57809
57809
    GREENLITE
    GREEN CREATIVE PAR38 LED
57809 数据手册
PAR38 14W DIM. CORE LED SERIES 14W REPLACES 90W Hal. CORE 80% Energy Savings Wet location rated for outdoor use Lightweight environmentally friendly construction Full-face optic: maximizes distribution, minimizes glare High 75 LPW in Warm White Smooth dimming on existing dimmers FL beam angle in Soft White & Warm White CCT $261 75 25,000 H DIMMABLE 3 TM 21 Savings per lamp* 80 YR IES WARRANTY SEMI ENCLOSED** DESIGNEDFOR SUITABLE FORALL COMMERCIAL DIRECTIONAL APPLICATIONS APPLICATIONS www.greencreative.com / info@greencreative.com - Tel / Fax: (866) 774-5433 - / GREENCREATIVELED / GClightingLED / GREEN CREATIVE Ref.#:DS114-PAR38-14W PAR38 14W DIM. CORE LED SERIES ILLUMINANCE & CANDELA DISTRIBUTION 14PAR38DIM/830FL40 Diameter Footcandles 3' 2.2 211 6' 4.4 53 9' 6.6 23 12' 8.7 13 15' 10.9 8 90° Degree Candela 0 2000 60° 30° 0° 5 1924 15 1302 25 423 35 97 45 50 For other CCT use the following multipliers: 2700K .95 Base: E26 Voltage: 120V Dimmable: Yes*** PF: 0.9 Lifetime: 25,000 hrs Weight: 0.44lb / 200g 5.12"(130mm) 4.76"(121mm) SPECIFICATIONS Product Power (W) 14PAR38DIM/827FL40 57807 14 14PAR38DIM/830FL40 57809 14 Model CRI (typ.) Lumens LPW Beam Angle CBCP (cd) Soft White 2700K 80 1000 71 FL 40° 1900 Warm White 3000K 80 1050 75 FL 40° 2000 CCT * Savings per lamp based on $0.11 / kw energy cost, 12 hrs / day lamp usage, $8 halogen with 1500-hr lifetime, $25 LED with 25,000-hr lifetime ** Not intended for use in totally enclosed fixtures *** List of tested dimmer switches available on website **** Suitable for use in wet locations
57809 价格&库存
很抱歉,暂时无法提供与“57809”相匹配的价格&库存,您可以联系我们找货
