EBM6WV300
EBM6WV300
    MENDA
EBM6WV300 数据手册
EBM6WV300 Datasheet Technical Specifications EBM6WV300 Tip Style: Tip Width: Tip Length: 600 Type Cartridge1 : RoHS Compliant 2 / Lead Free: Equivalent to: For Use With: Hoof w/Dent 2.40mm (0.09") 14.50mm (0.57") 325°C - 358°C YES N/A EB-9000S-1, EB-9000S-2, MX500 and MX5000 Material Composition 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2014 Easy Braid Co. All Rights Reserved
EBM6WV300 价格&库存
很抱歉,暂时无法提供与“EBM6WV300”相匹配的价格&库存,您可以联系我们找货
