500-080-231-H01
500-080-231-H01
    插件,P=2.5mm
    板对板连接器 插件 针脚数:80Pin 间距:2.5mm 排数:8
500-080-231-H01 数据手册
1.2REF. 4PLC 1.6REF. 2.5REF. TYP 24.9REF. 1.2REF. ±0.25 ±0.15 ±0.10 1 ORIGINAL 3.12REF. .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. TOLERANCE UNLESS OTHERWISE SPECIFIED 4PLC 3.6REF. 3PLC GROUND GROUND 0.9REF. 19.65REF. 23.35REF. 4.5REF. ROW E ROW F GROUND GROUND 15REF. ROW C ROW D 7.505REF. GROUND ROW A ROW B GROUND GROUND ROW G ROW H GROUND NOTES: 0.8REF. 5.3±0.1 2.95±0.05 MATERIAL: HOUSING: SHIELD: CONTACT: 6.35±0.2 13.4±0.08 2.5 X9= 22.5 LCP +30% GLASS REINFORCED, UL94V-0 PHOSPHOR BRONZE PHOSPHOR BRONZE GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING 30~100µ" ON SOLDER TAIL OVER NICKEL 50~150µ" UNDER PLATING 2.5 -Y- GROUND ROW A ROW B GROUND GROUND ROW C ROW D GROUND GROUND ROW E ROW F GROUND GROUND ROW G ROW H GROUND 17.1 0.9 PCB HOLE DIM: DRILLED HOLE = 0.550±0.020mm FINISHED HOLE = 0.460±0.050mm 3.6 Cu THICKNESS = 0.0375±0.0125mm Au THICKNESS = 0.007±0.003mm 1.2 10 1 1.2 Ni THICKNESS = 0.0044±0.0032mm OR Ag THICKNESS = 0.0003±0.002mm -X- Ø0.460±0.050 0.05 X Y ALL PLATED THRU HOLES ACAD REFERENCE NO.: ZD+ CONNECTOR, MALE, VERTICAL, 4 PAIR DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 500-080-231-H01 DATE: JUNE.27 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 500-080-231-H01 ISSUE PART NUMBER: 500-080-231-H01 1
500-080-231-H01 价格&库存
很抱歉,暂时无法提供与“500-080-231-H01”相匹配的价格&库存,您可以联系我们找货
