C8-272-M-36
C8-272-M-36
    JOHNSON
    占空比螺线管 开放框架(拉) 型 行程 底座安装
C8-272-M-36 数据手册
Ledex® C Frame Size C8 VDC Battery Powered All products are RoHS Compliant Select from performance chart below Typical Force @ 20°C Specifications Operation Pull Dieletectric Strength 500 VRMS for one second Continuous Duty Cycle 100% at 20°C ambient temperature Intermittent Duty Cycle See below Holding Force 2.24 lbs (9.96 N) at 20°C Coil Insulation Class “A”: 105°C max. Coil Termination 3/16" QC Plunger Weight 0.4 oz. (11.3 g) + – High Long Magnetic Miniature Total Weight oz.Quiet (45.4 g) Speed Life Latching Size1.6 Performance 3.5 (15.6) 2.5 (11.1) DC attery ered High Speed Long Life + – Magnetic Latching Performance Quiet Miniature Performance Size Maximum Duty Cycle 100% 50% 25% ■ 10% Duty Cycle 35W ■ 25% Duty Cycle 14W ■ 50% Duty Cycle 7W ■ 100% Duty Cycle 3.6W 3.0 (13.3) 10% Maximum ON Time (sec) when pulsed continuously ∞ 19 9 3 Maximum ON Time (sec) for single pulse ∞ 286 92 27 Watts (@ 20°C) 3.6 7 14 35 Ampere Turns (@ 20°C) 464 657 929 1470 Force - lbs (N) LINEAR Open Frame Part Number: C8 - XXX - M- 36 2.0 (8.9) 1.5 (6.7) 1.0 (4.4) 0.5 (2.2) Coil Data Part Number Resistance Ref # VDC VDC VDC VDC (@20°C) Turns (Nom) (Nom) (Nom) (Nom) C8-276-M-36 C8-273-M-36 C8-274-M-36 C8-272-M-36 C8-271-M-36 C8-270-M-36 C8-269-M-36 2.56 404 3 4.2 5.9 9.3 9.30 752 6 8.5 12 19 23.2 1252 9 12.7 18 28.5 37.12 1484 12 17 24 38 150.73 2736 24 34 48 76 621.54 5544 48 68 96 152 3824 15035 120 164 231 366 NOTES: 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heatsink. 4. Magnetic latching versions available. 5. Pull versions standard; push versions available. 6. Other coil terminations available. 0 0.1 (2.5) 0.3 (7.6) Stroke - in (mm) 0.4 (10.2) 0.5 (12.7) How to Order Select the part number from the table provided. (For example, to order a 25% duty cycle unit rated at 48 VDC, specify C8-271-M-36. Please see www.ledex.com for our list of stock products available through our North American distributors. All specifications subject to change without notice. Ledex® Solenoids 0.2 (5.1) Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Ledex® C Frame Size C8 Inches (mm) Dimensions All solenoids are illustrated in energized state 0.486 (12.34) 0.187 (4.75) Q.C. Terminals 0.234 (5.94) 0.140 (3.56) Min. 1.020 (25.91) Ref. 0.662 (16.81) 0.437 ± 0.015 (11.1 ± 0.381) 0.125 (3.18) 1.125 ± 0.015 (28.58 ± 0.381) 0.75 (19.05) 6-32UNC (2) Places 0.812 ± 0.015 (20.62 ± 0.381) 0.750 ± 0.031 (19.05 ± 0.787) 0.25 (6.35) 0.438 (11.13) 0.187 ± 0.015 (4.75 ± 0.381) Ledex® Solenoids 0.500 (12.4) 0.073 (1.85) 0.067 (1.70) Dia. (2) Holes www.ledex.com 0.109 (2.77) 1.937.454.2345 Fax: 1.937.898.8624
C8-272-M-36 价格&库存
很抱歉,暂时无法提供与“C8-272-M-36”相匹配的价格&库存,您可以联系我们找货
C8-272-M-36
  • 1+328.553911+42.45971
