L005-102P
L005-102P
    EASEELECTRONICS
    适配器连接器 端子块,夹紧连接,2 针,1 行 至 2.1mm DC 插头 黑色
L005-102P 数据手册
Adapter Plug to Terminal Block Specifications: Connector Type : Adapter : BNC Male Convert From Connector : Terminal Block Convert To Connector :1 Convert From Positions : N/A Convert From Gender : Plug Convert To Gender : Brass / PVC Bodies : Brass Centre Contact Part to be clean and free of burrs Specifications: Connector Type Convert From Connector Convert To Connector Convert From Positions Convert From Gender Convert To Gender Bodies Centre Contact : Adapter : 2.1x5.5mm DC Male : Terminal Block :1 : N/A : Plug : Brass / PVC : Brass Part to be clean and free of burrs Part Number Table Number Description Material Finish 1 Body 2 Washer Brass/ PVC Nickel 100μ” Min. 3 Insulation POM None 4 Centre Contact Brass Copper 5 Insulation POM None Part Number Description L005-101P BNC Male Plug to Terminal Block L005-102P DC Male Plug to Terminal Block Important Notice : This data sheet and its contents (the “Information”) belong to the members of the EASE group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. EASE is the registered trademark of Ease Electronics Co., Limited 2019. Page 04/09/13 V1.0 Adapter Plug to Terminal Block Specifications: Connector Type : Adapter : BNC Female Convert From Connector : Terminal Block Convert To Connector :1 Convert From Positions : N/A Convert From Gender : Plug Convert To Gender : Brass / PVC Bodies : Brass Centre Contact Part to be clean and free of burrs Specifications: Connector Type Convert From Connector Convert To Connector Convert From Positions Convert From Gender Convert To Gender Bodies Centre Contact : Adapter : 2.1x5.5mm DC Female : Terminal Block :1 : N/A : Plug : Brass / PVC : Brass Part to be clean and free of burrs Part Number Table Number Description Material Finish 1 Body 2 Washer Brass/ PVC Nickel 100μ” Min. 3 Insulation POM None 4 Centre Contact Brass Copper 5 Insulation POM None Part Number Description L005-201P BNC Female Plug to Terminal Block L005-202P DC Female Plug to Terminal Block Important Notice : This data sheet and its contents (the “Information”) belong to the members of the EASE group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. EASE is the registered trademark of Ease Electronics Co., Limited 2019. Page 04/09/13 V1.0
L005-102P 价格&库存
很抱歉,暂时无法提供与“L005-102P”相匹配的价格&库存,您可以联系我们找货
L005-102P
    • 1+35.903281+4.64280
    • 10+30.5369410+3.94885
    • 25+28.6255825+3.70169
    • 50+27.2577650+3.52481
    • 100+25.95539100+3.35640
    • 250+24.33021250+3.14624
    • 500+23.16926500+2.99611
    • 1000+22.063951000+2.85318
    • 2500+20.684012500+2.67473
    库存:1785
