AD-EL-2402000
AD-EL-2402000
    EDGELIGHT(边光)
    HIGH POWER 200W LED DRIVER
AD-EL-2402000 数据手册
电源产品规格书 Power supply product specification 产品名称:200W—LED 驱动条形电源 Product Name: 200W—LED Strip Power Supply 产品型号: AD-EL-2402000 Product Item: AD-EL-2402000 Shanghai Edgelight Industry Co.,Ltd. TEL:+86-21-64412288 FAX:+86-21-64412266 E-mail: info@edgelight.com 1、产品简介 Product Introductions AD-EL-2402000 · 电气类型:隔离电源 Electrical type: Isolated power supply · 功能说明:全电压(半电压)无频闪 Function description: Full voltage (half voltage) without stroboscopic · 产品特性:SELV 全电压范围内工作,高 PF 值、高性能,高效率,可以连接我司 three-in-one 调光控 制器构成 pwm/0-10v/resistor 调光电源 Product features: SELV working in full voltage range, high PF value, high performance, high efficiency, can be connected to our three-in-one dimming controller to form pwm/0-10v/resistor dimming power supply · 应用领域:LED 照明领域 Application area:LED lighting field · 质保:参见产品寿命曲线 Warranty: To refer product life curve · 认证: Certification: 2、电气规格 Electrical specifications 指标 Index 型号全称 AD-EL-2402000 Full name of model 输出特性 输出电压 Output Output voltage characteristic 输出电流 24V Output current 6.66A @100-120Vac 纹波电压+噪音(峰 400mV(Vp-p) 8.33A@200-240Vac 峰值) Ripple voltage + noise(peak-to-pe ak) 电压精度 ±1% Voltage accuracy 启动时间(最大值) <500ms Start time (maximum) 温度漂移 ±0.03%/℃(0-60℃) Temperature drift 输出线性调整率 ±2% Output linear adjustment rate 负载调整率 ±2% Load regulation rate 保持时间 100ms Preserve time 输入特性 输入电压 Input Input voltage characteristics 输入频率 100VAC~240VAC 50HZ/60HZ Input frequency 输入电流(最大值) 1.9A @ 100Vac Input current (maximum) 漏电流 0.8mA ±0.03%/℃(0-60℃) Leakage current 总谐波 <25% Total harmonic 功率因数 >0.9 Power factor 效率 92% Efficiency 浪涌电流 冷启动 40A @230Vac Surge current Cold start 40A @230Vac 空载功耗/待机功耗 1W No-load power consumption / standby power consumption 保护特性 过流保护 Protection Over current characteristics protection 短路保护 12A 有 yes Short circuit protection 工作温度 环境描述 Operating Environmental temperature description 工作湿度 Tcase=-20℃-50℃ 20-95%RH,无冷凝 Working humidity 存储温度-湿度 -20℃-50℃ 10-95%RH Storage temperature-hum idity 大气压强 86-106KPa Atmospheric pressure 安全及规范 认证 Safety and Certification regulation 耐压 CE、CB、UL-8750+Class P I/P-O/P:3KVAC Pressure resistant 绝缘阻抗 Insulation resistance I/P-O/P, I/P-FG,O/P-FG:100MΩ/500Vdc/70%RH 电磁兼容干扰 Electromagnetic compatibility interference 符合 EN55015、EN61000-3-2、EN61000-3-3,EN61547 标 准要求 Meets EN55015, EN61000-3-2, EN61000-3-3, EN61547 requirements 电磁兼容抗干扰 EN61000-3-2,EN61000-3-3,EN61547 标准要求 Electromagnetic EN61000-3-2, EN61000-3-3, EN61547 standard compatibility requirements anti-jamming 其他 包装 净重量约 261g,包装: 净重量 261g,包装: others Package 330g*60pcs,19.8kg 330g*60pcs,19.8kg The net weight is about Net weight 261g, 261g, packaging: packaging: 330g*60pcs, 330g*60pcs, 19.8kg 19.8kg 尺寸 500*30*17mm size IP 等级说明 IP20 IP Level description 质保说明 ≥2 年,参见寿命曲线 ≥2 年,参见寿命曲线 Warranty ≥ 2 years, refer to life curve ≥ 2 years, refer to life curve description 测试设备 LCR METER: TH2830, fluke 数字万用表,电子负载:PEL-3041,交流源:远方 Test PPS1010、功率分析仪:Ainuo,数字示波器:SDS3034E,传导分析仪:远方 LS-3、 Equipment FFT3030,接地电阻测试仪:MS2520C 型,耐压测试仪:TH9320,烤箱,电脑监控 老化测试系统。 LCR METER: TH2830, fluke digital mult imeter, electronic load: PEL-3041, AC source: remote PPS1010, power anal yzer: Ainuo, digital oscilloscope: SDS3034E, conduction analyzer: remote LS-3, FFT3030, ground resistance tester: MS2520C Type, withstand voltage tester: TH9320, oven, computer monitoring aging test system. 测试说明 纹波电压测试方法:示波器探头设置 AC,带宽设置 20M,在输出端并接 10uF 电解电 Test 容/100nF 贴片电容。除温升测试项目外,其余测试温度均在 25℃,230Vac 条件下。 instruction Ripple voltage test method: The oscilloscope probe is set to AC, the bandwi dth is set to 20M, and 10uF electrolytic capacitor/100nF chip capacitor is con nected at the output end. Except for the temperature rise test project, the rest of the test temperature is at 25℃, 230 Vac. 3、产品寿命 Product life span 在一个密闭空间内,当环境温度达到 30℃,40℃,50℃,60℃,70℃时,计算产品使用寿命 In a confined space, when the ambient temperature reaches 30 ° C, 40 ° C, 50 ° C, 60 ° C, 70 ° C, Calculate product life 4、输出负载 VS 环境温度 5、静态特性曲线 Output load VS ambient temperature Static characteristic curve 6、功率因素特性曲线 7、总谐波失真特性曲线 Power factor characteristic curve Total harmonic distortion characteristic curve 8、效率 VS 负载 Efficiency vs load 9、结合调光器使用连接图 Use the connection diagram with the dimmer 三合一调光功能: 在 DIM+和 DIM-间连接一个电阻或连接 0-10V 直流电压或 PWM 信号,即可调整输出恒电流的数值。 Vo+和 Vo-之间直接连接 12V 或者 24V 的 LED 灯条或灯带。 Three-in-one dimming function: The output constant current value can be adjusted by connecting a resistor or connecting a 0-10V DC voltage or PWM signal between DIM+ and DIM-. A 12V or 24V LED strip or strip is directly connected between Vo+ and Vo-. 实物图连接如下: The material is connected in the picture as follows: 调光功能说明: Dimming function description: 1.0-10V 调光: 调光范围 0%-100% 0-10V light modulator: light modulator range 0%-100% 调光电压 Dimming voltage 额定电流百分比 Rated current percentage 0V 1V 2V 3V 4V 5V 6V 7V 8V 9V 10V OPEN 关 12.5 17% 30% 40% 49% 61% 73% 80% 83% 91% 95%-1 断 % 05% 2.电阻调光: 调光范围 10%-100%,电阻阻值范围: 2KΩ-20kΩ Resistance dimming: Dimming range 10%-100%, resistance range: 2KΩ-20kΩ 调光电阻阻值 Light modulator resistance 2kΩ 4kΩ 6kΩ 8kΩ 10k Ω 12k Ω 14k Ω 16kΩ 18k Ω 20kΩ OPEN 额定电流百分比 Rated current percentage 6% 17% 26% 37% 46% 57% 68% 79% 95% 99.5 % 95%-1 05% 3.PWM 调光: 调光范围 10%-100%,采用幅值为 10V,频率为 500Hz-5KHz 的 PWM 信号调节 PWM dimming:dimming range 10%-100%, PWM signal adjustment with amplitude of 10V and frequency of 500Hz-5KHz PWM 信号占 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% OPEN 5% 17% 30% 40% 50% 60% 70% 80% 90% 100% 95%-10 空比 PWM signal duty cycle 额定电流百分 比 Rated current percentage 5% 8、外观尺寸 Exterior dimension 9、铭牌 Label
AD-EL-2402000 价格&库存
很抱歉,暂时无法提供与“AD-EL-2402000”相匹配的价格&库存,您可以联系我们找货
