C5-272-B-1
C5-272-B-1
    JOHNSON
    间断 占空比螺线管 开放框架(拉) 型 0.125"(3.18mm) 行程 12VDC 底座安装
C5-272-B-1 数据手册
VDC Battery Powered Part Number: C5 - XXX - B- 1 All products are RoHS Compliant Select from performance chart below Force (Gross, Without Spring) Specifications Operation Pull Dieletectric Strength 500 VRMS for one second Continuous Duty Cycle 100% At 20°C ambient temperature Intermittent Duty Cycle See below Coil Insulation Class “B”: 130°C max. Coil Termination 0.025" square pin terminals Plunger Pole Face 60° conical Plunger Weight 0.08 oz. (2.2 g) + – High Long Magnetic Miniature Quiet Total Weight oz. (11.9 g) Speed Life Latching Size0.42 Performance 1.4 (6.23) 1.0 (4.45) DC attery ered High Speed Long Life + – Magnetic Latching Performance – etic ng 0.8 (3.56) Quiet Miniature Performance Size Maximum Duty Cycle 100% 50% 25% 10% Maximum ON Time (sec) ∞ 145 47 14 Watts (@ 20°C) 3 6 12 30 Ampere Turns (@ 20°C) 422 564 844 1268 Miniature Quiet Size Performance ■ 10% Duty Cycle 30W ■ 25% Duty Cycle 12W ■ 50% Duty Cycle 6W ■ 100% Duty Cycle 3W 1.2 (5.34) Force - lbs (N) LINEAR Open Frame Ledex® C Frame Size C5 0.6 (2.67) 0.4 (1.78) Coil Data Part Number Resistance Ref # VDC VDC VDC VDC (@20°C) Turns (Nom) (Nom) (Nom) (Nom) C5-273-B-1 C5-272-B-1 C5-271-B-1 C5-270-B-1 C5-269-B-1 C5-268-B-1 C5-267-B-1 2.88 406 3 4 6 9 11.52 795 6 8 12 19 25.77 1222 9 12 18 28 48.65 1642 12 17 24 38 72.84 1968 15 21 30 47 152.20 2860 21 30 43 68 191.73 3202 24 34 48 76 NOTES: 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heatsink. 4. Other coil terminations available. 5. Pull versions standard; push versions available. 6. Magnetic latching version available. 0.2 (0.89) 0 0 0.02 0.04 0.06 0.08 0.10 0.12 0.14 0.16 0.18 0.20 (0.51) (1.02) (1.52) (2.03) (2.54) (3.05) (3.56) (4.06) (4.57) (5.08) Stroke - in (mm) How to Order Select the part number from the table provided. (For example, to order a 25% duty cycle unit rated at 48 VDC, specify C5-267-B-1. Please see www.ledex.com for our list of stock products available through our North American distributors. All specifications subject to change without notice. Ledex® Solenoids Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Ledex® C Frame Size C5 Inches (mm) Dimensions All solenoids are illustrated in energized state Terminals 0.025 (0.64) Square terminals 1.24 (31.5) 0.8 (20.3) 0.42 (10.6) 0.41 (10.4) M2 X 0.4 Thru (2) Holes "A" Ledex® Solenoids 0.14 (3.6) 0.312 (7.93) Ref. 0.035 (0.9) 0.2 (5.0) 0.46 (11.7) 0.23 (5.8) 0.94 (23.8) 0.28 (7.1) 0.362 (9.2) 0.04 (1.0) 0.5 (12.7) 0.22 (5.6) B A A B Ø0.16 (4.0) 0.07 (1.8) Ø0.063 +0.003 (1.6 +0.08) 1-72 UNF Thru (2) Holes "B" www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624
C5-272-B-1 价格&库存
很抱歉,暂时无法提供与“C5-272-B-1”相匹配的价格&库存,您可以联系我们找货
C5-272-B-1
  • 1+222.330981+28.73230
  • 10+198.0594810+25.59565
  • 25+189.1245325+24.44096
  • 50+182.6301050+23.60168
  • 100+176.35620100+22.79089
  • 250+168.38479250+21.76072
  • 500+162.59106500+21.01199
