B14HD-254-B-4
B14HD-254-B-4
    JOHNSON
    占空比螺线管 开放框架(拉) 型 行程 底座安装
B14HD-254-B-4 数据手册
LINEAR Open Frame Part Number: B14HD - 2 XX - B- X VDC Battery Powered Long Life All products are RoHS Compliant 4 - 10 Inch (254 mm) leads 6 - Terminals Coil Selection (from performance chart below) 2 - Conical Pole Configuration Specifications Typical Force @ 20°C Operation Pull Dielectric Strength 1000 VRMS for one second Continuous Duty Cycle 100% at 20°C ambient temperature Intermittent Duty Cycle See below Holding Force 6.38 lbs (28.4 N) at 20°C Coil Insulation Class “ B”: 130°C max. + – Coil Termination 10" (254 mm) PVC lead wires or High Long Magnetic Miniature Quiet Speed Life Latching Sizeterminal Performance Plunger Weight 0.86 oz. (24.4 g) Total Weight 3.47 oz. (98.4 g) + – Magnetic Latching 10.0 (44.5) 8.0 (35.6) Quiet Miniature Performance Size Performance Maximum Duty Cycle 100% 50% 25% 10% Maximum ON Time (sec) when pulsed continuously ∞ 100 27 7 Maximum ON Time (sec) for single pulse ∞ 326 100 28 Watts (@ 20°C) 5.5 11 Ampere Turns (@ 20°C) 663 938 22 55 Resistance Ref # VDC VDC VDC VDC (@20°C) Turns (Nom) (Nom) (Nom) (Nom) B14HD-258-B-X B14HD-257-B-X B14HD-256-B-X B14HD-254-B-X B14HD-253-B-X 1.45 7.0 14.2 27.5 110.2 ■ 10% Duty Cycle 55W ■ 25% Duty Cycle 22W ■ 50% Duty Cycle 11W ■ 100% Duty Cycle 5.5W 6.0 (26.7) 4.0 (17.8) 2.0 (8.9) 1326 2097 Coil Data Part Number Force - lbs (N) h d Ledex® Box Frame Size B14HD 321 3.0 4.3 6.1 9.7 750 6.0 8.7 12.4 19.6 1068 9.0 12.5 17.6 27.9 1470 12.0 17.4 24.6 38.9 2920 24.0 34.8 49.2 77.8 NOTES: 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heat sink. 4. Pull versions standard; push versions available. 5. Magnetic latching version available. 0 0 0.1 (2.54) 0.3 (7.62) Stroke - in (mm) 0.4 (10.16) 0.5 (12.7) How to Order Select the part number from the table provided. (For example, to order a 25% duty cycle unit rated at 6.1 VDC with 10" lead wires, specify B14HD-258-B-4. Please see www.ledex.com for our list of stock products available through our North American distributors. All specifications subject to change without notice. Ledex® Solenoids 0.2 (5.08) Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Ledex® Box Frame Size B14HD Inches (mm) Dimensions All solenoids are illustrated in energized state 2.12 ± 0.02 (53.8 ± 0.5) Lead Wire Models 6-32 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 1.214 ± 0.016 (30.84 ± 0.41) Ø0.157 (4.00) Ø0.394 ± 0.003 (10.00 ± 0.08) 0.315 ± 0.008 (8.0 ± 0.20) 0.787 ± 0.008 (20.00 ± 0.20) 0.138 ± 0.005 (3.51 ± 0.13) 0.319 ± 0.010 (8.10 ± 0.25) 0.787 ± 0.008 (20.00 ± 0.20) M4 - 0.7 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 0.820 ± 0.016 (20.84 ± 0.41) 10.0 (254) Min. Length to Frame 1.46 ± 0.14 (37.0 ± 3.6) 0.118 ± 0.010 (3.00 ± 0.25) 1.024 ± 0.006 (26.00 ± 0.15) 0.662 ± 0.17 (16.82 ± 0.43) Ø0.118 ± 0.002 (3.00 ± 0.05) 2.12 ± 0.02 (53.8 ± 0.5) Terminal Connection Models 6-32 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 1.214 ± 0.016 (30.84 ± 0.41) Ø0.157 (4.00) Ø0.394 ± 0.003 (10.00 ± 0.08) 0.315 ± 0.008 (8.0 ± 0.20) 0.787 ± 0.008 (20.00 ± 0.20) 0.138 ± 0.005 (3.51 ± 0.13) 0.319 ± 0.010 (8.10 ± 0.25) 0.373 (9.48) Ref. to Bobin Flange 0.787 ± 0.008 (20.00 ± 0.20) 0.820 ± 0.016 (20.84 ± 0.41) M4 - 0.7 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 0.020 ± 0.003 (0.51 ± 0.08) Terminal Thickness 1.46 ± 0.14 (37.0 ± 3.6) 0.24 (6.0) Max. Engagement 0.118 ± 0.010 (3.00 ± 0.25) 0.55 ± 0.20 (13.9 ± 5.1) 1.024 ± 0.006 (26.00 ± 0.15) 0.662 ± 0.17 (16.82 ± 0.43) Terminal Mates with DIN 46247 Ledex® Solenoids 0.110 ± 0.005 (2.79 ± 13) Ø0.118 ± 0.002 (3.00 ± 0.05) www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624
B14HD-254-B-4 价格&库存
很抱歉,暂时无法提供与“B14HD-254-B-4”相匹配的价格&库存,您可以联系我们找货
B14HD-254-B-4
  • 1+815.947251+104.73655
  • 10+726.6093010+93.26896
  • 25+693.7867725+89.05580
  • 50+669.9295150+85.99343
  • 100+646.87924100+83.03466
库存:418
