500-080-225-F02
500-080-225-F02
    板对板连接器 板边缘,通孔,直角 针脚数:80Pin 间距:2.5mm 排数:8
500-080-225-F02 数据手册
.X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. TOLERANCE UNLESS OTHERWISE SPECIFIED 1 ORIGINAL ±0.35 ±0.25 ±0.15 6 1.10 ROW HG (GROUND) ROW H ROW G ROW GG (GROUND) ROW FG (GROUND) ROW F ROW E ROW FG (GROUND) ROW DG (GROUND) ROW D ROW C ROW CG (GROUND) ROW BG (GROUND) ROW B ROW A ROW AG (GROUND) 1 5 RECOMMENDED PCB LAYOUT SCALE 2:1 4.50 (X3) LCP +30% GLASS REINFORCED, UL94V-0 COPPER ALLOY GOLD FLASH PLATING 80~160µ" ON SOLDER TAIL OVER NICKEL 50~150µ" UNDER PLATING -Y- 2.50 2.50 MATERIAL: HOUSING: CONTACT: 1.00±0.2 10 0.90 (X3) (X7) X Y 1.20 0.05 ALL PLATED THRU HOLES -X- 1.20 (X4) NOTES: Ø0.450 1.04 9X2.5=22.50 24.95 MAX. -X- 22.50 -Y- 27.90 REF. 4.50 2.50 1.50 4.00 ROW H 3.68 REF. 15.67 1.70 ROW D ROW C 19.35±0.08 21.35±0.08 ROW F ROW E 16.68 REF. ROW G 2.40 +0.2 10.20-0.1 ROW G ROW H ROW HG (GROUND) (X3) (X3) 1.20 (X3) ROW E ROW F ROW FG (GROUND) 1.10 1.20 (X3) 0.85±0.05 TOP SURFACE OF PCB 4.50 (X3) ROW C ROW D ROW DG (GROUND) "A" ROW AG (GROUND) ROW A ROW B ROW BG (GROUND) ROW B ROW A 17.84 MAX. 0.250±0.05 0.580±0.05 0.15 X Y DETAIL A SCALE 10:1 ACAD REFERENCE NO.: ZD+ CONNECTOR, FEMALE, RIGHT ANGLE, 4 PAIR DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 500-080-225-F02 DATE: JUNE.27 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 500-080-225-F02 ISSUE PART NUMBER: 500-080-225-F02 1
500-080-225-F02 价格&库存
很抱歉,暂时无法提供与“500-080-225-F02”相匹配的价格&库存,您可以联系我们找货
