500-080-231-B01
500-080-231-B01
    插件,P=2.5mm
    板对板连接器 插件 针脚数:80Pin 间距:2.5mm 排数:8
500-080-231-B01 数据手册
.X .XX .XXX ±0.25 ±0.15 ±0.10 TYP. ROW B ROW C ROW D 0.12 0.39 ROW E ROW F TYP. ROW DG (GROUND) 1.500 2.99 A B 19.65 23.4 MAX. ROW F 0.12 ROW BG (GROUND) ROW C ROW E ROW A A B TYP. 3.00 ROW B 5.68 REF. TYP. 1.50 2-C0.4 ROW A ROW D 1 ORIGINAL 2.50 6.40 2.50 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. TOLERANCE UNLESS OTHERWISE SPECIFIED ROW FG (GROUND) ROW G ROW G ROW H ROW H 0.03~0.08 0.03~0.08 ROW HG (GROUND) 0.75 REF. 25.00 MAX. 3.80 2.95 NOTES: 13.40 MATERIAL: HOUSING: SHIELD: 9 X 2.5 = 22.5 2.500 LCP+30% GLASS REINFORCED, UL94V-0 PHOSPHOR BRONZE NICKEL PLATING PHOSPHOR BRONZE GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING CONTACT: TYP. 10 0.05 6 5 TYP. ROW A ROW B ROW BG (GROUND) ROW C ROW D ROW DG (GROUND) ROW E ROW F ROW FG (GROUND) ROW G ROW H ROW HG (GROUND) 1.500 -Y- PCB HOLE DIM: DRILLED HOLE = 0.700±0.025mm FINISHED HOLE = 0.600±0.050mm Cu THICKNESS = 0.0375±0.0125mm SnPb THICKNESS = 0.007±0.003mm 1 X Y ALL PLATED THRU HOLES SCALE 2:1 -X- ACAD REFERENCE NO.: ZD CONNECTOR, MALE, VERTICAL, 4 PAIR DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 500-080-231-B01 DATE: JUNE.27 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 500-080-231-B01 ISSUE PART NUMBER: 500-080-231-B01 1
500-080-231-B01 价格&库存
很抱歉,暂时无法提供与“500-080-231-B01”相匹配的价格&库存,您可以联系我们找货
