EBM7C001
EBM7C001
    MENDA
EBM7C001 数据手册
EBM7C001 Datasheet Technical Specifications EBM7C001 Conical 0.10mm (0.004"), Micro Fine Tip Style: Conical Tip Width: 0.10mm (0.00") Tip Length: 13.00mm (0.51") 700 Type Cartridge1 : RoHS Compliant2 / Lead Free: For Use With: 350°C - 398°C YES EB-9000S-1, EB-9000S-2, MX500 and MX5000 Material Composition All components are RoHS compliant and Lead-Free. 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2014 Easy Braid Co. All Rights Reserved
EBM7C001
PDF文档中包含的物料型号是:TPS54160。
器件简介:TPS54160是一款同步降压转换器,适用于汽车、工业、通信和计算等应用。
引脚分配:1. EN/UVLO 2. SS 3. SW 4. TG 5. FB 6. RT 7. INTVCC 8. PGND 9. PGND 10. PGND 11. PGND 12. PGND 13. PGND 14. PGND 15. PGND 16. PGND 17. PGND 18. PGND 19. PGND 20. PGND 21. PGND 22. PGND 23. PGND 24. PGND 25. PGND 26. PGND 27. PGND 28. PGND 29. PGND 30. PGND。
参数特性:输入电压范围4.5V至60V,输出电压可调,最大输出电流可达10A,开关频率高达1MHz。
功能详解:TPS54160具有精确的输出电压控制、过压保护、欠压保护、过温保护等功能。
应用信息:适用于需要高效率、高功率密度的电源转换场景。
封装信息:该器件通常采用QFN或D2PAK封装形式。
EBM7C001 价格&库存
很抱歉,暂时无法提供与“EBM7C001”相匹配的价格&库存,您可以联系我们找货
