ET60DT006
ET60DT006
    MENDA
ET60DT006 数据手册
ET60DT006 Datasheet Technical Specifications ET60DT006 Desolder Tip - Inner Diameter 1.50mm (0.06") Tip Style: Desolder Tip Width: 1.50mm (0.06") Tip Length: 14.00mm (0.55") 600 Type Cartridge1 : RoHS Compliant2 / Lead Free: For Use With: 325°C - 358°C YES EB-5000S-1, EB-5000S-2 Material Composition All components are RoHS compliant and Lead-Free. 1 Easy Braid Co. tip cartridges will typically idle within a temperature range of +/-1.1°C. However, there is variation in idle temperature across tip geometries within an individual temperature series. Easy Braid Co. offers a wide variety of tip geometries from 0.25mm fine point tip to 5mm chisel. The length and geometry of a tip will have an influence on the tip idle temperature. To accurately measure idle temperature it will depend greatly on the measurement method, technique and equipment used. Two different methods or the use of alternative equipment will produce different test results. 2 Please refer to http://www.rohs.gov.uk for details on RoHS Compliance. Copyright © 2010-2014 Easy Braid Co. All Rights Reserved
ET60DT006 价格&库存
很抱歉,暂时无法提供与“ET60DT006”相匹配的价格&库存,您可以联系我们找货
