USB-B1 v2 User Manual
V1.5
22/05/2018
Table of Contents
1.
Introduction ..................................................................................................................................................2
1.1 Device Overview ................................................................................................................................................ 2
1.2 System Overview ............................................................................................................................................... 3
1.3 Features ............................................................................................................................................................. 3
1.4 Connectors......................................................................................................................................................... 4
1.4.1
USB Connector (J1) ................................................................................................................................ 4
1.4.2
External Antenna Connector (J10) ........................................................................................................ 5
1.4.3
External / PCB Antenna Selection Connectors J8 and J9 ....................................................................... 5
1.4.4
IO and Peripheral Configuration Header ............................................................................................... 6
1.5 LEDs ................................................................................................................................................................... 6
2.
Electrical Characteristics ................................................................................................................................7
2.1 Test Conditions .................................................................................................................................................. 7
2.2 Absolute Maximum Ratings ............................................................................................................................... 7
2.3 Operating Conditions......................................................................................................................................... 7
2.4 GPIO ................................................................................................................................................................... 7
2.5 Antenna Output ................................................................................................................................................. 8
2.6 Flash ................................................................................................................................................................... 8
2.7 IDAC ................................................................................................................................................................... 8
2.8 PWM ................................................................................................................................................................ 11
2.9 ADC .................................................................................................................................................................. 11
2.10 Comparator...................................................................................................................................................... 11
3.
Installation and operation ........................................................................................................................... 12
4.
Mechanical Dimensions ............................................................................................................................... 13
1
1. Introduction
1.1 Device Overview
Features
Low cost RFID Reader with MIFARE
Classic®, MIFARE Ultralight® and
NTAG2® support
LED indicator of a tag presence in the
antenna field
Stand-alone mode (polling)
Command interface via USB COM PORT
with optional AES-128 encryption
UART baud rate up to 921600 bps
High transponder read and write speed
-25°C to 85°C operating range
4 configurable GPIOs with interrupts
3 configurable PWMs
Comparator
ADC
Current Output DAC
AES-128 encryption engine
Multiple internal reference voltages
RoHS compliant
Applications
Access control
Monitoring goods
Approval and monitoring
consumables
Pre-payment systems
Managing resources
Contact-less data storage systems
Evaluation and development of RFID
systems
Description
The USB-B1 v2 module is an expansion of the RFID B1 module - the
second in an evolving family of 13.56 MHz sub assemblies from
Eccel Technology Ltd (IB Technology). The product is designed
with both embedded applications and computing / PLC platforms
in mind. This product is an ideal design choice if the user wishes to
add RFID capability to their design quickly and without requiring
extensive RFID and embedded software expertise and time. An on
board low power ARM microcontroller handles the RFID
configuration setup and provides the user with a powerful yet
simple command interface to facilitate fast and easy read/write
access to the memory and features of the various transponders
supported by this module.
2
1.2 System Overview
The USB-B1 v2 device is an extension of our RFID B1 module. Below, In Figure 1-1 the System Diagram is presented.
5V to 3.3V Voltage
Converter
+5V
PCB RFID Antenna
+3.3V
USB Type B
Connector
(J1)
FTDI FT234XD USB
to Com Port
Converter
UART
RFID B1 Module
ANT Signals
RFID Antenna Switch
(J8 and J9)
+3.3V
IO + Peripherals
+5V
Header Connector
(J3)
External RFID
Antenna Connector
(J10)
Figure 1-1 System Diagram
1.3 Features
Parameter
Typical Value
Range (dependent upon antenna dimensions and tuning, tag: MIFARE Classic® 1K
ISO card)
a) PCB antenna (on board)
b) External PCB antenna 50x50mm (RFID-ANT1356-50x50-300 v1)
c) External PCB antenna 25x25mm (RFID-ANT1356-25x25-300 v1)
Nominal RF frequency
Supported tags
Time needed to read the whole tag memory (MIFARE Classic® 1K)
Time needed to write the whole tag memory (MIFARE Classic® 1K)
Width x Length
Table 1-1
3
up to 50 mm
up to 70 mm
up to 40 mm
13.56 MHz
MIFARE Classic®, MIFARE
Ultralight®, NTAG2®
0.5 s
0.6 s
75 x 50 mm
1.4 Connectors
Micro USB Connector (J1)
External/PCB Antenna Selection
Connectors (J8 and J9)
IO and Peripherals
Configuration Header (J3)
Picture 1-1
In Picture 1-1 there are marked connectors available for the user when working with the USB-B1 v2 device. The
connectors used on the USB-B1 v2 are described below.
1.4.1
USB Connector (J1)
The device provides communication and power via USB connector J1. It is a micro USB Type B connector. The USB port,
connected to the FTDI FT234XD chip provides USB to COM Port functionality. The user can configure the COM Port
with a baud rate up to the maximum allowed by the RFID B1 module.
4
1.4.2
The user has the option to work with an external RFID antenna connected to the USB-B1 v2 device. Connector J10 is
where this should be connected. Eccel Technology Ltd provides a variety of RFID antennas which the user can use
together with this device.
J10 – External Antenna Socket
1.4.3
To switch between the PCB antenna and an external antenna, two jumpers have to be used with the J8 and J9
connectors. These jumpers (J8 and J9) are not mounted by default.
J8,J9 – Antenna selection header
EXTERNAL ANTENNA
PCB ANTENNA
REMARK: Also remove resistors: R13 and R14
Before connecting an external antenna the user should remove the R13 and R14 resistors. These resistors are
mounted by default and connect the RFID chip to the internal PCB antenna.
We recommend using our external antennas from series RFID-ANT1356-50X50-xxx, where xxx is the cable length in
mm. They have a read range of about 70mm, 50x50mm in size and 300 or 800mm cable length. We can also design
antennas with higher read range and custom dimensions on request.
More information about antennas: https://eccel.co.uk/product-category/antennas/
5
1.4.4
The device PCB connects the pins on this header to all IOs and peripherals provided by the onboard RFID B1 module
and a few pins are available providing +3.3V and GND signals.
J3.1 – GPIO 0
J3.2 – GPIO 2
J3.3 – GPIO 1
J3.4 – GPIO 3
J3.5 – GND
J3.6 – 3.3 V
J3.7 – IDAC (Digital to Analog Converter with current-type output)
J3.8 – GND
J3.9 – COMP (Comparator positive input)
J3.10 – GND
J3.11 – ADC (Analog to Digital Converter input)
J3.12 – GND
J3.13 – GND
J3.14 – nRST (nRESET – reset input signal – active low)
J3.15 – nSLEEP (Output signal indicating the device is in Sleep Mode or Power Down Mode – active low)
J3.16 – nPWRDN (Power Down Request input signal – active low)
1.5 LEDs
There are 3 LEDs installed on the board. Each of them has its own functionality:
LED1 – indicates that the reader is powered.
LED2 – indicates data transmission via UART interface. The Functionality of LED2 can be configured in the
internal MTP (Multiple-Time Programmable) memory of the FT234XD chip using the software utility FT_PROG
which can be downloaded from the FTDI Utilities (click here).
LED3 – indicates a tag presence in the reader antenna field.
All of the LEDs are marked in green in Figure 4-1.
6
2. Electrical Characteristics
2.1 Test Conditions
Typical device parameters were measured at an ambient temperature 22°C ±3°C and using a power supply of 5V ±5%.
Symbol
TS
Parameter
Storage Temperature
Min
-40
Max
150
Unit
°C
VUSBMAX
VIOMAX
USB Supply Voltage
V
Input Pin Voltage
-0.3
3.5
V
IIOMAX
Output Pin Current
mA
IANT
ANT1 and ANT2 Current
mA
Notes
Maximum continuous current. This depends upon the impedance of the
circuit between ANT1 and ANT2 at 13.56MHz.
Table 2-1
Symbol
Parameter
Min
Max
Unit
TO
Ambient Temperature
-25
85
°C
VUSB
USB Supply Voltage
4.5
5.5
V
V3V3
+3.3V Generated Voltage
3.235
3.365
V
Table 2-2
2.4 GPIO
Symbol
Parameter
VIOIL
Input Low Voltage
VIOIH
Input High Voltage
IIOMAX
Output Pin Current
IIOLEAK
Input Leakage Current
Internal ESD Series
Resistor
IO Pin Histeresis
RIOESD
V IOHYST
Min
Typ
Max
Unit
0.3V3V3
V
0.7V3V3
V
± 0.1
200
0.1V 3V3
Notes
±6
mA
± 40
nA
Ω
V
Table 2-3
7
High impedance IO connected to V3V3 or GND.
2.5 Antenna Output
Symbol
fANT
fANTAG
VANTH
VANTL
IANT
Par ameter
Min
Antenna Signal
Frequency
Antenna Signal
Frequency Aging
Antenna High Level
Output Voltage
Antenna Low Level
Output Voltage
Typ
M ax
Unit
Notes
MHz
±30 ppm (-20°C - 70°C).
ppm
At 25°C.
V
IANT = 80mA.
0.64
V
IANT = 80mA.
100
mA
the circuit between ANT1 and ANT2 at 13.56MHz.
13.56
V3V3 - 0.64
Table 2-4
2.6 Flash
Symbol
Parameter
Min
CFE
Flash Erase Cycles Before
Failure
Typ
Max
Unit
20000
cycles
TFDR
Flash Data Retention Time
10
years
years
Notes
For ambient temperature < 85°C
For ambient temperature < 70°C
Table 2-5
2.7 IDAC
IDAC Parameters
Source
Current drop at Temperature
Nominal
Range No Range [µA] Step Size [nA]
Vdd - 100 mV
coefficient
Current [µA]
[nA/°C]
Precision
2
3
< 0 ; 1.6 >
( 1.6 ; 4.7 >
( 4.7 ; 16 >
( 16 ; 64 >
50
100
500
2000
0.85
3.2
8.5
34
0.79
0.75
1.22
3.54
0.3
0.7
2.8
10.9
Table 2-6
8
Voltage
coefficient
[nA/V]
11.7
38.4
96.6
159.5
Sink
Temperature Voltage
Current drop at
coefficient coefficient
200 mV [%]
[nA/°C]
[nA/V]
0.3
0.32
0.62
1.75
0.2
0.7
2.8
10.9
12.5
40.9
94.4
148.6
Figure 2-1 Source Current
9
Figure 2-2 Sink Current
10
2.8 PWM
PWM Parameters
Period
Frequency
Minimum Maximum Minimum Maximum Maximum Error
[µs]
[s]
[Hz]
[kHz]
4.81
3.19
0.313
207.9
3
Table 2-7
2.9 ADC
Symbol
Parameter
Min
Typ
Max
Unit
Notes
VADCIN
Input Voltage Range
IADCIN
Input Current
2.5
V
Internal 2.5V reference voltage used.
100
nA
CADCIN
Input Capacitance
2
pF
RADCIN
Input On Resistance
1
MΩ
Table 2-8
2.10 Comparator
Symbol
Parameter
Min
VCMPIN
Input Voltage Range
VCMPOFST
Offset Voltage
-12
VCMPHYST
Hysteresis
Typ
Max
Unit
V3V3
V
12
mV
mV
Table 2-9
11
Notes
3. Installation and operation
From the system and functionality point of view, the USB-B1 v2 device gives the same features as the RFID B1 module,
and the user should refer to the RFID B1 User Manual when working with the USB-B1 v2. The FTDI chip expands the
communication interface to the on-board RFID B1 module and allows the board to be connected to a computer and
communicate with the device via a USB Com Port. Most systems have built-in drivers for such a Com Port.
For a quick test, the user can connect the USB-B1 v2 to a computer and then start the B1-client application which
allows the user to test all features of the device. The B1-client along with its user guide can be downloaded from here.
HOST
USB Cable
Figure 3-1 Connection to the host system.
The best read range can be achieved when the tag is parallel to the surface of the reader.
Figure 3-2 The correct way to read a RFID tag
12
The USB-B1 v2 can also operate in a stand-alone mode. The user can control all GPIO’s and add tags to the whitelist (a
list of defined tags). For easy configuration of polling parameters we provide the B1 Stand-Alone Configurator
application which can be downloaded from here. This application allows the user to simply search for a new tag, add
it to the whitelist, configure polling parameters, enable/disable all of GPIOs and control them. For more information
please refer to the RFID-B1 User Manual.
Figure 3-3 The main window of the B1 Stand-alone Configurator
13
4. Mechanical Dimensions
Dimensions in mm. All LEDs are marked with green circles.
Figure 4-1
14
MIFARE, MIFARE Ultralight, MIFARE Plus, MIFARE Classic, and MIFARE DESFire are trademarks of NXP B.V.
No responsibility is taken for the method of integration or final use of the B1 based modules
More information about the B1 module and other products can be found at the Internet site:
http://www.eccel.co.uk
or alternatively contact ECCEL Technology (IB Technology) by e-mail at:
sales@eccel.co.uk
15
很抱歉,暂时无法提供与“000373”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+484.570661+62.63590
- 3+461.229453+59.61880
- 10+437.8882310+56.60170
