TOLERANCE
UNLESS OTHERWISE
SPECIFIED
.X
.XX
.XXX
±0.25
±0.15
±0.10
C
22.50
18.90
2.50
TYP.
1.00
ROW B
ROW A
1.20
TYP.
4.50
TYP.
2.60
0.700±0.05
7.67
-Y-
1.70
8.67
13.35
4.50
TYP.
ROW D
ROW C
11.35
1.50
TYP.
4.00
TYP.
1
LCP E6808 +30% GLASS REINFORCED, UL94V-0
PHOSPHOR BRONZE
COPPER ALLOY
GOLD FLASH PLATING 80~160µ" ON SOLDER TAIL
OVER NICKEL 50~150µ" UNDER PLATING
CRITICAL DIMENSION; OTHERWISE MINOR DIEMSION
DIMENSIONS NEEDS TO BE MEASURED IN CPK
MARKED:
MARKED:
24.95 MAX.
ORIGINAL
NOTES:
MATERIAL:
HOUSING:
SHIELD:
CONTACT:
10.00
CL
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM.
0.250±0.05
0.620±0.05
"A"
8.70
CL - -X-
TOP SURFACE OF PCB
DETAIL A
SCALE 10:1
3.68
0.75
1.50
1.10
ALL PLATED THRU HOLES
11.73
2.50
0.20
CL
10
6
5
1
ROW DG (GROUND)
ROW D
ROW C
ROW CG (GROUND)
ROW BG (GROUND)
ROW B
ROW A
ROW AG (GROUND)
1.1
1.0±0.2
15.00
22.50
-X-
8.00
4.5 TYP.
X Y
1.2 TYP.
0.10
0.9 TYP.
Ø0.460
1.2 TYP.
3.50
2.50
TYP.
2.50
TYP.
-Y1.04
9X2.5=22.50
RECOMMENDED PCB LAYOUT
SCALE 2:1
ACAD REFERENCE NO.:
ZD+ CONNECTOR, FEMALE, RIGHT ANGLE, 2 PAIR
DRAWN:
W.T
CHECKED:
COMPLIANT
THIS SERIES FULLY CONFORMS TO
EDAC INC
THE EUROPEAN UNION DIRECTIVES
TORONTO, ONTARIO
CANADA
2011/65/EU FOR RoHS COMPLIANCY.
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
SCALE:
500-040-225-G02
DATE:
JUNE.27 /2018
DATE:
N.T.S
SHEET
1
OF
1
DRAWING NUMBER:
500-040-225-G02
ISSUE
PART NUMBER:
500-040-225-G02
1
很抱歉,暂时无法提供与“500-040-225-G02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+83.171311+10.81200
- 2+55.447542+7.20800
- 5+41.585655+5.40600
- 40+38.8132840+5.04560
- 106+36.04090106+4.68520
- 国内价格 香港价格
- 648+92.96218648+12.08479
