Ledex® C Frame Size C8
VDC
Battery
Powered
All products are RoHS Compliant
Select from performance chart below
Typical Force @ 20°C
Specifications
Operation Pull
Dieletectric Strength
500 VRMS for one second
Continuous Duty Cycle 100% at 20°C ambient temperature
Intermittent Duty Cycle See below
Holding Force
2.24 lbs (9.96 N) at 20°C
Coil Insulation
Class “A”: 105°C max.
Coil Termination
3/16" QC
Plunger Weight
0.4 oz. (11.3 g)
High
Long
Magnetic
Miniature
Total
Weight
oz.Quiet
(45.4 g)
Speed
Life
Latching
Size1.6 Performance
3.5
(15.6)
2.5
(11.1)
DC
attery
ered
High
Speed
Long
Life
Magnetic
Latching
Performance
Quiet
Miniature
Performance
Size
Maximum Duty Cycle
100%
50%
25%
■ 10% Duty Cycle 35W
■ 25% Duty Cycle 14W
■ 50% Duty Cycle 7W
■ 100% Duty Cycle 3.6W
3.0
(13.3)
10%
Maximum ON Time (sec)
when pulsed continuously
∞ 19 9 3
for single pulse
∞ 286 92 27
Watts (@ 20°C)
3.6
7
14
35
Ampere Turns (@ 20°C)
464
657
929
1470
Force - lbs (N)
LINEAR Open Frame
Part Number: C8 - XXX - M- 36
2.0
(8.9)
1.5
(6.7)
1.0
(4.4)
0.5
(2.2)
Coil Data
Part Number
Resistance Ref # VDC VDC VDC VDC
(@20°C) Turns (Nom) (Nom) (Nom) (Nom)
C8-276-M-36
C8-273-M-36
C8-274-M-36
C8-272-M-36
C8-271-M-36
C8-270-M-36
C8-269-M-36
2.56 404 3 4.2 5.9 9.3
9.30 752 6 8.5 12 19
23.2 1252 9 12.7 18 28.5
37.12 1484 12 17 24 38
150.73 2736 24 34 48 76
621.54 5544 48 68 96 152
3824 15035 120 164 231 366
NOTES:
1. All data is typical.
2. Force testing is done with the solenoid in the
horizontal position.
3. All data reflects operation with no heatsink.
4. Magnetic latching versions available.
5. Pull versions standard; push versions available.
6. Other coil terminations available.
(2.5)
0.3
(7.6)
Stroke - in (mm)
0.4
(10.2)
0.5
(12.7)
How to Order
Select the part number from the table provided. (For
example, to order a 25% duty cycle unit rated at 48 VDC,
specify C8-271-M-36.
Please see www.ledex.com for our list of stock products
available through our North American distributors.
All specifications subject to change without notice.
Ledex® Solenoids
0.2
(5.1)
Force values for reference only.
www.ledex.com
1.937.454.2345
Fax: 1.937.898.8624
Inches (mm)
Dimensions
All solenoids are illustrated in energized state
0.486
(12.34)
0.187
(4.75)
Q.C. Terminals
0.234
(5.94)
0.140
(3.56)
Min.
1.020
(25.91)
Ref.
0.662
(16.81)
0.437 ± 0.015
(11.1 ± 0.381)
0.125
(3.18)
1.125 ± 0.015
(28.58 ± 0.381)
0.75
(19.05)
6-32UNC
(2) Places
0.812 ± 0.015
(20.62 ± 0.381)
0.750 ± 0.031
(19.05 ± 0.787)
0.25
(6.35)
0.438
(11.13)
0.187 ± 0.015
(4.75 ± 0.381)
Ledex® Solenoids
0.500
(12.4)
0.073 (1.85)
0.067 (1.70)
Dia. (2) Holes
www.ledex.com
0.109
(2.77)
1.937.454.2345
Fax: 1.937.898.8624
很抱歉,暂时无法提供与“C8-271-M-36”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+335.651881+43.09373
