902-072-225-002
902-072-225-002
    72(36 x 2) 位置 SAS,迷你型 HD 插座(1x2) 连接器 压配 通孔,直角
902-072-225-002 数据手册
TOLERANCE UNLESS OTHERWISE SPECIFIED 12.000 CL .X .XX .XXX CL ±0.25 ±0.15 ±0.10 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. ORIGINAL 1 NOTES: 9 9 1 MATERIAL: HOUSING: 11.95 14.05 1 CONTACT: COLOR: 4 0.70 1.40 2-6.000 PF 0.75 TYP L.C.P HIGH TEMPERATURE GLASS, UL-94V-0 COPPER ALLOY GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING BLACK 3.80 7.60 11.40 23.9 REF. KEEP COMPONENT OUT AREA 15.190 MIN. 2.660 MIN. A5 A6 A8 A7 B8 12.000 6.000 A9 A2 A3 A5 A8 B1 C1 D1 C2 C3 B4 B6 C5 B7 C8 D2 D3 C4 C6 D5 C7 D8 D4 D6 D7 B9 C9 B1 C1 D1 B2 B3 A4 A6 B5 A7 B8 C2 C3 B4 B6 C5 B7 C8 D2 D3 C4 C6 D5 C7 D8 D4 D6 D7 C9 D9 0.700 1.400 CL B9 CL D9 A1 A9 3 26.15 27.660 24.000 12.000 B2 B3 A4 B5 0.750 1.500 2.250 A1 A2 A3 Ø0 .37 0± 0.0 5 7.300±0.15 2.650 MIN. 00 Ø2.2 5 ±0.0 1.450 3.800 7.600 11.400 2 DETAIL W SCALE 8:1 1 RECOMMENDED PCB LAYOUT (TOP VIEW) TOLERANCE=±0.05mm ACAD REFERENCE NO.: MINI SAS HD INTERNAL, RIGHT ANGLE PRESS FIT, 72 CONTACTS, FEMALE COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DRAWN: W.T CHECKED: SCALE: 902-072-225-002 DATE: JULY.03 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 902-072-225-002 ISSUE PART NUMBER: 902-072-225-002 1
902-072-225-002 价格&库存
很抱歉,暂时无法提供与“902-072-225-002”相匹配的价格&库存,您可以联系我们找货
  • 1152+76.539401152+9.81780
