500-040-225-E02
500-040-225-E02
    ZD CONNECTOR, 2.0 MM HARD METRIC
500-040-225-E02 数据手册
.X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. TOLERANCE UNLESS OTHERWISE SPECIFIED ±0.25 ±0.15 ±0.10 1 ORIGINAL NOTES: MATERIAL: HOUSING: SHIELD: -X0.05 X Y CONTACT: 1.500 1.50±0.2 ROW DG (GROUND) ROW D ROW C ROW BG (GROUND) ROW B ROW A TYP. ALL PLATED THRU HOLES LCP +30% GLASS REINFORCED, UL94V-0 PHOSPHOR BRONZE NICKEL PLATING PHOSPHOR BRONZE GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING 30~100µ" ON SOLDER TAIL OVER NICKEL 50~150µ" UNDER PLATING -Y- 2.500 TYP. PCB HOLE DIM: DRILLED HOLE = 0.700±0.025mm FINISHED HOLE = 0.600±0.050mm Cu THICKNESS = 0.0375±0.0125mm SnPb THICKNESS = 0.007±0.003mm 9 X 2.5 = 22.5 PCB LAYOUT SCALE 2:1 2.500 0.750 1.000 18.900 8.580 2.750 2.200 8.670 11.350±0.08 15.000 1.150 24.900 1.500 1.500 3.680 3.000 13.350±0.08 1.500 10.000 2.000 10.70 8.20 ACAD REFERENCE NO.: ZD CONNECTOR, FEMALE, RIGHT ANGLE, 2 PAIR DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 500-040-225-E02 DATE: JUNE.27 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 500-040-225-E02 ISSUE PART NUMBER: 500-040-225-E02 1
500-040-225-E02 价格&库存
很抱歉,暂时无法提供与“500-040-225-E02”相匹配的价格&库存,您可以联系我们找货
500-040-225-E02
    • 4+24.135994+3.13760
    • 9+18.101999+2.35320
    • 91+16.8951991+2.19632
    库存:129
