LINEAR Open Frame
Part Number: B14HDP - 2 XX - B- X
VDC
Battery
Powered
Long
Life
All products are RoHS Compliant
4 - 10 Inch (254 mm) leads
6 - Terminals
Coil Selection (from performance chart below)
2 - Conical Pole Configuration
Specifications
Typical Force @ 20°C
Operation Push
Dielectric Strength
1000 VRMS for one second
Continuous Duty Cycle 100% at 20°C ambient temperature
Intermittent Duty Cycle See below
Holding Force
6.38 lbs (28.4 N) at 20°C
Coil Insulation
Class “ B”: 130°C max.
Coil
Termination
10" (254
mm) PVC lead wires or
High
Long
Magnetic
Miniature
Quiet
Speed
Life
Latching
Sizeterminal
Performance
Plunger Weight 0.91 oz. (25.8 g)
Total Weight
3.53 oz. (100.1 g)
Magnetic
Latching
10.0
(44.5)
8.0
(35.6)
Quiet
Miniature
Performance
Size
Performance
Maximum Duty Cycle
100%
50%
25%
10%
Maximum ON Time (sec)
when pulsed continuously
∞ 100 27 7
for single pulse
∞ 326 100 28
Watts (@ 20°C)
5.5
11
Ampere Turns (@ 20°C)
663
938
22
55
Resistance Ref # VDC VDC VDC VDC
(@20°C) Turns (Nom) (Nom) (Nom) (Nom)
B14HDP-258-B-X 1.45
B14HDP-257-B-X 7.0
B14HDP-256-B-X 14.2
B14HDP-254-B-X 27.5
B14HDP-253-B-X 110.2
■ 10% Duty Cycle 55W
■ 25% Duty Cycle 22W
■ 50% Duty Cycle 11W
■ 100% Duty Cycle 5.5W
6.0
(26.7)
4.0
(17.8)
2.0
(8.9)
1326 2097
Coil Data
Part Number
Force - lbs (N)
h
d
Ledex® Box Frame Size B14HDP
321 3.0 4.3 6.1 9.7
750 6.0 8.7 12.4 19.6
1068 9.0 12.5 17.6 27.9
1470 12.0 17.4 24.6 38.9
2920 24.0 34.8 49.2 77.8
NOTES:
1. All data is typical.
2. Force testing is done with the solenoid in the
horizontal position.
3. All data reflects operation with no heat sink.
4. Pull versions standard; push versions available.
5. Magnetic latching version available.
(2.54)
0.3
(7.62)
Stroke - in (mm)
0.4
(10.16)
0.5
(12.7)
How to Order
Select the part number from the table provided. (For
example, to order a 25% duty cycle unit rated at 6.1 VDC
with 10" lead wires, specify B14HDP-258-B-4.
Please see www.ledex.com for our list of stock products
available through our North American distributors.
All specifications subject to change without notice.
Ledex® Solenoids
0.2
(5.08)
Force values for reference only.
www.ledex.com
1.937.454.2345
Fax: 1.937.898.8624
Inches (mm)
Dimensions
Illustrated in energized/de-energized state
Lead Wire Models
0.28
(7.0)
0.81
(20.7)
0.787 ±0.008
(20.00 ±0.20)
0.670 (17.02)
both sides
0.19
(4.9)
0.315 ± 0.008 0.787 ± 0.008
(8.0 ± 0.20) (20.00 ± 0.20)
0.354 ± 0.003 dia.
(Ø10.0 ± 0.08)
6-32 Thd Typ (4)
(2 Holes This Side;
2 Holes Opposite Side)
M4 - 0.7 Thd Typ (4)
(2 Holes This Side;
Non-Energized Position
1.46 ± 0.14
(37.0 ± 3.6)
0.34
(8.7)
10.0
(254)
Min. Length
to Frame
0.67
(16.9)
Ø0.118
(3.0)
1.024 ± 0.006
(26.00 ± 0.15)
Energized Position
Terminal Connection Models
0.81 (20.7)
Terminal Centers
0.28
(7.0)
0.81
(20.7)
0.787 ±0.008
(20.00 ±0.20)
0.670 (17.02)
both sides
0.19
(4.9)
0.020 ± 0.003 (0.51 ± 0.08)
Terminal Thickness
0.354 ± 0.003 dia.
(Ø10.0 ± 0.08)
6-32 Thd Typ (4)
(2 Holes This Side;
(2 Holes This Side;
0.34
(8.7)
0.373 (9.48)
Ref. to
Bobin Flange
0.24 (6.0)
Max. Engagement
1.46 ± 0.14
(37.0 ± 3.6)
Ø0.118
(3.0)
1.024 ± 0.006
(26.00 ± 0.15)
0.55 ± 0.20
(13.9 ± 5.1)
0.67
(16.9)
Energized Position
Ledex® Solenoids
0.110 ± 0.005
(2.79 ± 13)
www.ledex.com
Terminal Mates
with DIN 46247
1.937.454.2345
Fax: 1.937.898.8624
很抱歉,暂时无法提供与“B14HDP-254-B-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+736.603821+95.57374
