B17-L-153-B-3
B17-L-153-B-3
    JOHNSON
    连续 占空比螺线管 开放框架(拉) 型 0.180"(4.57mm) 行程 24VDC 底座安装
B17-L-153-B-3 数据手册
Ledex® Magnetic Latching Box Frame Size B17-L LINEAR Open Frame Part Number: B17 - L - X XX - B- 3 VDC Battery Powered DC attery ered High Speed All products are RoHS Compliant Coil Selection (from performance chart below) Pole Configuration 1 Flat Face Specifications Operation Pull Dielectric Strength 500 VRMS for one second Unlatch Voltage See schematic and coil data below Magnet Hold Force* 10 oz. (2.5 N) Coil Insulation Class “ B”: 130°C max, Coil Termination 10" (254 mm) PVC lead wires Spring Force 16.0 oz/in; 2.4 oz latched position Plunger Pole Face Flat face (other options available) + – High Long Magnetic Miniature Quiet Plunger Weight oz. (2.46 g) Speed Life Latching Size0.08 Performance Total Weight 0.70 oz. (19.85 g)*In no power, latched position. * In no power, latched position, with return spring + Long Life – Magnetic Latching Typical Force @ 20°C (Net, with Spring) 25.0 (7.0) 15.0 (4.2) Quiet Miniature Performance Size 10.0 (2.8) – Magnetic Latching – etic ng Unlatch Maximum Duty Cycle Voltage 50% Quiet Miniature Size Performance 25% 10% Recommended Max ON Time (sec) 1 1 1 1 Watts (@ 20°C) 1.6 3.2 6.4 16 Ampere Turns (@ 20°C) 292 414 584 923 Force - oz (N) Performance + ■ 10% Duty Cycle 16W ■ 25% Duty Cycle 6.4W ■ 50% Duty Cycle 3.2W 20.0 (5.6) 5.0 (1.4) Miniature Quiet Size Performance Coil Data Part Number Resistance Ref # Unlatch VDC VDC VDC (@20°C) Turns VDC (Nom) (Nom) (Nom) B17-L-158-B-3 5.40 556 3 4 6 9 B17-L-155-B-3 21.93 1112 6 8.5 12 19 B17-L-156-B-3 50.20 1540 9 12 18 28.3 B17-L-154-B-3 88.95 2208 12 17 24 38 B17-L-153-B-3 337.00 3687 24 34 48 76 B17-L-152-B-3 1465.00 9177 48 68 96 153 NOTES: 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heatsink. 0 0 0.02 0.04 0.06 0.08 0.10 0.12 0.14 0.16 0.18 (0.51) (1.02) (1.52) (2.03) (2.54) (3.05) (3.56) (4.06) (4.57) Stroke - in (mm) Coil Polarity Latch: A+ B- A (Red) Unlatch: A- B+ B (Black) How to Order Select the part number from the table provided. (For example, to order a 25% duty cycle unit rated at 48 VDC, specify B17-L-153-B-3. Please see www.ledex.com for our list of stock products available through our North American distributors. All specifications subject to change without notice. Ledex® Solenoids Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Ledex® Magnetic Latching Box Frame Size B17-L Inches (mm) Dimensions All solenoids are illustrated in energized state 0.062 (1.57) 0.079 (2.01) 0.190 ± 0.003 (4.83 ± 0.076) Dia. 0.188 ± 0.010 (4.78 ± 0.254) 0.470 ± 0.025 (11.94 ± 0.635) 0.315 ± 0.008 (8.00 ± 0.203) 0.512 ± 0.015 (13.0 ± 0.381) 0.152 ± 0.007 (3.86 ± 0.178) 0.029 + (0.74 + - Plunger Detail 0.276 ± 0.008 (7.01 ± 0.203) 0.003 0.000 0.076 0.000) Ø0.062 + (1.58 + - 0.003 0.000 0.076 0.000) See Plunger Detail #4-40 UNC Thds (3 Holes) 0.787 ± 0.015 (19.99 ± 0.381) E-Ring #26 AWG PVC Lead Wires 0.594 ± 0.015 (15.09 ± 0.381) Black Red Spring 1.120 ± 0.030 (28.45 ± 0.762) 10.0 Min. (254) All specifications subject to change without notice. Ledex® Solenoids www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624
B17-L-153-B-3 价格&库存
很抱歉,暂时无法提供与“B17-L-153-B-3”相匹配的价格&库存,您可以联系我们找货
