EA W202B-NLW
EA W202B-NLW
    ELECTRONICASSEMBLYGMBH
    LCD MOD 40DIG 20X2 TRANSFLCT WHT
EA W202B-NLW 数据手册
ELECTRONIC ASSEMBLY making things easy blue line The Blue Displays THE NEW LOOK ! Blue displays with white character: „At last an alternative for the yellow/green standard displays“ many customers are pleased. Of course: a fine display helps selling an equipment. The excellent contrast and the wide viewing angle make the people convinced immediately. What’s the secret of these new displays? The base are the built-in super bright white LED dies. But to result an uniform and bright backlight you do need a figured out light guide, too. The blue color and the wide viewing Pinbelegung angle came from a special polarisor for Pin Symbol Pegel Beschreibung the STN cell. 1 VSS L Versorgung 0V, GND 2 VDD H Versorgung +5V Thanks to this high efficienct 3 VEE Di spl ayspannung 0..0,5V construction a 2x16 lcd requires 4 RS H/L Regi ster Sel ect 5 R/W H/L H: Read / L: Wri te 15~60mA only. Additionally we provide 6 E H Enabl e 7 D0 H/L Datenl ei tung 0 (LSB) an ultra low power version with 1 LED chip for 2mA, too! Remember: 8 D1 H/L Datenl ei tung 1 yellow/green displays do need 100mA and more. Nevertheless 9 D2 H/L Datenl ei tung 2 10 D3 H/L Datenl ei tung 3 BlueLine displays are better readable than traditional yellow/green 11 D4 H/L Datenl ei tung 4 12 D5 H/L Datenl ei tung 5 displays - except in direct sunlight. 13 D6 H/L Datenl ei tung 6 14 D7 H/L Datenl ei tung 7 (MSB) 15 LED + - LED-Versorgung Pl us /Vorwi derstand! LOW POWER EA DIP162-DN3LW The low power consumption save money for power supply. And because of the small heat of backlight there are much less problems to solve with self-heating of device. That is why standard temperature range of 20..+70°C is enough normally. Even life time of white LED chip is limited, these displays can be used or industrial equipment. If operation around the char. char. height outline dim. ordering information 1x16 9,66mm 122x33mm EA W161B-ENLW clock is necessary, backlight can be switched off or dimmed easily. You 2x16 5,55mm 80x36mm EA W162B-N3LW 2x16 5,55mm 84x44mm EA W162B-NLW do not need any inverter or interface unit. All displays are absolute 2x16 9,66mm 122x44mm EA W162B-BNLW 2x20 5,55mm 116x37mm EA W202B-NLW compatible with market standard HD44780. Interface is 4- or 8- bit data 2x20 12,7mm 190x54mm EA E202-CNLW 2x24 5,55mm 118x36mm EA W242B-NLW bus. Optional you can have 2x40 5,55mm 182x33mm EA W402B-NLW 4x16 4,75mm 87x60mm EA W164B-NLW all displays with integrated 4x20 4,75mm 98x60mm EA W204B-NLW 4x40 4,89mm 190x54mm EA W404B-NLW RS-232 interface. Also all 128x64 Grafik 93x70mm EA W128B-6N2LW 160x128 Grafik 129x102mm EA W160-7KHLW graphic displays do have 240x64 Grafik 180x65mm EA W240-6KH2LW 240x128 Grafik 144x104mm EA W240-7KHLW built-in graphic controller ... weitere Displays auf Anfrage like KS0107, or T6963. We offer them with and without RS-232 interface. Order your favorite display now! The whole range of various sizes is available ex stock usually. 16 LED - - LED-Versorgung Mi nus NEED MORE INFORMATIONS? all dimensions in mm At our web site you’ll find more informations and the complete data sheet: www.lcd-module.de/blueline Or fax following inquiry: Company ................................................................................................. Street ....................................................................................................... Postal code / city .................................................................................... Phone / Fax ............................................................................................. making things easy Lochhamer Schlag 17 D-82166 Graefelfing Phone +49- (0)89- 854 1991 Fax +49- (0)89- 8541721 info@lcd-module.de Printed: April 2005 Printing error reserved. Your name ..............................................................................................
EA W202B-NLW
1. 物料型号:EA W161B-ENLW, EA W162B-N3LW, EA W162B-NLW, EA W162B-BNLW, EA W202B-NLW, EA E202-CNLW, EA W242B-NLW, EA W402B-NLW, EA W164B-NLW, EA W204B-NLW, EA W404B-NLW, EA W128B-6N2LW, EA W160-7KHLW, EA W240-6KH2LW, EA W240-7KHLW, EA DIP162-DN3LW。
2. 器件简介:文档介绍了BlueLine品牌的LCD显示屏,具有新的亮度和对比度,使用内置的超亮白光LED灯珠和特殊的STN单元偏振器,提供宽视角和蓝色背景。
3. 引脚分配:文档列出了LCD模块的引脚分配表,包括电源、地、显示电压、寄存器选择、读写选择、使能、数据输入等。
4. 参数特性:文档提到了LCD模块的功耗,标准2x16 LCD模块的功耗为15~60mA,还提供了超低功耗版本,使用1个LED芯片,功耗仅为2mA。
5. 功能详解:文档解释了LCD模块的工作原理,包括如何通过简单的操作来控制背光的开关或调光,以及与市场标准HD44780的兼容性。
6. 应用信息:文档提到这些LCD模块可以用于工业设备,如果需要24小时运行,可以轻松地关闭或调暗背光。
7. 封装信息:文档列出了不同尺寸和分辨率的LCD模块的订购信息和尺寸。
EA W202B-NLW 价格&库存
很抱歉,暂时无法提供与“EA W202B-NLW”相匹配的价格&库存,您可以联系我们找货
