EA 4SGD24-M
EA 4SGD24-M
    ELECTRONICASSEMBLYGMBH
    VOLTMETER 0-40VDC LCD PANEL MT
EA 4SGD24-M 数据手册
    Multi purpose color DVM Order number: EA 4SGD24-M Short description: multi purpose / color graphic- digit voltmeter module; digit height mm (2.4" TFT); input range 0 bis +40 V; 2 channel; bargraph, supply +4 to +30V dc;; integrated snap-in bezel for easy panel mounting The SGD 24-M is a programmable panel meter featuring dual analogue inputs, alarm outputs and 2.4” TFT colour touchscreen display. Configured using the free PanelPilot M Software, choose from an everincreasing number of configurations including bar-graph, tank level, analogue style and trend graphs. Then customise colours, text labels, units and input scaling before uploading to a display via USB. TOTAL WIDTH [mm] TOTAL HEIGHT [mm] TOTAL THICKNESS [mm] PIXEL COUNT IN X-DIRECTION PIXEL COUNT IN Y-DIRECTION SCREEN SIZE (DIAGONAL) [INCH] SUPPLY VOLTAGE DATA INTERFACE POWER CONSUMPTION WITH BACKLIGHT [mA] OPERATING TEMPERATURE CHARACTER FORMAT DISPLAY TECHNOLOGY BACKLIGHT DISPLAY COLOR BACKLIGHT COLOR TOUCHPANEL TYPE TERMINAL 76.5 48.5 18 320 240 2.4 5V, 9V USB 100 0 ... +40 °C negative TFT Color with backlight RGB weiss analog resisitive screw terminal                                                      https://shop.lcd‐module.com/multi‐purpose‐color‐dvm.html 12‐15‐17
EA 4SGD24-M 价格&库存
很抱歉,暂时无法提供与“EA 4SGD24-M”相匹配的价格&库存,您可以联系我们找货
