Ledex® Magnetic Latching Box Frame Size B14HD-L
VDC
Battery
Powered
gh
ed
Long
Life
4 - 10 Inch (254 mm) leads
6 - Terminals
Pole Configuration
1 - Flat Face
2 - Conical
Specifications
Typical Force @ 20°C – Conical (net with spring)
Operation Pull
Dielectric Strength
1000 VRMS for one second
Unlatch Voltage
See schematic and coil data below
Magnetic Holding Force* Conical: 8.7 lb (38 N)
Flat Face: 12.6 lb (56 N)
Coil Insulation +
Class “ B”: 130°C max.
HighTermination
Long
Magnetic
Miniature
Quietmm) PVC lead wires or
Coil
10"Performance
(254
Speed
Life
Latching
Size
terminal
Plunger Pole Face
Flat face or conical
Plunger Weight 0.86 oz. (24.4 g)
Total
Weight
3.47 oz. (98.4 g)
Quiet
Magnetic
Miniature
*Latching
In
no power,
latched
position,
with return spring
Performance
Size
12.0
(53.4)
10.0
(44.5)
6.0
(26.7)
4.0
(17.8)
2.0
(8.9)
Unlatch
Quiet
Miniature
Maximum
Duty Cycle Voltage 50%
Performance
Size
Recommended Max ON Time (sec)
1
1
25%
10%
1
1
Watts (@ 20°C) 11 11 22 55
Ampere Turns (@ 20°C)
940
938
Resistance Ref # VDC VDC VDC VDC
(@20°C) Turns (Nom) (Nom) (Nom) (Nom)
B14HD-L-X58-B-X 1.45
B14HD-L-X57-B-X 7.0
B14HD-L-X56-B-X 14.2
B14HD-L-X54-B-X 27.5
B14HD-L-X53-B-X 110.2
321 4.4 4.3 6.1 9.7
750 8.9 8.7 12.4 19.6
1068 12.7 12.5 17.6 27.9
1470 17.7 17.4 24.6 38.9
2920 35.4 34.8 49.2 77.8
0.2
(5.08)
0.3
(7.62)
Stroke - in (mm)
0.4
(10.16)
0.5
(12.7)
16.0
(71.2)
1326 2097
Coil Data
Part Number
0.1
(2.54)
Typical Force @ 20°C – Flat Face (net with spring)
Force - lbs (N)
Magnetic
Latching
■ 10% Duty Cycle 55W
■ 25% Duty Cycle 22W
■ 50% Duty Cycle 11W
8.0
(35.6)
Performance
All products are RoHS Compliant
Coil Selection (from performance chart below)
Force - lbs (N)
LINEAR Open Frame
Part Number: B14HD - L - X XX - B- X
12.0
(53.4)
8.0
(35.6)
4.0
(17.8)
NOTES:
1. All data is typical.
2. Force testing is done with the solenoid in the
horizontal position.
3. All data reflects operation with no heat sink.
(1.27)
0.1
(2.54)
0.15
(3.81)
Stroke - in (mm)
0.2
(5.08)
0.25
(6.35)
How to Order
Select the part number from the table provided. (For
example, to order a 25% duty cycle unit with a conical
pole configuration rated at 6.1 VDC with 10" lead wires,
specify B14HD-L-258-B-4.
Please see www.ledex.com for our list of stock products
available through our North American distributors.
(Red)
Coil Polarity
Latch:
A
A+ B-
Unlatch: A- B+
B
(Black)
All specifications subject to change without notice.
Ledex® Solenoids
Force values for reference only.
www.ledex.com
1.937.454.2345
Fax: 1.937.898.8624
Max.
0.5
(12.7)
Inches (mm)
Dimensions
All solenoids are illustrated in energized state
2.12 ± 0.02
(53.8 ± 0.5)
Lead Wire Models
6-32 Thd Typ (4)
(2 Holes This Side; 2 Holes Opposite Side)
1.214 ± 0.016
(30.84 ± 0.41)
Ø0.157
(4.00)
Ø0.394 ± 0.003
(10.00 ± 0.08)
0.315 ± 0.008
(8.0 ± 0.20)
0.787 ± 0.008
(20.00 ± 0.20)
0.138 ± 0.005
(3.51 ± 0.13)
0.319 ± 0.010
(8.10 ± 0.25)
0.787 ± 0.008
(20.00 ± 0.20)
M4 - 0.7 Thd Typ (4)
0.820 ± 0.016
(20.84 ± 0.41)
10.0
(254)
Min. Length
to Frame
1.46 ± 0.14
(37.0 ± 3.6)
B - Black
1.024 ± 0.006
(26.00 ± 0.15)
A - Red
0.662 ± 0.17
(16.82 ± 0.43)
Ø0.118 ± 0.002
(3.00 ± 0.05)
2.12 ± 0.02
(53.8 ± 0.5)
Terminal Connection Models
6-32 Thd Typ (4)
1.214 ± 0.016
(30.84 ± 0.41)
Ø0.157
(4.00)
Ø0.394 ± 0.003
(10.00 ± 0.08)
0.315 ± 0.008
(8.0 ± 0.20)
0.787 ± 0.008
(20.00 ± 0.20)
0.138 ± 0.005
(3.51 ± 0.13)
0.319 ± 0.010
(8.10 ± 0.25)
0.787 ± 0.008
(20.00 ± 0.20)
0.820 ± 0.016
(20.84 ± 0.41)
0.373 (9.48)
Ref. to
Bobin Flange
0.020 ± 0.003
(0.51 ± 0.08)
Terminal Thickness
1.46 ± 0.14
(37.0 ± 3.6)
0.24 (6.0)
Max. Engagement
0.118 ± 0.010
(3.00 ± 0.25)
B
A
0.55 ± 0.20
(13.9 ± 5.1)
1.024 ± 0.006
(26.00 ± 0.15)
0.662 ± 0.17
(16.82 ± 0.43)
Terminal Mates
with DIN 46247
Ledex® Solenoids
0.110 ± 0.005
(2.79 ± 13)
Ø0.118 ± 0.002
(3.00 ± 0.05)
www.ledex.com
1.937.454.2345
Fax: 1.937.898.8624
很抱歉,暂时无法提供与“B14HD-L-257-B-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+659.148311+85.27090
