R3002BD-F
R3002BD-F
    EASEELECTRONICS
    CBL COAX RG59 22+2/20 AWG 100'
R3002BD-F 数据手册
Cable Assembly RG59 Coaxial Cable with Power Cable Specifications Cable Length Connector Type A Connector Type B Diagram Part Number R1502BD-F R3002BD-F : 50ft, 100ft : BNC (M) + DC (M) : BNC (M) + DC (F) L±L1mm L±L1mm 15240±20mm 30480±20mm Page 29/03/22 V1.0 Cable Assembly RG59 Coaxial Cable with Power Cable Dimensions : Millimeter 1. Cable (0.643MM BC+FPE OD:3.8MM+14mm AL Foil +0.12MM/128#CCA(95%)+WH PVC OD:6.0±0.2MM)+Power (0.20MM/16C CCA+PE OD:1.8MM)*1PAIR(RED/BK)+WH PVC OD:4.5±0.15MM (0.6mm) 2. Connector Type A BNC Male Soldering White PVC Jacket Brass Plated Pin 3. Connector Type B 2.1mm*5.5mm DC Male/Female Soldering White PVC Jacket 4. Inner Molded LDPE 5. Outer Molded 45P PVC, White Part Number Table Description 50ft. RG59 Coaxial Cable with Power Cable 100 ft. RG59 Coaxial Cable with Power Cable Part Number R1502BD-F R3002BD-F Important Notice : This data sheet and its contents (the “Information”) belong to the members of the EASE group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. EASE is the registered trademark of Ease Electronics Co., Limited 2019. Page 29/03/22 V1.0
R3002BD-F 价格&库存
很抱歉,暂时无法提供与“R3002BD-F”相匹配的价格&库存,您可以联系我们找货
R3002BD-F
  • 1+928.222771+120.23732
