ED-2204-2e
DH-G series Electoric Double Layer Capacitor "DYNACAP"
5.5V Wider Temperature range Capacitors
GREEN
85°C
The wetprooting is improved by wearing the resin court to the sealing part.
Wider temperature range (-40°C to +85°C) than battery.
φ13.5×9.8L size can encase up at 0.22F.
Advanced in rapid charge and dischage.
Ideal for backing up of CMOS IC's, microcomputers, RAM's, RTC's and
the like used in Electric power meter, Outdoor installation equipment,
Automotive applications, Industrial equipment
Specifications
Item
Performance
Category temperature range(°C)
-40 to +85
Tolerance at rated capacitance(%)
-20 to +80
Internal resistance at 1kHz(Ω)
Rated capcitance(F)
0.047
0.1
0.22
Internal resistance(Ω)
40
40
40
Percentage of capacitance change
Within ±30% of the value at 20℃
Characteristics at high
and low temperature
Internal resistance
-40°C : Less than 7 times of the value at 20°C
85°C: L ess than 5 times of the value at 20°C
Test time
1000 hours
Endurance(85°C)
Within ±30% of the initial measured value
Internal resistance
Within 4 times of the intial specified value
Shelf life(85°C)
Test time:1000 hours;Same as endurance.
Applicable standards
Conform to JIS C 5160-1 2009
Part numbering system(example:5.5V0.1F)
Outline Drawing
DHL
Series code
5R5
D
Max.operating
voltage symbol
104
GT
Rated capacitance
symbol
Part number is refer to below tabale.
Caution for Cleaning after Soldering
・Recommended cleaning method
(1)cleaning solutions:
(a) CLEANTHROUGH 710M, 750H,
750L
(b) PINEALPHA ST-100S
(c) Techno Care FRW-4~17
(d) Isopropyl alcohol (2-propanol)
(2)Cleaning conditions:
(a) The temperature of cleaning solution shall be less than 60°C.
(b) Use immersion or ultrasonic waves within two minutes.
(c) After cleaning, capacitors and PCB’s shall thoroughly be rinsed and
dried with hot blast for more than 10 minutes. The temperature of such
breeze should be less than the upper category temperature.
(d) After cleaning, do not keep capacitors in cleaning solution atmosphere
or airtight containers.
• During cleaning, control the cleaning solution against contamination.
Standard Ratings
Max operating voltage(V)
Rated capacitance(F)
ELNA Parts No.
φD×L (mm)
5.5
0.047
DHL-5R5D473GT
13.5×9.8
5.5
0.1
DHL-5R5D104GT
13.5×9.8
5.5
0.22
DHL-5R5D224GT
13.5×9.8
NOTE
ELNA CO., LTD.
Design,Specifications are subject to change without notice.
3-8-11 Shin-yokohama,kouhoku-ku,yokohama-city,kanagawa,222-0033 JAPAN
Ask factory for technical specifications before purchase and/or use.
TEL. +81-45-470-7254 FAX. +81-45-470-7260
ELNA Co.,LTD.
http://www.elna.co.jp/
RSCHL2245R5G09014GT 价格&库存
很抱歉,暂时无法提供与“RSCHL2245R5G09014GT”相匹配的价格&库存,您可以联系我们找货
