472-100-529-001
472-100-529-001
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:100Pin 间距:0.8mm 排数:2
472-100-529-001 数据手册
.X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. TOLERANCE UNLESS OTHERWISE SPECIFIED 1 ORIGINAL ±0.25 ±0.15 ±0.10 46.000 PIN 1 15.0 42.800 1.500 MYLAR PIN 99 PITCH 0.800 39.200 5.600 7.500 3.250 5.700 0.800 1. Ø 45 0 0.500 PIN 100 PIN 2 3.200 7.600 4.400 44.200 NOTES: A 9.97 MATERIAL: MYLAR: HOUSING: CONTACT: -A- 0.10 A 1.270 0.130 REF. A 4.660+0.2 -0 SEC. A-A 42.800 PIN 2 PIN 100 0 .32 Ø1 OPERATION TEMPERATURE: -55°C TO 85°C ELECTRICAL: CURRENT RATING: VOLTAGE RATING: INSULATION RESISTANCE: CONTACT RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: 0.5A 50V AC 500MΩ MIN. 50MΩ MAX. 150V AC / 60 SEC. 1.500 MARKED MARKED PIN 1 PE MATERIAL (NO PLATING) L.C.P SERIES, UL-94V-0 COPPER ALLOY 10µ" GOLD PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING : CRITICAL DIMENSION DIMENSIONS NEED TO BE MEASURED IN CPK PIN 99 BOARD TO BOARD, 100 CONTACTS, SMT, ALL LONG PIN, MALE ACAD REFERENCE NO.: DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 472-100-529-001 DATE: JUNE.28 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 472-100-529-001 ISSUE PART NUMBER: 472-100-529-001 1
472-100-529-001 价格&库存
很抱歉,暂时无法提供与“472-100-529-001”相匹配的价格&库存,您可以联系我们找货
