B22-253-M-36
B22-253-M-36
    JOHNSON
    连续 占空比螺线管 开放框架(拉) 型 0.500"(12.70mm) 行程 24VDC 底座安装
B22-253-M-36 数据手册
Ledex® Box Frame Size B22 All products are RoHS Compliant Select from performance chart below Specifications Typical Force @ 20°C Operation Pull Dielectric Strength 1500 VRMS for one second Continuous Duty Cycle 100% at 20°C ambient temperature Intermittent Duty Cycle See below Holding Force 8 lbs (35.6 N) at 20°C Coil Insulation Class “A”: 105°C max. Coil Termination 3/16" QC Plunger Weight 1.4 oz. (39.7 g) Total Weight 7.5 oz. (212.6 g) 16.0 (71.2) 14.0 (62.3) 10.0 (44.5) Performance Maximum Duty Cycle 100% 50% 25% 10% Maximum ON Time (sec) when pulsed continuously ∞ 52 23 9 Maximum ON Time (sec) for single pulse ∞ 485 167 47 Watts (@ 20°C) 9.9 Ampere Turns (@ 20°C) 19.8 39.6 99 1046 1482 2093 3314 Coil Data Part Number ■ 10% Duty Cycle 99W ■ 25% Duty Cycle 39.6W ■ 50% Duty Cycle 19.8W ■ 100% Duty Cycle 9.9W 12.0 (53.4) Force - lbs (N) LINEAR Open Frame Part Number: B22 - XXX - M- 36 8.0 (35.6) 6.0 (26.7) 4.0 (17.8) 2.0 (8.9) 0 0 0.2 (5.1) Resistance Ref # VDC VDC VDC VDC (@20°C) Turns (Nom) (Nom) (Nom) (Nom) 0.4 (10.2) 0.6 (15.2) Stroke - in (mm) 0.8 (20.3) 1.0 (25.4) B22-255-M-36 3.64 635 6 8.5 12 19 B22-254-M-36 14.55 1300 12 17 24 38 B22-253-M-36 58.18 2578 24 34 48 76 B22-252-M-36 232.73 5103 48 68 96 152 B22-251-M-36 1493 12744 120 172 240 385 How to Order NOTES: Please see www.ledex.com for our list of stock products available through our North American distributors. 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heatsink. 4. Pull versions standard; push versions available. 5. Other coil terminations available. 6. Magnetic latching version available. Select the part number from the table provided. (For example, to order a 25% duty cycle unit rated at 48 VDC, specify B22-253-M-36. All specifications subject to change without notice. Ledex® Solenoids Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Ledex® Box Frame Size B22 Inches (mm) Dimensions All solenoids are illustrated in energized state 1.312 ± 0.015 (33.32 ± 0.381) 1.000 (25.4) 0.500 (12.7) 1.468 ± 0.015 (37.29 ± 0.381) 0.59 (14.99) Ref. 0.42 (10.7) Approx. 0.187 (4.75) QC Terminals #10-32 UNF (2 Holes) 1.609 ± 0.015 (40.87 ± 0.381) 0.845 ± 0.030 (21.46 ± 0.762) 0.097 / 0.094 (2.46 / 2.39) Dia. (2 holes) Ledex® Solenoids 0.140 ± 0.015 (3.56 ± 0.381) 0.375 ± 0.015 (9.53 ± 0.381) 0.500 Dia. (12.7) www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624
B22-253-M-36 价格&库存
很抱歉,暂时无法提供与“B22-253-M-36”相匹配的价格&库存,您可以联系我们找货
B22-253-M-36
  • 1+275.826301+35.82844
  • 10+245.7160910+31.91728
  • 25+234.6303525+30.47730
  • 50+226.5721750+29.43058
  • 100+218.78508100+28.41908
  • 300+206.97854300+26.88547
  • 500+201.70595500+26.20058
库存:303
