ES80BV011
ES80BV011
    MENDA
    BEVEL 1.10MM
ES80BV011 数据手册
ES80BV011 Datasheet Technical Specifications ES80BV011 Bevel 60° 1.10mm (0.04") Tip Style: Bevel Tip Width: 1.10mm (0.04") Tip Length: 13.40mm (0.53") 420°C - 475°C 80 Type Cartridge1 : RoHS Compliant2 / Lead Free: YES For Use With: EB-2000S, SP200, MFR-PS1100, MFR-PS2200 (SSC Tips) Material Composition All components are RoHS compliant and Lead-Free. 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2013 Easy Braid Co. All Rights Reserved
ES80BV011 价格&库存
很抱歉,暂时无法提供与“ES80BV011”相匹配的价格&库存,您可以联系我们找货
