B17-254-A-1
B17-254-A-1
    JOHNSON
    占空比螺线管 开放框架(拉) 型 0.100"(2.54mm) 行程 底座安装
B17-254-A-1 数据手册
Ledex® Box Frame Size B17 VDC Battery Powered All products are RoHS Compliant Select from performance chart below Typical Force @ 20°C Specifications Operation Pull Dielectric Strength 500 VRMS for one second Continuous Duty Cycle 100% at 20°C ambient temperature Intermittent Duty Cycle See below Holding Force 14.04 oz. (3.9 N) at 20°C Coil Insulation Class “ B”: 130°C max. Coil Termination 10" (254 mm) PVC lead wires Plunger Weight 0.1 oz. (2.84 g) + – High Long Magnetic Miniature Quiet Total Weight oz. (18.4 g) Speed Life Latching Size0.65 Performance 30.0 (8.3) 20.0 (5.6) DC attery ered High Speed Long Life + – Magnetic Latching Performance Quiet Miniature Performance Size Maximum Duty Cycle – etic ng 100% 50% 25% 10% Maximum ON Time (sec) when pulsed continuously ∞ 15 6 2 Maximum ON Time (sec) for single pulse ∞ 112 36 10.5 Watts (@ 20°C) 1.6 3.2 6.4 16 Ampere Turns (@ 20°C) 292 414 584 923 Miniature Quiet Size Performance Coil Data Part Number Resistance Ref # VDC VDC VDC VDC (@20°C) Turns (Nom) (Nom) (Nom) (Nom) B17-258-A-1 B17-255-A-1 B17-256-A-1 B17-254-A-1 B17-253-A-1 B17-252-A-1 5.40 556 3 4 6 9 21.93 1112 6 8.5 12 19 50.2 1540 9 12 18 28.3 88.95 2208 12 17 24 38 337 3687 24 34 48 76 1465 9177 48 68 96 153 NOTES: 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heatsink. 4. Pull versions standard; push versions available. 5. Magnetic latching version available.. ■ 10% Duty Cycle 16W ■ 25% Duty Cycle 6.4W ■ 50% Duty Cycle 3.2W ■ 100% Duty Cycle 1.6W 25.0 (6.9) Force - oz (N) LINEAR Open Frame Part Number: B17 - XXX - A- 1 15.0 (4.2) 10.0 (2.8) 5.0 (1.4) 0 0 0.02 0.04 0.06 0.08 0.10 0.12 0.14 0.16 0.18 (0.51) (1.02) (1.52) (2.03) (2.54) (3.05) (3.56) (4.06) (4.57) Stroke - in (mm) How to Order Select the part number from the table provided. (For example, to order a 25% duty cycle unit rated at 48 VDC, specify B17-253-A-1. Please see www.ledex.com for our list of stock products available through our North American distributors. All specifications subject to change without notice. Ledex® Solenoids Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Ledex® Box Frame Size B17 Inches (mm) Dimensions All solenoids are illustrated in energized state (3) #4-40 UNC threads Plunger Detail 0.062 (1.57) 0.190 ± 0.003 (4.83 ± 0.076) 0.188 ± 0.010 (4.78 ± 0.254) 0.079 (2.01) 0.312 ± 0.025 (7.92 ± 0.635) 0.315 ± 0.008 (8.0 ± 0.203) 0.512 ± 0.015 (13.0 ± 0.381) 0.276 ± 0.008 (7.01 ± 0.203) 0.062 ± 0.003 (1.57 ± 0.076) Dia. 0.594 ± 0.015 (15.08 ± 0.381) #26 AWG PVC Lead Wires 0.787 ± 0.015 (19.99 ± 0.381) Ledex® Solenoids 0.945 ± 0.030 (24.0 ± 0.762) www.ledex.com 10.0 (254) Min. 1.937.454.2345 Fax: 1.937.898.8624
B17-254-A-1 价格&库存
很抱歉,暂时无法提供与“B17-254-A-1”相匹配的价格&库存,您可以联系我们找货
