EUS-704.02-1175
EUS-704.02-1175
    EAO
    * (704-02-1175) PB RND W/GREEN L
EUS-704.02-1175 数据手册
Series 04 22.5mm 30.5mm IP65 10A 600VAC Choose one component from each of the colored sections to assemble a complete switch. INDICATOR PUSHBUTTON E-STOP MUSHROOM KEYLOCK Product Profile SELECTOR BUZZER Indicator The Series 04 is a high quality switch range that includes pushbuttons, indicators, selectors, mushroom headed switches, key switches, and Emergency-stops. Options include self cleaning, slow-make and snap-action switching elements. Technical drawings see pages 18-21 • IP65 Protection • Switch Rating: Maximum Voltage, 600VAC Maximum Thermal Current, Ith = 10A 230VAC/6A, 24VDC/10A • Raised Mounting into 22.5mm cut out • Flush Mounting into 30.5mm cut out • Illumination using Ba9s (T-31/4 bayonet base) Lamps or LED’s • All standard lenses are transparent with translucent diffuser • Screw terminal or plug-in connections Indicator, round, full face, 22.5mm mounting Color Part No. Indicator, flush mount, aluminum bezel, 30.5mm mounting Color Part No. Red 704.000.2 Red 704.006.218 Yellow 704.000.4 Yellow 704.006.418 Green 704.000.5 Green 704.006.518 Blue 704.000.6 Blue 704.006.618 Clear 704.000.7 Clear 704.006.718 For complete switch also order For complete switch also order Non illuminated raised pushbutton, aluminum bezel, 22.5mm mounting Non illuminated flush mount pushbutton, aluminum bezel, 30.5mm mounting Non-illuminated pushbutton Non illuminated raised pushbutton, gray plastic bezel, 22.5mm mounting Part Ordering System 704.02 - ( ) Pushbutton Action Lens/Cap Style 1-Momentary 2-Momentary 3-Momentary 4-Momentary 5-Maintained 6-Maintained 7-Maintained 8-Maintained Standard-plastic Standard-metal Extended-plastic Mushroom-plastic Standard-plastic Standard-metal Extended-plastic Mushroom-plastic For complete switch also order www.eaoswitch.com 10 ( ) ( Front Ring Style A 0-Standard 1-Standard 2-Sealed 3-Sealed 4-Standard 6-Standard 7-Extended 9-Standard * Only available in standard plastic Material Black plastic Anodized Al Ni plated brass Silicone cover Anodized Al Silicon cover Chrome plastic Gray plastic Gray plastic Steel ) ( ) Color Diffuser Type Lens/Cap Color 0-Black 1-No diffuser (Mushroom or opaque lens) 7-Clear 9-White 0-Black 2-Red 3-Orange* 4-Yellow 5-Green 6-Blue** 7-White *** 8-Aluminum** 9-Steel** ** Not available with mushroom cap *** Combination of clear lens and white diffuser EAO Switch Condensed Catalog 100 Part No., Momentary Part No., Maintained Red 704.012.218 704.042.218 Yellow 704.012.418 704.042.418 Green 704.012.518 704.042.518 Blue 704.012.618 704.042.618 Clear 704.012.718 704.042.718 Black 704.012.018 704.042.218 For complete switch also order A Series 04 22.5mm 30.5mm IP65 10A 600VAC A Choose one component from each of the colored sections to assemble a complete switch. For other options or further information please contact EAO Switch directly. BLOCK LED ACCESSORIES Illuminated pushbutton Illuminated raised pushbutton, gray plastic bezel, 22.5mm mounting Part Ordering System 704.01 - ( Illuminated raised pushbutton, aluminum bezel, 22.5mm mounting ) Pushbutton Action Lens Style Termination Style 1-Momentary 2-Momentary 3-Momentary 4-Momentary 5-Maintained 6-Maintained 7-Maintained 8-Maintained 9-Momentary 10-Momentary 11-Maintained 12-Maintained Standard Standard Extended Extended Standard Standard Extended Extended Mushroom Mushroom Mushroom Mushroom Screw 0.250” Q.C. Screw 0.250” Q.C. Screw 0.250” Q.C. Screw 0.250” Q.C. Screw 0.250” Q.C. Screw 0.250” Q.C. ( ) ( Front Ring Material 0-Standard 1-Standard 2-Sealed 4-Standard 6-Standard 7-Extended 9-Standard A ( ) Diffuser* Type Black plastic Anodized Al Ni plated brass Silicon cover Anodized Al Silicon cover Chrome plastic Gray plastic Gray plastic Steel 3-Sealed For complete switch also order ) Illuminated flush mount pushbutton, aluminum bezel, 30.5mm mounting Color Lens Color 7-Clear 9-White 2-Transparent red 3-Transparent orange 4-Transparent yellow 5-Transparent green 6-Transparent blue 7-White (uses clear lens/white diffuser) Part No., Momentary Part No., Maintained Red 704.032.218 704.062.218 Yellow 704.032.418 704.062.418 Green 704.032.518 704.062.518 Blue 704.032.618 704.062.618 Clear 704.032.718 704.062.718 For complete switch also order *White translucent for incandescent lamps and clear knurled for neon A Illuminated pushbutton Illuminated raised pushbutton, gray plastic bezel, 22.5mm mounting Part Ordering System 704.03 - ( Pushbutton Action Lighted or Unlighted Film Insert 0-Momentary 1-Momentary 2-Momentary 3-Momentary 4-Maintained 5-Maintained 6-Maintained 7-Maintained Lighted Lighted Unlighted Unlighted Lighted Lighted Unlighted Unlighted With Without With Without With Without With Without For complete switch also order ) Illuminated raised pushbutton, aluminum bezel, 22.5mm mounting ( ) ( Lamp Holder ( Bezel Color 0-No lamp holder 1-Lamp holder screw terminals 2-Lamp holder 0.250" Q.C. terminals A ) 0-Black 4-Chrome 6-Light gray ) Lens Color 0-Black 2-Red 3-Orange 4-Yellow 5-Green 6-Blue 7-White* *Combination of clear lens and white diffuser EAO Switch Condensed Catalog 100 11 Series 04 22.5mm 30.5mm IP65 10A 600VAC Choose one component from each of the colored sections to assemble a complete switch. INDICATOR PUSHBUTTON E-STOP MUSHROOM KEYLOCK SELECTOR BUZZER Emergency-stop switch Emergency-stop, twist release, 37mm diameter, foolproof to EN 60947-5-1 and EN 418, use slow-make switching elements Emergency-stop, key release, 37mm diameter, foolproof to EN 60947-5-1 and EN 418, use slow-make switching elements Part No. Part No. 704.064.2 704.066.2 A Mushroom headed pushbutton, plastic bezel and aluminum bezel, 22.5mm mounting, function momentary Front Ring Markings 704.074.2 Gray plastic Directional arrows 704.075.2 Anodized aluminum Directional arrows A For complete switch also order Keylock switch Mushroom headed pushbutton Color Part No. For emergency stop applications, a maximum of 2 switching elements can be used For emergency stop applications, a maximum of 2 switching elements can be used For complete switch also order Emergency-stop, twist release, mushroom head, 40mm diameter, use slow-make switching elements Keylock switch 2 position, raised, 22.5mm mounting A 1 B Mom 42° Drawing Part No. Action 2 C B Maint 90° Key rem. Drawing Part No. A 3 Keylock switch 2 position, flush mount, 30.5mm mounting B Mom 42° Action 4 C B Maint 90° Key rem. Part No., Plastic Part No., Aluminum Red 704.070.2 704.071.2 1 704.123.0 Momentary A 3 704.123.018 Momentary A Yellow 704.070.4 704.071.4 2 704.121.0 Maintained C 4 704.121.018 Maintained C Green 704.070.5 704.071.5 Black 704.070.0 704.071.0 Maintained versions available as well For complete switch also order www.eaoswitch.com 12 A For complete switch also order A EAO Switch Condensed Catalog 100 For complete switch also order A Series 04 22.5mm 30.5mm IP65 10A 600VAC A Choose one component from each of the colored sections to assemble a complete switch. For other options or further information please contact EAO Switch directly. BLOCK Keylock switch A 5 C A B 6 C Mom 42° Part No. ACCESSORIES Selector switch Keylock switch 3 position, raised, 22.5mm mounting Drawing LED B Maint 90° Action Key rem. Keylock switch 3 position, flush mount, 30.5mm mounting Drawing A 7 C B Maint/Mom 42° Part No. Action Key rem. Drawing Part No. A 8 Selector switch short lever 2 position, raised, 22.5mm mounting 9 B Mom 42° Action C B Maint 90° Bezel 5 704.115.0 Momentary/Momentary A 7 704.115.018 Momentary/Momentary A 8 704.412.0 Momentary Gray plastic 6 704.114.0 A 7 704.114.018 Maintained/Maintained A 8 704.413.0 Momentary Aluminum Maintained/Maintained A For complete switch also order For complete switch also order A 9 704.410.0 Maintained Gray plastic 9 704.411.0 Maintained Aluminum For complete switch also order A Selector switch Selector switch short lever 2 position, flush mount, 30.5mm mounting Drawing Part No. A A 10 B Mom 42° Action 11 C B Maint 90° Bezel 12 Selector switch short lever 3 position, raised, 22.5mm mounting Drawing Part No. C A B Maint/Mom 42° Action Bezel 13 Selector switch short lever 3 position, flush mount, 30.5mm mounting Drawing Part No. C B Maint/Mom 42° Action Bezel 10 704.413.018 Momentary Aluminum 12 704.404.0 Momentary/Momentary Gray plastic 13 704.405.018 Momentary Aluminum 11 704.411.018 Maintained Aluminum 12 704.405.0 Momentary/Momentary Aluminum 13 704.403.018 Maintained Aluminum 12 704.402.0 Maintained/Maintained Gray plastic 12 704.403.0 Maintained/Maintained Aluminum For complete switch also order A For complete switch also order A EAO Switch Condensed Catalog 100 For complete switch also order A 13 Series 04 22.5mm 30.5mm IP65 10A 600VAC Choose one component from each of the colored sections to assemble a complete switch. INDICATOR PUSHBUTTON E-STOP MUSHROOM KEYLOCK SELECTOR BUZZER Selector switch Drawing A 14 Selector switch long lever 2 position, raised, 22.5mm mounting 15 B Mom 42° Part No. Action C B Maint 90° Bezel Selector switch long lever 2 position, flush mount, 30.5mm mounting Drawing Part No. A 16 17 B Mom 42° Action C B Maint 90° Bezel A Selector switch long lever 3 position, raised, 22.5mm mounting Drawing Part No. 18 C B Maint/Mom 42° Action Bezel 14 704.102.0 Momentary Gray plastic 16 704.103.018 Momentary Aluminum 18 704.094.0 Momentary Gray plastic 14 704.103.0 Momentary Aluminum 17 704.101.018 Maintained Aluminum 18 704.095.0 Momentary Aluminum 15 704.100.0 Maintained Gray plastic 18 704.092.0 Maintained Gray plastic 15 704.101.0 Maintained Aluminum 18 704.093.0 Maintained Aluminum For complete switch also order A For complete switch also order Selector switch A For complete switch also order A Buzzer A Selector switch long lever 3 position, flush mount, 30.5mm mounting Drawing Part No. 19 C B Buzzer, plastic bezel, raised, 22.5mm mounting, 24VDC, 95dB ± 8 at a distance of 0.1m Maint/Mom 42° Action Part No. Front finish Part No. Front finish 19 704.095.018 Momentary Aluminum 14-810.002 Black plastic 14-810.910 Black plastic 19 704.093.018 Maintained Aluminum 14-810.902 Chromium-plated 14-810.918 Chromium-plated For complete switch also order www.eaoswitch.com 14 Bezel Buzzer, plastic bezel, flush mount, 30.5mm mounting, 24VDC, IP40, 95dB ± 8 at a distance of 0.1m A EAO Switch Condensed Catalog 100 Series 04 22.5mm 30.5mm IP65 10A 600VAC A Choose one component from each of the colored sections to assemble a complete switch. For other options or further information please contact EAO Switch directly. BLOCK Contact block LED ACCESSORIES LED Contact block, screw terminal, snap-action with silver self-cleaning contacts Contact block, screw terminal, slow-make (positive-break) with silver forced opening contacts LED, Ba9s (T-31/4 bayonet base), single chip, 6 Volt and 12 Volt Part No. Contact type Part No. Contact type Part No. Voltage 704.900.1 1NO 704.910.2 1NC Red 10-2506.1082 6VDC, 17mA 704.900.2 1NC 704.910.4 2NC Yellow 10-2506.1084 6VDC, 17mA 704.900.3 2NO 704.910.5 1NO/1NC Green 10-2506.1085 6VDC, 17mA 704.900.4 2NC 704.910.1 1NO Blue 10-2506.1086 6VDC, 17mA 704.900.5 1NO/1NC 704.910.2 2NO White 10-2506.1089 6VDC, 17mA Red 10-2509.1142 12VAC/DC, 16mA Yellow 10-2509.1144 12VAC/DC, 16mA Green 10-2509.1145 12VAC/DC, 7mA Blue 10-2509.1146 12VAC/DC, 16mA White 10-2509.1149 12VAC/DC, 16mA Not recommended for Emergency-stop applications For complete switch also order Color For complete switch also order LED LED, Ba9s, single chip, (T-31/4 bayonet base) 24 Volt and 28 Volt LED, Ba9s, (T-31/4 bayonet base) single chip, 48 Volt LED, Ba9s, (T-31/4 bayonet base) single chip, 130 Volt and 230 Volt Color Color Color Part No. Voltage Part No. Voltage Part No. Voltage Red 10-2512.1142 24VAC/DC, 15mA Red 10-2519.1052 48VAC/DC, 8mA Red 10-2H24.2052 130VAC / 5mA Yellow 10-2512.1144 24VAC/DC, 15mA Yellow 10-2519.1054 48VAC/DC, 8mA Yellow 10-2H24.2054 130VAC / 5mA Green 10-2512.1145 24VAC/DC, 7mA Green 10-2519.1055 48VAC/DC, 4mA Green 10-2H24.2055 130VAC / 3mA Blue 10-2512.1146 24VAC/DC, 15mA Blue 10-2519.1056 48VAC/DC, 8mA Blue 10-2H24.2056 130VAC / 5mA White 10-2512.1149 24VAC/DC, 15mA White 10-2519.1059 48VAC/DC, 8mA White 10-2H24.2059 130VAC / 5mA Red 10-2513.1142 28VAC/DC, 13mA Red 10-2H25.2042 230VAC / 3mA Yellow 10-2513.1144 28VAC/DC, 13mA Yellow 10-2H25.2044 230VAC / 3mA Green 10-2513.1145 28VAC/DC, 7mA Green 10-2H25.2045 230VAC / 2mA Blue 10-2513.1146 28VAC/DC, 13mA Blue 10-2H25.2046 230VAC / 3mA White 10-2513.1149 28VAC/DC, 13mA White 10-2H25.2049 230VAC / 3mA EAO Switch Condensed Catalog 100 15 Series 04 22.5mm 30.5mm IP65 10A 600VAC Choose one component from each of the colored sections to assemble a complete switch. INDICATOR A PUSHBUTTON E-STOP MUSHROOM KEYLOCK SELECTOR BUZZER Accessories Lens cap, round, transparent, plastic for raised and flush indicators with bezel and pushbutton actuators Color Protective cover, raised pushbutton Protective front ring with silicon membrane for raised or flush mount pushbutton, natural anodized aluminum Part No. Part No. Red 704.602.2 704.925.0 for pushbuttons Comment 704.600.3 29mm Ø for raised pushbutton Part No. Size Yellow 704.602.4 704.925.3 for selector with short 704.955.3 35mm Ø for flush mount pushbutton Green 704.602.5 lever with “self return” Blue 704.602.6 Clear 704.602.7 For complete lens also order diffuser 704.609.9 (see page 21) A Accessories 1 Emergency-stop protective shroud, yellow painted aluminum with 22.5mm mounting hole Emergency-stop switch label, 60mm diameter, English, French and German with adhesive backing Part No. Part No. Contact EAO Switch directly 704.963.6 Markings Image 1 704.945.0 704.963.5 Not Aus 2 704.945.6 704.963.7 Arret D’urgence Blank 90mm versions also available www.eaoswitch.com 16 Emergency-stop switch enclosure with 22.5mm mounting hole Emergency stop 44-950 EAO Switch Condensed Catalog 100 2 Part No. Series 04 22.5mm 30.5mm IP65 10A 600VAC A Choose one component from each of the colored sections to assemble a complete switch. For other options or further information please contact EAO Switch directly. BLOCK A ACCESSORIES Accessories Blanking plate Part No. A LED Lens, LED and lamp remover Part No. Part No. 704.960.7 Mounting hole 22.5mm Ø 704.955.0 700.006.0 704.964.8 30.5mm Ø 704.955.1 Accessories 1 1 2 2 Legend plate, adhesive, natural anodized aluminum finish for raised and flush mount pushbuttons Label for front bezel set for 22.5 and 30.5mm flush mount with label support, self adhesive Image Image Part No. Mounting hole 1 704.968.2 22.5mm Ø 1 704.968.0 Part No. 2 704.968.3 30.5mm Ø 2 704.968.1 EAO Switch Condensed Catalog 100 17 Series 04 Technical Drawings 04 Indicator 04 Indicator Raised Flush 04 Pushbutton 04 Pushbutton Non-Illuminated, Raised Non-Illuminated, Flush 04 Pushbutton 04 Pushbutton Illuminated, Raised www.eaoswitch.com 18 Illuminated, Flush EAO Switch Condensed Catalog 100 Technical Drawings 04 E-Stop EN 418 Series 04 04 E-Stop EN 418 with optional key 04 E-Stop Mushroom 04 Keylock Pushbutton Mushroom 2-Position, 3-Position, Raised 04 Keylock 04 Selector 2-Position, 3-Position, Flush 2-Position, 3-Position, Short and Long, Flush EAO Switch Condensed Catalog 100 19 Series 04 Technical Drawings 04 Selector, Short Lever 04 Selector, Long Lever 2-Position, 3-Position, Raised 2-Position, 3-Position, Raised 04 Buzzer 04 Buzzer Raised Flush www.eaoswitch.com 20 EAO Switch Condensed Catalog 100 Technical Drawings Series 04 04 Cut-outs, Raised Mounting 04 Cut-outs, Flush Mounting (All but long lever) (All but long lever) 04 Long Lever Cut-outs, Raised Mounting 04 Long Lever Cut-outs, Flush Mounting 04 E-Stop EN418 Cut-outs 04 E-Stop Mushroom Cut-outs Pushbutton Mushroom EAO Switch Condensed Catalog 100 21
EUS-704.02-1175
物料型号: - 该系列包括多种型号,例如704.000.2至704.000.7,704.012.218至704.042.718等。
器件简介: - Series 04是高质量的开关系列,包括按钮、指示器、选择器、蘑菇头开关、钥匙开关和紧急停止开关。 - 提供自清洁、慢速接通和快动开关元件等选项。
引脚分配: - 提供螺钉端子或插入式连接方式。
参数特性: - IP65防护等级。 - 最大电压:600VAC。 - 最大热电流:Ith = 10A(230VAC/6A,24VDC/10A)。
功能详解: - 提供多种安装方式,包括22.5mm和30.5mm的凸起安装或齐平安装。 - 使用Ba9s(T-31/4卡口底座)灯泡或LED进行照明。 - 所有标准镜头均为透明,带有半透明散光器。
应用信息: - 适用于需要高防护等级和高电流承载能力的工业环境。
封装信息: - 提供多种颜色和材料的前环、散光器、镜头/帽选择。
EUS-704.02-1175 价格&库存
很抱歉,暂时无法提供与“EUS-704.02-1175”相匹配的价格&库存,您可以联系我们找货
EUS-704.02-1175
    • 1+141.54480
    • 200+56.48400
    • 500+54.59400
    • 1000+53.66520
    EUS-704.02-1175
    • 5+181.692635+23.61142
