151-832-426-900
151-832-426-900
    CONN HEADER R/A 32POS 4MM
151-832-426-900 数据手册
TOLERANCE 0.30 6.00 2.30 65.70 3.350±0.20 .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED ±0.35 ±0.25 ±0.15 ORIGINAL 1 NOTES: MATERIAL: HOUSING: SWITCH: CONTACT: L.C.P HIGH TEMPERATURE, UL-94V-0 SUS304 COPPER ALLOY, GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER 50µ" MIN. NICKEL UNDER PLATING 70.60 60.00 4.00 TYP 1.05TYP. 4 6 32 1 3 5 31 1.00 4 .0 ±0 40 .4 Ø1 4.25 64.00 2 REMOVE THE 4.00 TERMINAL 3 & 4 RECOMMAND PCB LAYOUT (COMPONENT SIDE) THICKNESS 2.34mm 8.00 6.80 2.28 2.10 2.70 REMOVE THE TERMINAL 3 & 4 60.00 2.50 32 2.25 6 10.00 2 6.50 31 9.0 5 2.80±0.30 0.30 65.70 1 3 1 3 5 31 2 4 6 32 Ø1 .45 ±0 .05 REMOVE THE TERMINAL 3 & 4 RECOMMAND PCB LAYOUT (COMPONENT SIDE) THICKNESS 1.60mm 8.00 4.00 2.35 2.500±0.20 2.50 30.00 2 1 0.80 3.10 2.50±0.30 3 SWITCH 2 SUS304 - 2 CONTACT 30 COPPER ALLOY TIN PLATING ON SOLDERING END OVER 50u" MIN. NICKEL UNDER-PLATING 1 HOUSING 1 HIGH TEMPERATURE, UL94 V-0 - NO. DESCRIPTION QTY. MATERIAL FINISH 2.00 POWER PIN HEADER R/A TYPE CONNECTOR FOR BACKPLANE SERVER ACAD REFERENCE NO.: DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 151-832-426-900 DATE: JULY.03 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 151-832-426-900 ISSUE PART NUMBER: 151-832-426-900 1
151-832-426-900 价格&库存
很抱歉,暂时无法提供与“151-832-426-900”相匹配的价格&库存,您可以联系我们找货
