EBM80DT006
EBM80DT006
    MENDA
    DESOLDERING TIP 1.50MM
EBM80DT006 数据手册
EBM80DT006 Datasheet Technical Specifications EBM80DT006 Tip Style: Tip Width: Tip Length: 800 Type Cartridge1 : RoHS Compliant 2 / Lead Free: Equivalent to: For Use With: Desolder 1.50mm (0.06") 14.00mm (0.55") 420°C - 475°C YES STDC-806 EB-9000S, EB-9000S-2, MX500 and MX5000 Material Composition 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2012 Easy Braid Co. All Rights Reserved
EBM80DT006 价格&库存
很抱歉,暂时无法提供与“EBM80DT006”相匹配的价格&库存,您可以联系我们找货
