901-072-629-002
901-072-629-002
    72(36 x 2) 位置 SAS,迷你型 HD 插座(1x2) 连接器 焊接 表面贴装型
901-072-629-002 数据手册
2.0 PIN D1 COMPLIANT 0.300 24.160 22.560 10.34±0.10 6.000 PIN A10 PIN D10 0.75±0.05 PIN PITCH PIN A18 PIN D18 6.470 5.830 1.000 TOLERANCE UNLESS OTHERWISE SPECIFIED THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 3 4 INSERT MOLDING CONTACT LATCH 1 9 36 2 L.C.P GLASS REINFORCED, UL94 V-0 L.C.P GLASS REINFORCED, UL94 V-0 L.C.P GLASS REINFORCED, UL94 V-0 COPPER ALLOY STAINLESS STEEL SEE NOTES BLACK SEE NOTES SEE NOTES ±0.35 ±0.25 ±0.15 3 CAP 1 .X .XX .XXX 2 HOUSING TIN(MATTE)100~200 1 FINISH/COLOR 0.250 12.000 MATERIAL 6.250 11.425 NOTES: 22.850 µ" 0.10 ORIGINAL 2 1 ISSUE NUMBER UPDATE DRAWING Y.Z DEC.20/2018 900-072-629-002 DATE: 1 OF 2 ISSUE 1 JUNE.28 /2018 L.C.P GLASS REINFORCED, UL-94V-0 L.C.P GLASS REINFORCED, UL-94V-0, COLOR: BLACK L.C.P GLASS REINFORCED, UL-94V-0 STAINLESS STEEL, TIN (MATTE) 100~200" µ COPPER ALLOY 30 µ" GOLD PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING W.T DATE: 900-072-629-002 SHEET DRAWING NUMBER: 900-072-629-002 N.T.S PART NUMBER: SCALE: CHECKED: DRAWN: ACAD REFERENCE NO.: INSERT MOLDING: LATCH: CONTACT: MATERIAL: HOUSING: CAP: 4.030 QTY. Ø1.000 6.750 DESCRIPTION 14.170 0.635 3.920 0.250 NO. 5.000 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. MINI SAS HD INTERNAL, VERTICAL SMT, FEMALE, 72 CONTACTS 8.920 11.190 7.85±0.05 8.950 0.200 PIN A9 PIN D9 THE EUROPEAN UNION DIRECTIVES THIS SERIES FULLY CONFORMS TO 2011/65/EU FOR RoHS COMPLIANCY. 4.0±0.05 12.410 0.930 1.200±0.08 1.000 2.70±0.10 7.94±0.10 PIN A1 3.42
901-072-629-002 价格&库存
很抱歉,暂时无法提供与“901-072-629-002”相匹配的价格&库存,您可以联系我们找货
