75060R-30
75060R-30
    DIALOGSEMICONDUCTOR(戴乐格)
    U60 TP1250
75060R-30 数据手册
PRODUCT DATASHEET U60 USB to LON® FT and TP-1250 Expansion Modules IP-70 and IP-852 Clients and Routers RNI Clients IP-70 IP-852 Remote Network Interface (RNI) Ethernet Interface SmartServer IoT® Reset LAN BT/BLE WLAN Ready WAN Connect USB Interfaces U60 U60 TP-1250 and FT devices U60 expansion modules connect LON devices via USB Product Description The U60 network interface expansion modules enable a controller or computer to communicate with LON networks via USB. The compact devices are housed in DIN 43880 2TE compliant enclosures. The U60 TP-1250 model is an interface to LON/ IP TP-1250 and LON TP-1250. The U60 FT model is an interface to LON/IP-FT and LON-FT. Both are compatible with OpenLDV 5 and with hosts implementing the LON/IP stack which provides source code for LON/IP and LON compatible protocol stacks. The interfaces facilitate communication to everyday devices like pumps, motors, valves, sensors, actuators and lights for process control, building automation, energy management, transportation systems control and telecommunications equipment management. Tx and Rx LEDs provide an indication of LON packet transmission and reception. An on-board Status or Service LED (see specifications) provides a visual indication of device status; status is also communicated to the host via the USB interface enabling the host controller to monitor Status (TP1250 model) or provide a network Service indicator (FT model). Features and Benefits • USB interfaces for LON FT and TP-1250 networks for any edge server, gateway, controller, or device, including Echelon’s SmartServer IoT and i.LON 700 • Compatible with IzoT® Net Server, OpenLNS® Server, LNS® Server and OpenLDV applications • Works with IzoT Net and LNS compatible applications such as the IzoT Commissioning Tool and LonMaker Integration Tool • Compatible with SmartServer™ IoT and i.LON 700 • Compact DIN 43880 2TE form factor • Powered by 5V USB input • Source code available as download for a Linux-compatible driver Project: Date: Detail: Product Specifications Hardware and electrical specifications Humidity: 10-90% RH @ 50°C Mounting: DIN 43880 2TE Processor (TP-1250 model): Echelon Neuron 6050 Processor (FT model): Echelon FT 6050 Smart Transceiver LON connector: 1 two-way push clip Interface (TP-1250 model): Micro-B USB receptacle for connection to the host: Certified USB 2.0 compatible, compatible with USB 1.1 and highspeed USB systems, peripherals and cables LON/IP TP-1250 and LON TP-1250 (TP/ XF-1250) with a Layer 2 or Layer 5 interface Interface (FT model): LON/IP-FT and LON-FT (TP/FT-10) with a Layer 2 or Layer 5 interface USB cable: Includes cable with Micro-B USB to Type A USB Indicators: LON Tx/Rx LEDs, Status LED (TP-1250 model), Service LED (FT model) Software Platform Drivers (free downloads from echelon.com/downloads): • Linux source code for a U60 network driver • OpenLDV 5, or newer, driver for Windows (FT model only) Safety, compliance and warranty Connect button: TP-1250 model Agency approvals: MET 60950, TUV EN 60950, CE, C-Tick Input voltage: 5VDC USB power EMC: Input current: 110mA maximum USB power FCC Part 15 Class A, EN55022 Class A, EN55024, CISPR 24 Class A Temperature range: -40°C to +70°C Warranty: 1 year limited warranty Dimensions, Mounting and Connections FT DIN 3.5" 89.5mm U60 FT DIN Model 75060R-40 Input Voltage: 5V USB USB 1.4" 35mm TP-1250 DIN 75060R-30 75060R-40 LON/FT Network 2.5" 66.5mm The U60 modules are designed for DIN-rail mounting; dimensions for both modules are the same 3.5" Model # 89.5mm Connect Bottom view (when mounted): USB port, connect button, network connector Product Name Product Description U60 U60TP-1250 DIN Network Interface TP-1250 DIN USB interface to LON/IP TP-1250 and LON TP-1250 1.25Mbps twisted pair networks Model 75060R-30 Input Voltage: 5V USB U60 FT DIN Network Interface DS-18003 rev 2/19 USB interface to LonTalk/IP-FT and LON-FT free topology twisted pair networks © 2019 All rights reserved. Echelon, Echelon logo, IzoT and LON are trademarks or registered trademarks of Echelon Corporation in the United States and other countries. Other company, product or service names may be trademarks or service marks of others. Content is subject to change without notice.. 1.4" 35mm 2.5" 66.5mm info@echelon.com
75060R-30 价格&库存
很抱歉,暂时无法提供与“75060R-30”相匹配的价格&库存,您可以联系我们找货
