1887215
1887215
    HENKEL(汉高)
    SOJ4
    24 MHz ±50ppm 晶体 18pF 4-SOJ,3.30mm 间距
1887215 数据手册
Crystal unit Product Number (please contact us) MA-406 : Q22MA4062xxxx00 MA-505 : Q22MA5052xxxx00 MA-506 : Q22MA5062xxxx00 MHz RANGE CRYSTAL UNIT MA - 406 MA - 505 / MA - 506 Frequency range Thickness Overtone order : : : : Applications : 4 MHz to 64 MHz 11.7 × 4.8 × 3.7 mm ···MA-406 13.46 × 5.08 × 4.6 mm ···MA-505 / 506 Fundamental 3rd overtone (30 MHz to 64 MHz) For Clock of integrated circuit Actual size MA-406 MA-505 / 506 Specifications (characteristics) Item Symbol Nominal frequency range f_nom Specifications Conditions / Remarks 4.000 MHz to 29.999 MHz Fundamental *1 30.000 MHz to 64.000 MHz 3rd overtone *2 Storage temperature T_stg -55 C to +125 C Storage as single product. Operating temperature T_use -20 C to +70 C Please contact us on availability of -40 C to +85 C Level of drive DL 10 W to 100 W Frequency tolerance (standard) f_tol 50  10-6 +25 C Under 5.5 MHz :50  10-6 -20 C to +70 C Frequency versus temperature characteristics f_tem (standard) Over 5.5 MHz :30  10-6 Please contact us for requirements not listed in this specifications. Fundamental: 10 pF to  Load capacitance CL Overtone: 5 pF to  Please specify Motional resistance (ESR) R1 As per table below -20 C to +70 C, DL=100 W Shunt capacitance C0 5 pF Max. Frequency aging f_age 5  10-6 / year Max. +25 C,First year *1 4.0 MHz  f_nom < 5.5 MHz : See “Available frequencies from 4.0 MHz to less than 5.5 MHz”. 8.0 MHz < f_nom < 8.2 MHz: Unavailable. *2 26.000 MHz  f_nom
1887215
物料型号: - MA-406 - MA-505 / MA-506
器件简介: - 频率范围:4 MHz 至 64 MHz - 尺寸:MA-406为11.7 × 4.8 × 3.7 mm,MA-505 / 506为13.46 × 5.08 × 4.6 mm - 基频和3次泛音(30 MHz至64 MHz)适用于集成电路的时钟
引脚分配: - 内部连接图显示了MA-406、MA-505和MA-506的引脚分配,注意不要将MA-506的#2和#3引脚连接到外部设备。
参数特性: - 存储温度:-55°C至+125°C - 工作温度:-20°C至+70°C(对于-40°C至+85°C的范围,请咨询) - 驱动电平:10 W至100 W - 频率容差(标准):+50x10^-6至+25°C - 频率与温度特性(标准):5.5MHz以下50x10^-6,5.5MHz以上30x10^-6 - 负载电容:基频10pF至,泛音5pF至 - 动态电阻(ESR):详见表格 - 并联电容:最大5pF - 频率老化:最大+5x10^-6/年
功能详解: - 详细列出了不同频率下的动态电阻(ESR)和频率容差。
应用信息: - 适用于汽车多媒体、车身电子、遥控门禁等汽车应用,以及与驾驶安全相关的应用(如发动机控制单元、安全气囊、ESC等)。
封装信息: - 提供了推荐的足迹尺寸。
1887215 价格&库存
很抱歉,暂时无法提供与“1887215”相匹配的价格&库存,您可以联系我们找货
