Elna Confidential
ELECTRIC DOUBLE LAYER CAPACITORS
ED-1203
High reliability, Safe and unlike secondary batteries, this is pollution free devices.
RoHS Compliant.
ELAN P/N: DSK-3R3E224U-E
Spec sheet
Item
Performance
Category temperature
range (deg C)
Rated Voltage (V)
-10 to +60
3.3
Rated Capacitance (F)
Tolerance at
rated capacitance (%)
Internal resistance
(ohm max.)
20deg C,1kHz
0.22
(20deg C)
-20 to +80
(20deg C)
200
Characteristics at high
and low temperature
Capacitance change
Internal resistance
Within -50% to +50% at 20deg C
Less than five times of the initial specified value
Endurance(60deg C)
Test time
Percentage of capacitance change
Internal resistance
500hours
Within -30% to +30% of initial value
Less than 800 ohm
Shelf life(60deg C)
Test time
Capacitance change
Internal resistance
500hours
Less than 800 ohm
Applicable standards
Conforms to JIS C5160-1 (IEC 62391-1 )
ELNA part numbering system
DSK
Series code
3R3
E
Rated voltage
symbol
224
U
Rated
capacitance
symbol
Additional
symbol
E
Terminal
shaped
Outline drawing
φD
L
(mm)
6.8
2.1
Unit : mm
(Note) It is recommended that you shall obtain technical specifications from ELNA CO., LTD. to ensure that the component is suitable for your intended use.
ELNA CO., LTD.
http://www.elna.co.jp/
Kyobashi East Bldg 9F, 2-7-19, Kyobashi, Chuo-ku, Tokyo 104-0031, Japan
TEL:03-4221-4950 FAX:03-4221-4951
很抱歉,暂时无法提供与“RSCSK2243R3D02011U”相匹配的价格&库存,您可以联系我们找货
