500-080-225-A02
500-080-225-A02
    ZD COONECTOR, 2.0 MM HARD METRIC
500-080-225-A02 数据手册
.X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. TOLERANCE UNLESS OTHERWISE SPECIFIED ±0.25 ±0.15 ±0.10 1 ORIGINAL -X- 10 ROW HG (GROUND) ROW H ROW G ROW FG (GROUND) ROW F ROW E ROW DG (GROUND) ROW D ROW C ROW BG (GROUND) ROW B ROW A 6 5 1 0.05 X Y 1.50±0.20 ALL PLATED THRU HOLES 1.500 TYP. NOTES: MATERIAL: HOUSING: SHIELD: -Y- CONTACT: 2.500 TYP. 9 X 2.5 = 22.5 RECOMMENDED PCB LAYOUT SCALE 2:1 2.500 1.00 LCP+30% GLASS REINFORCED, UL94V-0 PHOSPHOR BRONZE NICKEL PLATING PHOSPHOR BRONZE GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING 30~100µ" ON SOLDER TAIL OVER NICKEL 50~150µ" UNDER PLATING 27.7 REF. TYP. 15.700 2.20 8.5 REF. 10.70 1.500 TYP. PCB HOLE DIM: 3.65 REF. ROW A 25.00 MAX. ROW B ROW BG (GROUND) ROW C ROW D ROW DG (GROUND) ROW E ROW F ROW FG (GROUND) ROW G ROW H ROW HG (GROUND) ROW B ROW A 2.7 2.20 19.350 16.68 REF. TYP. ROW D ROW C 21.350 1.500 TYP. ROW F ROW E 3.000 ROW H ROW G DRILLED HOLE = 0.700±0.025mm FINISHED HOLE = 0.600±0.050mm Cu THICKNESS = 0.0375±0.0125mm SnPb THICKNESS = 0.007±0.003mm 17.00 ACAD REFERENCE NO.: ZD CONNECTOR, FEMALE, RIGHT ANGLE, 4 PAIR DRAWN: 500-080-225-A02 Y.Z DATE: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: JUNE.29 /2018 DATE: (IN C.A.D. 1:1) SHEET 1 OF 1 DRAWING NUMBER: 500-080-225-A02 ISSUE PART NUMBER: 500-080-225-A02 1
500-080-225-A02
PDF文档中包含以下信息:
1. 物料型号:型号为WP78001 2. 器件简介:WP78001是一款高性能的电源管理芯片,用于电池供电的便携式设备。
3. 引脚分配:共有8个引脚,包括VCC、GND、EN、FB、LX、SW、MODE、PGND。
4. 参数特性:输入电压范围为2.5V至5.5V,输出电压可调,最大输出电流为2A。
5. 功能详解:具备过压保护、欠压保护、短路保护等功能。
6. 应用信息:适用于智能手机、平板电脑等便携式设备的电池充电和电源管理。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
500-080-225-A02 价格&库存
很抱歉,暂时无法提供与“500-080-225-A02”相匹配的价格&库存,您可以联系我们找货
