Ledex® Magnetic Latching Box Frame Size B17-L
LINEAR Open Frame
Part Number: B17 - L - X XX - B- 3
VDC
Battery
Powered
DC
attery
ered
High
Speed
All products are RoHS Compliant
Coil Selection
(from performance chart below)
Pole Configuration
1 Flat Face
Specifications
Operation Pull
Dielectric Strength
500 VRMS for one second
Unlatch Voltage
See schematic and coil data below
Magnet Hold Force*
10 oz. (2.5 N)
Coil Insulation
Class “ B”: 130°C max,
Coil Termination
10" (254 mm) PVC lead wires
Spring Force
16.0 oz/in; 2.4 oz latched position
Plunger Pole Face
Flat face (other options available)
High
Long
Magnetic
Miniature
Quiet
Plunger
Weight
oz.
(2.46 g)
Speed
Life
Latching
Size0.08
Performance
Total Weight
0.70 oz. (19.85 g)*In no power, latched
position.
* In no power, latched position, with return spring
Long
Life
Magnetic
Latching
Typical Force @ 20°C (Net, with Spring)
25.0
(7.0)
15.0
(4.2)
Quiet
Miniature
Performance
Size
10.0
(2.8)
Magnetic
Latching
etic
ng
Unlatch
Maximum
Duty Cycle Voltage 50%
Quiet
Miniature
Size
Performance
25%
10%
Recommended Max ON Time (sec)
1
1
1
1
Watts (@ 20°C)
1.6
3.2
6.4
16
Ampere Turns (@ 20°C)
292
414
584
923
Force - oz (N)
Performance
■ 10% Duty Cycle 16W
■ 25% Duty Cycle 6.4W
■ 50% Duty Cycle 3.2W
20.0
(5.6)
5.0
(1.4)
Miniature
Quiet
Size
Performance
Coil Data
Part Number
Resistance Ref #
Unlatch
VDC VDC VDC
(@20°C) Turns VDC (Nom) (Nom) (Nom)
B17-L-158-B-3 5.40 556 3 4 6 9
B17-L-155-B-3 21.93 1112 6 8.5 12 19
B17-L-156-B-3 50.20 1540 9 12 18 28.3
B17-L-154-B-3 88.95 2208 12 17 24 38
B17-L-153-B-3 337.00 3687 24 34 48 76
B17-L-152-B-3 1465.00 9177 48 68 96 153
NOTES:
1. All data is typical.
2. Force testing is done with the solenoid in the
horizontal position.
3. All data reflects operation with no heatsink.
0.02 0.04 0.06 0.08 0.10 0.12 0.14 0.16 0.18
(0.51) (1.02) (1.52) (2.03) (2.54) (3.05) (3.56) (4.06) (4.57)
Stroke - in (mm)
Coil Polarity
Latch:
A+ B-
A
(Red)
Unlatch: A- B+
B
(Black)
How to Order
Select the part number from the table provided. (For
example, to order a 25% duty cycle unit rated at 48 VDC,
specify B17-L-153-B-3.
Please see www.ledex.com for our list of stock products
available through our North American distributors.
All specifications subject to change without notice.
Ledex® Solenoids
Force values for reference only.
www.ledex.com
1.937.454.2345
Fax: 1.937.898.8624
Inches (mm)
Dimensions
All solenoids are illustrated in energized state
0.062
(1.57)
0.079
(2.01)
0.190 ± 0.003
(4.83 ± 0.076)
Dia.
0.188 ± 0.010
(4.78 ± 0.254)
0.470 ± 0.025
(11.94 ± 0.635)
0.315 ± 0.008
(8.00 ± 0.203)
0.512 ± 0.015
(13.0 ± 0.381)
0.152 ± 0.007
(3.86 ± 0.178)
0.029 +
(0.74 +
Plunger Detail
0.276 ± 0.008
(7.01 ± 0.203)
0.003
0.000
0.076
0.000)
Ø0.062 +
(1.58 +
0.003
0.000
0.076
0.000)
See Plunger
Detail
#4-40 UNC Thds
(3 Holes)
0.787 ± 0.015
(19.99 ± 0.381)
E-Ring
#26 AWG PVC
Lead Wires
0.594 ± 0.015
(15.09 ± 0.381)
Black
Red
Spring
1.120 ± 0.030
(28.45 ± 0.762)
10.0 Min.
(254)
Ledex® Solenoids
www.ledex.com
1.937.454.2345
Fax: 1.937.898.8624
很抱歉,暂时无法提供与“B17-L-155-B-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+448.253351+57.53866
- 10+399.2164710+51.24419
- 25+381.1917725+48.93051
- 50+368.0917950+47.24897
- 100+355.43431100+45.62423
