2.5REF.
1.5REF.
1.6REF.
NOTES:
MATERIAL:
HOUSING:
SHIELD:
CONTACT:
TYP
1.2REF.
GROUND
0.9REF.
GROUND
GROUND
2PLC
4.5REF.
11.65REF.
2REF.
ROW C
ROW D
15.35REF.
GROUND
ROW A
ROW B
1
ORIGINAL
2PLC
24.9REF.
1.2REF.
±0.35
±0.25
±0.15
3.125REF.
.X
.XX
.XXX
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM.
TOLERANCE
UNLESS OTHERWISE
SPECIFIED
LCP +30% GLASS REINFORCED, UL94V-0
PHOSPHOR BRONZE
PHOSPHOR BRONZE
GOLD FLASH PLATING 30~100µ" ON SOLDER
TAIL OVER NICKEL 50~150µ" UNDER PLATING
3.8±0.10
6.35±0.2
2.95±0.05
PCB HOLE DIM:
13.4±0.08
DRILLED HOLE = 0.550±0.020mm
FINISHED HOLE = 0.460±0.050mm
Cu THICKNESS = 0.0375±0.0125mm
2.5
X9=
Au THICKNESS = 0.007±0.003mm
22.5
Ni THICKNESS = 0.0044±0.0032mm
2.5
OR Ag THICKNESS = 0.0003±0.002mm
0.9
-Y-
Ø0.46REF
8.1
1.2
1.2
3.6
GROUND
ROW A
ROW B
GROUND
GROUND
ROW C
ROW D
GROUND
-X0.05
X Y
ALL PLATED THRU HOLES
ACAD REFERENCE NO.:
ZD+ CONNECTOR, MALE, VERTICAL, 2 PAIR
DRAWN:
W.T
CHECKED:
COMPLIANT
THIS SERIES FULLY CONFORMS TO
EDAC INC
THE EUROPEAN UNION DIRECTIVES
TORONTO, ONTARIO
CANADA
2011/65/EU FOR RoHS COMPLIANCY.
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
SCALE:
500-040-231-J01
DATE:
JUNE.27 /2018
DATE:
N.T.S
SHEET
1
OF
1
DRAWING NUMBER:
500-040-231-J01
ISSUE
PART NUMBER:
500-040-231-J01
1
很抱歉,暂时无法提供与“500-040-231-J01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 102+8.70388102+1.12585
- 250+8.35499250+1.08072
