 92 95 96 97 99 ST 785 84 01 Accessories X2 + 02 03 X1 – 04 Wiring diagram 1 14 17 18 19 22 31 Illumination element bi-colour Additional Information • LED and built-in resistor included • Standard version: Cable length 300 mm with insulated ferrule, plug-in terminal 2.8 x 0.8 mm • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67). • Best illumination level will be reached with aluminium lens with spot, Part No. 84-7215.x00 and 84-7211.x00 • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 41 • Cabel connection IP 67, rear side fully sealed. The illumination element of the cable version cannot be disconnected from the actuator any longer 44 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination 51 56 57 Protection degree LED colour Operating voltage Operation current Terminal Part No. Wiring diagram 10 Weight 61 70 IP 40 71 Illumination element with bi-colour illumination Bi-colour LED red/green 24 VDC ±10 % 20 mA Plug 2.8 x 0.8 mm 84-8005.8620 1 0.005 kg Bi-colour LED yellow/green 24 VDC ±10 % 20 mA Plug 2.8 x 0.8 mm 84-8005.7620 1 0.005 kg 82 92 95 X3 + X1 – X2 + 97 99 grün 96 0V 24 V rot oder gelb 24 V Wiring diagram 1 ST 786 Illumination element with bi-colour illumination Bi-colour LED yellow/green 24 VDC ±10 % 20 mA Flat ribbon cable 84-8005.7640 2 0.011 kg Bi-colour LED red/green 24 VDC ±10 % 20 mA Flat ribbon cable 84-8005.8640 2 0.011 kg gb + 24 V bl 0V rt +24 V rot oder gelb IP 67 grün 84 Wiring diagram 2 Accessories 84 01 Switching element with illumination 02 Additional Information • LED and built-in resistor included 03 • Standard version: Cable length 300 mm with insulated ferrule, plug-in terminal 2.8 x 0.8 mm 04 • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) 10 • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 14 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination 17 Protection degree LED colour Operating voltage Operation current Contacts Terminal Part No. Wiring diagram 18 19 Weight 22 IP 40 31 Switching element with illumination Single-LED red 12 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.2320 1 0.006 kg Single-LED orange 12 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.3320 1 0.006 kg Single-LED yellow 12 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.4320 1 0.006 kg Single-LED green 12 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.5320 1 0.006 kg Single-LED blue 12 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.6320 1 0.006 kg Single-LED white 12 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.9320 1 0.006 kg Single-LED red 24 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.2620 1 0.006 kg Single-LED orange 24 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.3620 1 0.006 kg Single-LED yellow 24 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.4620 1 0.006 kg Single-LED green 24 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.5620 1 0.006 kg Single-LED blue 24 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.6620 1 0.006 kg Single-LED white 24 VDC ±10 % 10 mA 1 NO Plug 2.8 x 0.8 mm 84-8511.9620 1 0.006 kg 41 44 51 56 57 61 70 IP 40 71 Switching element with illumination Single-LED red 12 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.2340 1 0.015 kg Single-LED orange 12 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.3340 1 0.015 kg Single-LED yellow 12 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.4340 1 0.015 kg Single-LED green 12 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.5340 1 0.015 kg Single-LED blue 12 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.6340 1 0.015 kg Single-LED white 12 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.9340 1 0.015 kg Single-LED red 24 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.2640 1 0.015 kg Single-LED orange 24 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.3640 1 0.015 kg Single-LED yellow 24 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.4640 1 0.015 kg Single-LED green 24 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.5640 1 0.015 kg Single-LED blue 24 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.6640 1 0.015 kg Single-LED white 24 VDC ±10 % 10 mA 1 NO Flat ribbon cable 84-8511.9640 1 0.015 kg 82 84 92 95 96 97 99 Contacts: NO = Normally open ST 787 84 01 3 X2 + 4 X1 – Accessories 02 03 04 10 14 17 Wiring diagram 1 Switching element bi-colour Additional Information • LED and built-in resistor included 18 • Protection degree IP 67, rear side fully sealed. The switching element cannot be disconnected from the actuator any longer 19 • Best illumination level will be reached with aluminium lens with spot, Part No. 84-7215.x00 and 84-7211.x00 22 • Standard version: Cable length 300 mm with insulated ferrule 31 41 • Other options on request: Customisation of cable and connectors • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination Wiring diagram 44 Weight 24 VDC ±10 % 20 mA 1 NO Flat ribbon cable 84-8515.8640 1 0.015 kg Bi-colour LED yellow/green 24 VDC ±10 % 20 mA 1 NO Flat ribbon cable 84-8515.7640 1 0.015 kg 51 Protection degree LED colour Operating voltage Operation current Contacts Terminal Part No. 56 57 70 71 Bi-colour LED red/green Contacts: NO = Normally open gr 82 gb gn + 24 V Wiring diagram 1 95 96 97 99 ST 788 ws 0V grün 84 92 Switching element with bi-colour illumination bn + 24 V rot oder gelb 61 IP 67 Accessories 84 01 Switching element without illumination 02 Additional Information • Standard version: Cable length 300 mm with insulated ferrule, plug-in terminal 2.8 x 0.8 mm 03 • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) 04 • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 10 Protection degree Contacts Terminal Part No. Wiring diagram 14 17 Weight 18 19 Switching element without illumination IP 40 1 NO Plug 2.8 x 0.8 mm 84-8510.0020 1 22 0.005 kg 31 41 Switching element without illumination IP 40 1 NO Flat ribbon cable 84-8510.0040 1 0.010 kg 44 Contacts: NO = Normally open 51 3 56 57 4 61 Wiring diagram 1 70 Switching element PCB illuminative 71 Additional Information 82 9.3 4 92 95 12.5 2 4 5.08 1 3 84 1 3.6 12.5 10.16 • LED and mounting flange to be ordered separately 5.7 Ø8 • The customer has to decide what series resistor shall be used to the LED .8 16 96 97 Dimensions [mm] 99 ST 789 Wiring diagram Weight 3 1 0.001 kg Part No. Component layout Accessories Component layout 84 Weight 92-800.042 4 0.001 kg 01 02 Contacts Terminal Switching action Part No. B 92-851.342 03 04 10 14 17 Switching element PCB mounting illuminative 1 NO PCB Contacts: NO = Normally open Switching action: B = Momentary The component layouts you will find from page 803 3 4 1 2 Wiring diagram 1 31 Illumination element PCB 41 Additional Information 44 • The customer has to decide what series resistor shall be used to the LED • LED and mounting flange to be ordered separately .8 16 8 0. 51 4 22 5.7 19 1.6 18 x 6.35 8 0. 56 12.5 57 Dimensions [mm] 61 70 71 Terminal 82 84 92 IIlumination element PCB mounting PCB The component layouts you will find from page 803 95 96 97 99 ST 790 Accessories 84 01 Mounting flange 02 6.85 24.5 03 R 2.2 04 7.35 30 ± 0.05 4 10 7.1 20 14 R2.2 21.55 ± 0.1 17 4.9 18 Dimensions [mm] 19 Product attribute Part No. 22 Weight 31 41 Mounting flange Halo illumination (illuminated multi-color bezel) 84-960.0 0.001 kg 44 51 Mounting flange 92-960.0 Standard version 56 0.001 kg 57 Flat receptacle 61 70 Product attribute Part No. Weight 71 82 Flat receptacle 2.8 x 0.8 mm plug-in terminal 84-9420 0.001 kg 84 92 Insulation sleeve 95 Product attribute Part No. 96 Weight 97 99 Insulation sleeve for flat receptacle 2.8 mm 31-929 0.001 kg ST 791 84 01 Accessories Plug 02 Additional Information 03 • For back protection IP67 of switching elements and illumination elements. Two plugs are nessecary per element 04 10 14 Part No. 17 18 Weight 84-900 19 22 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 792 Plug 0.001 kg Accessories 84 Illumination 01 Single-LED, T1 Bi-Pin 02 03 Additional Information • The customer has to decide what series resistor shall be used to the LED 04 • Luminosity and wave length scattering caused by LED manufacturing processes may cause slight variations in the illumination 10 14 17 LED colour Forward voltage typ. Lumi. intensity Dom. wavelength Part No. Weight 18 19 Single-LED Single-LED red 2.1 VDC @ 20 mA 200 mcd 625 nm 10-2602.3202L 0.001 kg Single-LED orange 2.1 VDC @ 20 mA 220 mcd 590 nm 10-2602.3203L 0.001 kg Single-LED yellow 3.3 VDC @ 20 mA 500 mcd 570 nm 10-2602.3204L 0.001 kg Single-LED green 3.5 VDC @ 20 mA 250 mcd 525 nm 10-2602.3205L 0.001 kg Single-LED blue 3.5 VDC @ 20 mA 450 mcd 470 nm 10-2602.3206L 0.001 kg Single-LED white 3.3 VDC @ 20 mA 600 mcd x=0.29/y=0.31 nm 10-2602.3209L 0.001 kg 22 31 41 44 Bi-colour-LED, T1 Bi-Pin 51 56 Additional Information • The customer has to decide what series resistor shall be used to the LED 57 • Luminosity and wave length scattering caused by LED manufacturing processes may cause slight variations in the illumination 61 70 LED colour Forward voltage typ. Lumi. intensity Dom. wavelength Part No. 71 Weight 82 84 Bi-colour-LED Bi-colour LED red/green 2.0/3.2 VDC @ 20 mA 310/800 mcd 625/528 nm 10-2603.308AL 0.001 kg Bi-colour LED yellow/green 2.0/3.2 VDC @ 20 mA 350/750 mcd 591/528 nm 10-2603.308CL 0.001 kg 92 95 96 97 99 ST 793 84 Accessories 01 Emergency-stop and Stop pushbutton 02 Emergency-stop legend 03 04 Additional Information • Front panel thickness 3 mm max. 10 14 Dimension Mounting cut-out Marking Colour Part No. Weight 17 18 Emergency-stop legend Ø 22.5 mm 22 31 Ø 90 x 1 mm Ø 22.5 mm 41 51 56 57 61 70 yellow 704.963.5 0.011 kg yellow 704.963.6 0.011 kg ARRET D›URGENCE yellow 704.963.7 0.011 kg NOT HALT yellow 704.963.8 0.011 kg NOT AUS yellow 704.963.0 0.011 kg EMERGENCY STOP yellow 704.963.1 0.011 kg ARRET D›URGENCE yellow 704.963.2 0.011 kg NOT HALT yellow 704.963.3 0.011 kg E-stop protective shroud Additional Information 11 1.8 • Front panel thickness 1 ... 3 mm Ø22.5 • With anti-twist device Ø50.2 44 NOT AUS EMERGENCY STOP • When using a protective shroud the e-stop or stop-switch has to be turned by 180° to be mounted. See dimensional drawing • The protection shroud Part No. 84-909 is not suitable for a proper use of emergency-stop. It can obstruct a spontaneous operation of the emergency-stop switch Ø31.8 19 Ø 59 x 1 mm 1.5 26 2.5 Ø22.5 82 Ø37 Ø45 71 1 84 92 Dimensions [mm] 95 96 97 Front protection Dimension Mounting cut-out Marking Material Colour Part No. Weight Plastic yellow 84-902 0.006 kg Plastic yellow 84-902A 0.006 kg 99 ST IP 65 E-stop protective shroud Ø 50 mm Ø 22.5 mm NOT - AUS 794 Accessories 84 01 Front protection Dimension Mounting cut-out Marking Colour Part No. Weight IP 65 Ø 50 mm Ø 22.5 mm EMERGENCY STOP Plastic Material yellow 84-902B 0.006 kg NOT - HALT yellow 84-902D 0.006 kg Plastic 02 03 04 E-stop protective shroud IP 40 Ø 45 mm Ø 22.5 mm Metal yellow RAL 1003 84-909 10 0.021 kg 14 Fixing nut 17 18 Product attribute Dimension Material Colour Part No. 19 Weight 22 Fixing nut For limited-space applications Ø 28 mm Plastic black 84-905 31 0.002 kg 41 44 Fixing nut Standard delivery Ø 30 mm Plastic black 84-908 0.002 kg 51 Emergency-stop enclosure, IP 66 56 57 Additional Information 65 2.5 • Bottom grey similar RAL 7035; cover lead-sealable, yellow similar RAL 1004 61 70 25 • Openings for cable gland M16 or M20 65 57 • With mounting cut-out Ø 22.5 mm, with anti- twist device 71 82 Dimensions [mm] 84 92 Dimension Part No. Weight 95 96 65 x 65 x 57 mm Emergency-stop enclosure 84-910 97 0.099 kg 99 ST 795 84 03 Additional Information • Cover lead-sealable B H 04 L 02 Stop switch enclosure, IP 66 2.5 01 Accessories 10 14 Dimensions [mm] 17 18 19 Product attribute Dimension Material Colour Part No. Weight L 94 x B 94 x H 81 mm Plastic grey, similar RAL 7035 704.945.1 0.211 kg L 130 x B 94 x H 81 mm Plastic grey, similar RAL 7035 704.945.2 0.251 kg L 180 x B 94 x H 81 mm Plastic grey, similar RAL 7035 704.945.3 0.313 kg L 180 x B 182 x H 110 mm Plastic grey, similar RAL 7035 704.945.4 0.572 kg L 180 x B 182 x H 110 mm Plastic grey, similar RAL 7035 704.945.5 0.568 kg 22 31 Enclosure with mounting cut-out 1 x Ø 22.5 mm, with anti-twist device 41 44 Enclosure with mounting cut-out 2 x Ø 22.5 mm, with anti-twist device 51 56 57 Enclosure with mounting cut-out 3 x Ø 22.5 mm, with anti-twist device 61 70 Enclosure with mounting cut-out 4 x Ø 22.5 mm, with anti-twist device 71 82 84 Enclosure with mounting cut-out 6 x Ø 22.5 mm, with anti-twist device 92 95 96 97 99 ST 796 Accessories 84 01 PCB plug-in base 02 2.9 03 1.6 20.3 04 10 0 8.3 -0.2 15.8 14 Dimensions [mm] Dimension Pins Terminal Part No. Component layout 17 18 Weight 19 22 PCB plug-in base 20.3 x 15.8 x 8.3 mm axial 84-920 PCB 5 31 0.003 kg The component layouts you will find from page 803 41 Cable gland, IP 68 44 51 Additional Information • With traction relief 56 57 Product attribute Thread Material Colour Part No. 61 Weight 70 Cable gland Clamping range Ø 4 ... 10 mm, thread length 8 mm M16 x 1.5 Plastic grey 61-9481.6 0.007 kg Clamping range Ø 6 ... 12 mm, thread length 9 mm M20 x 1.5 Plastic grey 704.945.6 0.011 kg 71 82 84 92 95 96 97 99 ST 797 84 01 Accessories Flat receptacle 02 03 Product attribute Part No. Weight 31-946 0.001 kg Part No. Weight 31-929 0.001 kg 04 10 14 17 Flat receptacle 2.8 x 0.5 mm plug-in terminal Insulation sleeve 18 19 Product attribute 22 31 41 Insulation sleeve for flat receptacle 2.8 mm 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 798 Accessories 84 Stop request pushbutton 01 Housing pole mounting 35 mm 02 Additional Information 03 31 04 50 • Please note: The cut-out of the pole must read min. 22 mm and needs to be aligned with the switch 10 • Screws are not contained in the scope of supply Ø35 Ø 22.5 Ø 4.8 111 14 38.7 17 98 ±0.4 18 Dimensions [mm] 19 22 Material Colour Part No. Weight 31 41 Housing pole mounting 35 mm Plastic 84-9500.4 yellow RAL 1023 44 0.035 kg traffic blue RAL 5017 84-9500.6A 0.035 kg grey RAL 7016 84-9500.8 0.035 kg 51 56 Housing pole mounting 38 mm Additional Information 57 31 61 42.5 • Please note: The cut-out of the pole must read min. 22 mm and needs to be aligned with the switch 70 • Screws are not contained in the scope of supply 110.5 Ø38 82 Ø4.8 98 ±0.4 71 38 Ø 22.5 84 Dimensions [mm] 92 95 Material Colour Plastic Part No. Weight 96 97 Housing pole mounting 38 mm yellow RAL 1023 84-9600.4 0.030 kg grey RAL 7016 84-9600.8 0.030 kg 99 ST 799 84 03 Additional Information • For housing, pole mounting 35 mm dia. 04 98 ±0.4 Ø 30 02 Adaptor reducing to 30 mm Ø 4.8 01 Accessories 20.5 111 10 14 Dimensions [mm] 17 18 19 Material Colour Part No. Weight 22 31 Adaptor reducing to 30 mm Plastic 41 44 51 yellow RAL 1023 84-9700.4 0.024 kg grey RAL 7016 84-9700.8 0.024 kg Adaptor reducing to 25 mm Additional Information 57 Ø 4.8 56 98 ±0.4 Ø25 • For housing, pole mounting 35 mm dia. 20.5 111 61 70 Dimensions [mm] 71 82 Material Colour Part No. Weight 84 92 95 Plastic 96 97 99 ST 800 Adaptor reducing to 25 mm yellow RAL 1023 84-9300.4 0.008 kg grey RAL 7016 84-9300.8 0.008 kg Accessories 84 01 Housing wall mounting Additional Information 02 31 03 31 • Please note: The cut-out of the pole must read min. 22 mm and needs to be aligned with the switch 110 • Screws are not contained in the scope of supply 36 04 Ø 22.5 Ø 4.8 10 98 ±0.4 14 Dimensions [mm] 17 18 Material Colour Part No. Weight 19 22 Plastic Housing wall mounting yellow RAL 1023 84-9800.4 0.024 kg grey RAL 7016 84-9800.8 0.024 kg 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 801 84 Accessories 01 Mounting 02 Mounting tool 03 04 10 Product attribute 14 17 Part No. Weight 84-996 0.014 kg 84-997 0.027 kg Mounting tool for tightening or loosening the fixing nut, for emergency-stop and stop-switch 18 19 Mounting tool for tightening or loosening of fixing nut, for Indicator and Pushbutton 22 31 41 44 Dismantling tool Additional Information • For actuator dismantling of switching element, illumination element and mounting flange 51 56 Part No. Weight 57 61 84-918 70 71 82 84 92 95 96 97 99 ST 802 Combined dismantling tool 0.008 kg Drawings 84 01 Drawings 02 23 24 21 22 X2+ X1- 12 11 Cable 11 white 12 X1_ X2+ 24 22 23 21 green grey 11 12 X1_ X2+ white green 11 12 24 22 23 21 white green 11 12 white Terminals brown 1 NC + 1 NO 2 NC Illumination yellow pink 11 / 12 + 23 / 24 11 / 12 + 21 / 22 _ X1 / X2+ 12 11 03 X2+ X1- 04 22 21 24 23 Terminals brown 1 NC Illumination yellow 10 11 / 12 _ X1 / X2+ 14 Terminals brown 1 NC + 1 NO 2 NC yellow 1 NC brown 11 / 12 + 23 / 24 11 / 12 + 21 / 22 17 Terminals 18 11 / 12 19 Component layout 1 Component layout 2 Single-LED Bi-colour-LED Drilling plan (element side) Drilling plan (element side) A Fixing holes for mounting flange (92-960.0) B Holes for LED C Holes for contact pins Pad max. Ø 2.5 mm Through-connection recommended A Fixing holes for mounting flange (92-960.0) B Holes for Bi-colour LED: BA1 (green) + BA2 (yellow or red) = Anodes, BK = Cathode C Holes for contact pins Pad max. Ø 2.5 mm Through-connection recommended 22 31 41 44 51 A A C B C Ø 2.0 5.08 C 10.16 C 56 BA2 15.24 5.08 10.16 15.24 B Ø 1.3 A C C C C BA1 BK A Ø 1.0 10.16 Ø2.0 57 Ø1.3 Ø1.0 61 10.16 12.7 12.7 15.24 15.24 70 71 82 Hyper mini Top-LED 84 92 Drilling plan (element side) A Fixing holes for mounting flange (84-960.0) 95 2.8 Ø 20.8 A 96 10.61 0.8 10.61 1 97 99 A Pads Ø2.0 10.61 ST 10.61 Component layout 3 803 84 Drawings 01 Single-LED Bi-colour-LED 02 Drilling plan (element side) Drilling plan (element side) 03 A Fixing holes for mounting flange (92-960.0) B Holes for LED C Holes for centering pins A Fixing holes for mounting flange (92-960.0) B Holes for Bi-colour LED: BA1 (green) + BA2 (yellow or red) = Anodes, BC = Cathode C Holes for centering pins 04 A Ø 1.0 A 17 18 6.35 10.16 15.24 15.24 22 41 Hyper mini Top-LED Drilling plan (element side) A Fixing holes for mounting flange (84-960.0) 44 2.8 Ø 20.8 51 A 10.61 10.61 1 56 57 A Pads 10.61 Ø 2.0 61 Component layout 4 %SJMMJOHQMBO FMFNFOUTJEF 71  Š 84 97  r  Y ± Š 1PTJUJPOJOHIPMF  Š 99 ST    Š 92 96 1VTICVUUPO BOUJUXJTUEFWJDF  Š 1VTICVUUPO DFOUSF  Š 82 95 10.61  70 0.8  Š Component layout 5 804 Y± 1JOTGPSDPOUBDU-&% 5ISPVHIDPOOFDUJPO SFDPNNFOEFE Ø1.0 BC 10.16 19 31 BA1 C A 6.35 Ø2.0 C 6.35 B 15.24 Ø 2.0 C 10.16 BA2 C 6.35 10.16 14 15.24 10 A B Technical data 84 01 Emergency-stop Switching system The double-break switching system can be supplied for the following switching functions: 1 Normally closed, 2 Normally closed, 1 Normally closed + 1 Normally open. The Normally closed contacts have forced opening according to EN IEC 60947-5-1 Material Connection cable Polyvinylchloride (PVC), operating temperature up to +65 °C Mushroom-head cap Polybutylenterephthalate (PBT), as per UL 94 V0 (red items) Actuator housing Polyamide (PA 66), as per UL 94 V0, Flat ribbon cable-cover Polyamide (PA 6.6), as per UL 94 V0 Rated Operational Voltage Ue 250 VAC, as per EN IEC 60947-1 02 03 Rated Insulation Voltage Ui 250 V, as per EN IEC 60947-1 04 Rated Impulse Withstand Voltage Uimp 2.5 kV, as per EN IEC 60947-1 10 Contact resistance New state ≤ 50 mΩ, as per DIN IEC 60512-2-3 14 Isolation resistance > 1011 Ω between the opend contats at 500 VDC, as per DIN IEC 60512-3-1 17 18 Electrical life ≥ 50 000 cycles of operations (inductive cosφ 0.4), as per EN IEC 60947-5-1 Voltage Current 120 VAC 3A 240 VAC 1.5 A 19 22 125 VDC 250 VDC 0.55 A 0.27 A Material of contact Silver alloy gold plated Reduced load ≥ 50 000 cycles of operations (resistive) Mechanical characteristics Voltage Current Front panel thickness Standard 1 … 4 mm with EMERGENCY-STOP protective shroud Part No. 84-902 1 … 3 mm Conventional free air thermal current Ith 5 A, as per EN IEC 60947-5-1 the maximum current in continuous operation and at ambient temperature must not exceed the quoted maximum values. Mounting cut-outs Ø 22.5 mm as per EN IEC 60947-5-1 with anti-twist device Switch rating Switch rating AC with silver contact (gold plated), service category AC-15, as per EN IEC 60947-5-1 Terminals Soldering terminals 2.8 x 0.5 mm (solderable), CuSn6 tin-plated Flat ribbon cable 2-, 4-, or 6-poles 0.35 mm² (AWG 22) Voltage Current 1 VAC/DC 100 mA 120 VAC 3A 31 41 42 VAC/DC 200 mA 44 51 Switch rating DC for silver contact (gold plated), service category DC-13, as per EN IEC 60947-5-1 Actuating force 22 N ±4 N Voltage (VDC) 12 VDC 24 VDC 48 VDC 60 VDC 125 VDC 250 VDC Current Plug 5 A 4A 2.1 A 1.7 A 0.55 A 0.27 A Current Cable 3 A 3A 2.1 A 1.7 A 0.55 A 0.27 A Mechanical lifetime ≥ 50 000 cycles of operations Electrical characteristics Standards The devices comply with: EN IEC 60947-5-1, EN IEC 60947-5-5 (EMERGENCY-STOP), DIN EN ISO 13850, EN IEC 60204 Illumination LED red with pole reversal, constant current source Operation Voltage 5 VDC … 30 VDC Current consumption 9.7 mA … 12.4 mA 70 71 82 84 Recommended minimum operational data Silver contacts (gold plated) Voltage Current 57 61 240 VAC 1.5 A Tightening torque Fixing nut 80 Ncm Actuating travel approx. 4 mm to release the internal operation part 56 92 1 VAC/DC 1 mA 95 Electric strength 500 VAC, 50 Hz, 1 min, as per DIN IEC 60512-2 96 Rated conditional short-circuit current 1000 A, type of short-circuit unit 6 A gG, as per EN IEC 60947-5-1 97 99 Protection class Class II, as per EN IEC 60947-5 ST 805 84 Technical data 01 02 Overvoltage category II, as per EN IEC 60947-1 03 Degree of pollution 3, as per EN IEC 60947-1 Climate resistance Damp heat, cyclic 96 hours, +25 °C/97 %, +55 °C/93 % relative humidity, as per EN IEC 60068-2-30 Environmental conditions Damp heat, steady 56 days, +40 °C/93 % relative humidity, as per EN IEC 60068-2-78 Storage temperature -25 °C … +80 °C Dry heat 96 hours, +70 °C, as per EN IEC 60068-2-2 17 Operating temperature -25 °C … +65 °C Low temperature 96 hours, -40 °C, as per EN IEC 60068-2-1 18 Front protection IP 65, as per EN IEC 60529 Saline mist 96 Stunden, +35 °C in chemical solution NaCl, as per EN IEC 60068-2-11 04 10 14 19 22 31 41 44 Shock resistance (semi-sinusoidal) max. 150 m/s², pulse width 11 ms, 3-axis, as per EN IEC 60068-2-27 Vibration resistance (sinusoidal) max. 50 m/s² at 10 Hz … 500 Hz, 10 cycles, 3-axis, as per EN IEC 60068-2-6 Approvals Approbations CB (IEC 60947) UL NFF Declaration of conformity CE 51 56 57 61 Switching element illuminated pushbutton Switching system Short-travel switching system with 2 independent contact points and tactile operation. Guarantees reliable switching even of very light loads. Fitted with 1 normally open contact. 70 71 82 84 92 95 Material Connection cable Polyvinylchloride (PVC), short-time heat-resistant up to 105 °C Material of contact Silver alloy gold plated Switching element Thermoplastic polyester (PET, PBT), as per UL 94 V0 and Polyacetale (POM), as per UL 94 HB 96 Mechanical characteristics 97 Terminals Plug-in terminals 2.8 x 0.8 mm (solderable) Flat ribbon cable 0.5 mm² PCB terminal 99 ST Actuating force 4.0 N ±0.2 N (measured at the lens) 806 Actuating travel ~0.5 mm Rebound time ≤ 1 ms Resistance to heat of soldering 260 °C, 5 s (PCB assembly) 350 °C, 10 s (when using a soldering iron) as per EN IEC 60068-2-20 Mechanical lifetime ≥ 1 million cycles of operations Electrical characteristics Illumination Single-Chip LED, green, orange, red, yellow, white and blue Operation Voltage 12 VDC Current consumption 10 mA 24 VDC 10 mA Contact resistance Starting value (initial) ≤ 100 mΩ, as per DIN IEC 60512-2 Isolation resistance ≥ 1 GΩ between all terminals at 100 VDC, as per DIN IEC 60512-3-1 Technical data 84 01 Environmental conditions Electrical life as per EN IEC 60512-5 5 million cycles of operation 5 million cycles of operation 2 million cycles of operation 2 million cycles of operation 300 000 cycles of operation 250 000 cycles of operation 1 million cycles of operation 1 million cycles of operation 1 million cycles of operation 5 million cycles of operation 1.5 million cycles of operation 100 000 cycles of operation 500 000 cycles of operation 300 000 cycles of operation 100 000 cycles of operation 24 VAC, 50 mA at 480 Ω 24 VAC, 100 mA at 240 Ω 42 VAC, 50 mA at 840 Ω 42 VAC, 100 mA at 420 Ω 42 VAC, 100 mA at cosφ 0.4 42 VAC, 200 mA at cosφ 0.395 12 VDC, 250 mA at 48 Ω 24 VDC, 50 mA at 480 Ω 24 VDC, 100 mA at 240 Ω 42 VDC, 25 mA at 1680 Ω 42 VDC, 50 mA at 840 Ω 42 VDC, 100 mA at 420 Ω 24 VDC, 200 mA at L/R = 30 ms 42 VDC, 100 mA at L/R = 30 ms 42 VDC, 200 mA at L/R = 30 ms Switch rating Voltage 50 mVAC/DC … 42 VAC/DC Current 10 uA … 100 mA Power max. 2 W 02 Storage temperature -40 °C … +85 °C 03 Operating temperature -25 °C … +70 °C 04 Protection degree Back protection: IP 40, standard version IP 67, fully sealed version, with mounted actuator only. 10 14 17 Shock resistance (semi-sinusoidal) max. 100 m/s², pulse width 11 ms, 3-axis, as per EN IEC 60068-2-27 18 19 Vibration resistance (sinusoidal) max. 50 m/s² at 10 Hz … 500 Hz, 10 cycles, 3-axis, as per EN IEC 60068-2-6 22 31 Electric strength 500 VAC, 50 Hz, 1 min, as per DIN IEC 60512-2 41 44 Actuator Material Environmental conditions Lens Polycarbonate (PC), as per UL 94 V2 or Aluminium anodised Storage temperature -40 °C … +85 °C Actuator housing Polyetherimid (PEI), as per UL 94 V0 or Aluminium anodised Operating temperature -25 °C … +70 °C Mechanical characteristics Front protection IP 67 and IP40, as per EN IEC 60529 Mounting cut-outs Ø 22.5 mm and Ø 30.5 mm Tightening torque Fixing nut max. 80 Ncm Damp heat, state 56 days, +40 °C/93 % relative humidity, as per EN IEC 60068-2-78 Actuating travel Total switching travel 1.2 mm Rapid change of temperature 100 cycles, -40 °C … +80 °C, as per EN IEC 60068-2-14 Mechanical lifetime ≥ 1 million cycles of operations Approvals Electrostatic breakdown value Plastic case ≥ 15 kV Aluminium case ≥ 5 kV as per IEC 61000-4-2, mounted in plastic front panel 56 57 61 70 Climate resistance Damp heat, cyclic 96 hours, +25 °C/97 %, +55 °C/93 % relative humidity, as per EN IEC 60068-2-30 Actuating force 4.0 N ±0.2 N (measured at the lens) Electrical characteristics 51 71 82 84 92 95 96 97 Approbations EBC NFF 99 Declaration of conformity CE TSI/PRM ST 807 84 01 02 03 04 10 Technical data Lens plastic with symbols Chemical and mechanical tests 1. Wipe resistance according to EN 61058-1 section 8.9 (Petrol/gasoline, distilled water, diluted alcohol) 2. Graffiti-Killer Test 3. Railway cleaning agents (Walo) 4. Damp/dry heat durability 5. UV test according to EN 60068-2-5 / 56 days 6. Mechanical life time 2 Mio. Operations (abrasive test) 14 17 EAO reserves the right to alter specifications without further notice. 18 19 22 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST 808 Application guidelines 84 01 Suppressor circuits When switching inductive loads such as relays, DC motors, and DC solenoids, it is always important to absorb surges (e. g. with a diode) to protect the contacts. When these inductive loads are switched off, a counter emf can severely damage switch contacts and greatly shorten lifetime. Fig. 1 shows an inductive load with a free-wheeling diode connected in parallel. This free-wheeling diode provides a path for the inductor current to flow when the current is interrupted by the switch. Without this free-wheeling diode, the voltage across the coil will be limited only by dielectric breakdown voltages of the circuit or parasitic elements of the coil. This voltage can be kilovolts in amplitude even when nominal circuit voltages are low (e. g. 12 VDC) see Fig. 2. The free-wheeling diode should be chosen so that the reverse breakdown voltage is greater than the voltage driving the inductive load. The DC blocking voltage (VR) of the free-wheeling diode can be found in the datasheet of a diode. The forward current should be equal or greater than the maximum current flowing through the load. To get an efficient protection, the free-wheeling diode must be connected as close as possible to the inductive load! ON Free-wheeling diode Inductive load 10 18 19 22 OFF 31 0 + _ 04 17 Switch VDC 03 14 Counter EMF over load without free-wheeling diode Fig. 2 Switching with inductive load Fig. 1 02 Several hundred to several thousend volts 41 di __ e = L dt 44 51 Arrangement mounting flange for switching- and illumination element, PCB mounting 56 57 25...30 61 max. 60 70 71 82 max. 60 84 25...30 The arrangement of the mounting flanges and their number is determined by the size of the front panel or PCB. To ensure uniform, tactile switching, we recommend a layout of the flanges as per adjacent sketch. For large PCBs with several switching elements we recommend the following procedure: 1. Fit the actuator to the front panel. 2. Clip the mounting flange to the rear of the intended actuator. 3. Screw the PCB with the components soldered to it to the assembled mounting flange. 92 Dismantling mounting flange The tool Part No. 84-998 must be used for removing the mounting flange from the actuator. Before removing the flange, the PCB fixing srews must be loosened. 95 96 97 99 ST This arrangement applies to PCBs 1.6 mm thick. 809 84 01 02 03 04 10 14 17 18 19 22 31 41 44 51 56 57 61 70 71 82 84 92 95 96 97 99 ST Index Index from Part No. Part No. Page 10-2602.3202L....... 793 10-2602.3203L....... 793 10-2602.3204L....... 793 10-2602.3205L....... 793 10-2602.3206L....... 793 10-2602.3209L....... 793 10-2603.308AL....... 793 10-2603.308CL....... 793 31-929.................... 791 31-929.................... 798 31-946.................... 798 61-9453.0............... 784 61-9481.6............... 797 61-9707.7............... 778 61-9980.0............... 783 704.945.1............... 796 704.945.2............... 796 704.945.3............... 796 704.945.4............... 796 704.945.5............... 796 704.945.6............... 797 704.963.0............... 794 704.963.1............... 794 704.963.2............... 794 704.963.3............... 794 704.963.5............... 794 704.963.6............... 794 704.963.7............... 794 704.963.8............... 794 704.964.8............... 784 704.968.0............... 784 704.968.1............... 784 84-0080.7............... 772 84-0090.7............... 768 84-0090.7............... 769 84-0100.0............... 758 84-0100.0............... 759 84-0200.7............... 758 84-0200.7............... 759 84-1081.7............... 773 84-1091.7............... 770 84-1091.7............... 771 84-1101.0............... 760 84-1101.0............... 762 84-1101.0............... 765 84-1101.0............... 767 84-1201.0............... 760 84-1201.0............... 762 84-1201.0............... 765 84-1201.0............... 767 84-1201.2............... 760 84-1201.2............... 762 84-1201.2............... 765 84-1201.2............... 767 84-1201.4............... 761 84-1201.4............... 762 84-1201.4............... 765 84-1201.4............... 767 84-1201.5............... 761 84-1201.5............... 762 84-1201.5............... 765 84-1201.5............... 767 84-1201.6............... 761 84-1201.6............... 762 84-1201.6............... 765 84-1201.6............... 767 84-1201.7............... 761 84-1201.7............... 762 84-1201.7............... 765 84-1201.7............... 767 84-1221.7............... 760 84-1221.7............... 762 84-1221.7............... 764 84-1221.7............... 766 84-2101.0............... 760 84-2101.0............... 762 84-2101.0............... 765 810 Part No. Page 84-2101.0............... 767 84-3100.0............... 758 84-3100.0............... 759 84-5020.0020......... 775 84-5020.0040......... 774 84-5021.2B20......... 775 84-5021.2B40......... 774 84-5030.0020......... 775 84-5030.0040......... 774 84-5031.2B20......... 775 84-5031.2B40......... 774 84-5040.0020......... 775 84-5040.0040......... 774 84-5041.2B20......... 775 84-5041.2B40......... 774 84-5120.0020......... 775 84-5120.0040......... 774 84-5121.2B20......... 775 84-5121.2B40......... 774 84-5130.0020......... 775 84-5130.0040......... 774 84-5131.2B20......... 775 84-5131.2B40......... 774 84-5140.0020......... 775 84-5140.0040......... 774 84-5141.2B20......... 775 84-5141.2B40......... 774 84-6820.0020......... 777 84-6820.0040......... 776 84-6821.2B20......... 777 84-6821.2B40......... 776 84-6830.0020......... 777 84-6830.0040......... 776 84-6831.2B20......... 777 84-6831.2B40......... 776 84-6840.0020......... 777 84-6840.0040......... 776 84-6841.2B20......... 777 84-6841.2B40......... 776 84-7111.200........... 778 84-7111.201........... 779 84-7111.202........... 779 84-7111.203........... 779 84-7111.300........... 778 84-7111.301........... 779 84-7111.400........... 778 84-7111.401........... 779 84-7111.500........... 778 84-7111.501........... 779 84-7111.502........... 779 84-7111.503........... 779 84-7111.600........... 778 84-7111.601........... 779 84-7111.602........... 779 84-7111.603........... 779 84-7111.700........... 778 84-7111.701........... 779 84-7111.702........... 779 84-7111.703........... 779 84-7114.600A......... 783 84-7115.200........... 778 84-7115.300........... 778 84-7115.400........... 778 84-7115.500........... 778 84-7115.600........... 778 84-7115.700........... 778 84-7121.000........... 778 84-7121.800........... 778 84-7124.000A......... 783 84-7124.200A......... 783 84-7124.400A......... 783 84-7124.500A......... 783 84-7124.600A......... 783 84-7125.000........... 778 84-7125.800........... 778 84-7201.000........... 779 84-7201.200........... 779 Part No. Page 84-7201.400........... 780 84-7201.500........... 780 84-7201.600........... 780 84-7201.800........... 780 84-7202.000........... 780 84-7202.000A......... 780 84-7202.200........... 780 84-7202.200A......... 780 84-7202.400........... 780 84-7202.400A......... 780 84-7202.500........... 780 84-7202.500B......... 780 84-7202.600........... 780 84-7202.600A......... 780 84-7202.800........... 780 84-7202.800A......... 780 84-7205.000........... 780 84-7205.000A......... 780 84-7205.200........... 780 84-7205.200A......... 780 84-7205.400........... 780 84-7205.400A......... 780 84-7205.500........... 780 84-7205.500A......... 780 84-7205.600........... 780 84-7205.600A......... 780 84-7205.800........... 780 84-7205.800A......... 780 84-7205.804A......... 781 84-7205.805A......... 781 84-7205.806A......... 781 84-7205.808A......... 781 84-7211.000........... 782 84-7211.200........... 782 84-7211.400........... 782 84-7211.500........... 782 84-7211.600........... 782 84-7211.800........... 782 84-7215.000........... 782 84-7215.200........... 782 84-7215.400........... 782 84-7215.500........... 782 84-7215.600........... 782 84-7215.800........... 782 84-8001.2320......... 785 84-8001.2340......... 785 84-8001.2620......... 785 84-8001.2640......... 785 84-8001.3320......... 785 84-8001.3340......... 785 84-8001.3620......... 785 84-8001.3640......... 785 84-8001.4320......... 785 84-8001.4340......... 785 84-8001.4620......... 785 84-8001.4640......... 785 84-8001.5320......... 785 84-8001.5340......... 785 84-8001.5620......... 785 84-8001.5640......... 785 84-8001.6320......... 785 84-8001.6340......... 785 84-8001.6620......... 785 84-8001.6640......... 785 84-8001.9320......... 785 84-8001.9340......... 785 84-8001.9620......... 785 84-8001.9640......... 785 84-8005.7620......... 786 84-8005.7640......... 786 84-8005.8620......... 786 84-8005.8640......... 786 84-8510.0020......... 789 84-8510.0040......... 789 84-8511.2320......... 787 84-8511.2340......... 787 84-8511.2620......... 787 Part No. Page 84-8511.2640......... 787 84-8511.3320......... 787 84-8511.3340......... 787 84-8511.3620......... 787 84-8511.3640......... 787 84-8511.4320......... 787 84-8511.4340......... 787 84-8511.4620......... 787 84-8511.4640......... 787 84-8511.5320......... 787 84-8511.5340......... 787 84-8511.5620......... 787 84-8511.5640......... 787 84-8511.6320......... 787 84-8511.6340......... 787 84-8511.6620......... 787 84-8511.6640......... 787 84-8511.9320......... 787 84-8511.9340......... 787 84-8511.9620......... 787 84-8511.9640......... 787 84-8515.7640......... 788 84-8515.8640......... 788 84-900.................... 792 84-902.................... 794 84-902A.................. 794 84-902B.................. 795 84-902D.................. 795 84-905.................... 795 84-908.................... 795 84-909.................... 795 84-910.................... 795 84-9103.7............... 783 84-918.................... 802 84-920.................... 797 84-9300.4............... 800 84-9300.8............... 800 84-9420.................. 791 84-9500.4............... 799 84-9500.6A............. 799 84-9500.8............... 799 84-960.0................. 791 84-9600.4............... 799 84-9600.8............... 799 84-9700.4............... 800 84-9700.8............... 800 84-9800.4............... 801 84-9800.8............... 801 84-996.................... 802 84-997.................... 802 92-800.042............. 790 92-851.342............. 790 92-960.0................. 791
84-5140.0020 价格&库存
很抱歉,暂时无法提供与“84-5140.0020”相匹配的价格&库存,您可以联系我们找货
