171-170-231-012
171-170-231-012
    PCB SOCKET, VERTICAL PRESS FIT W
171-170-231-012 数据手册
TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX 65.15±0.05 ±0.35 ±0.25 ±0.15 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 -C- A 45° 10.0±0.10 7.50±0.10 NOTES: C1.10±0.10 0.750 A MATERIAL: HOUSING: SIGNAL CONTACT: 1.20±0.10 GROUND CONTACT: 63.000 L.C.P GLASS FILLED, UL-94V-0 COLOR: BLACK COPPER ALLOY GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING COPPER ALLOY GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING CAVIT NO. 73.00±0.10 1.90±0.08 0.05 A B C -B- 12.50±0.10 2.80±0.10 2.10±0.20 3.50±0.10 1.15±0.10 1433 5 SEC. A-A SCALE 3:1 DATE CODE: 14 33 2.20±0.05 WEEK YEAR: 2014 69.30±0.05 58.500 5.80±0.10 -A- 1.500 1 1.350 5 4 2.250 4 3 2 3.000 3.625 GROUND PAD INSERT MOLDING 3 COPPER ALLOY 100~200 μ" NICKEL 58 GLASS FILLED LCP, UL94 V-0 BLACK 4 SIGNAL CONTACT 58 COPPER ALLOY SEE NOTES 3 GROUND CONTACT 27 COPPER ALLOY SEE NOTES 2 CAP 1 1 HOUSING 1 NO. DESCRIPTION QTY. PCB SOCKET, VERTICAL PRESS FIT W/ GROUNDING PAD, 170 CONTACTS, FEMALE DRAWN: W.T COMPLIANT EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: BLACK BLACK MATERIAL ACAD REFERENCE NO.: CHECKED: THIS SERIES FULLY CONFORMS TO GLASS FILLED LCP, UL94 V-0 GLASS FILLED LCP, UL94 V-0 FINISH / COLOR 171-170-231-012 DATE: JULY.03 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 171-170-231-012 ISSUE PART NUMBER: 171-170-231-012 1
171-170-231-012 价格&库存
很抱歉,暂时无法提供与“171-170-231-012”相匹配的价格&库存,您可以联系我们找货
