PROG-JACK-USB
PROG-JACK-USB
    ERP
    PROGRAM CABLE PSB30/PSB40/PSB50
PROG-JACK-USB 数据手册
PSB50 PSB40 PSB30 50 W 40 W 30 W at ion PSB50/40/30 Series 50, 40 & 30 W Programmable Constant Current LED Driver with Tri-Mode Dimming™ (TRIAC, ELV & 0-10 V) Nominal Input Voltage Max. Output Power 120 to 277 Vac, 220 to 240 Vac 50 W Efficiency Max. Case Temperature THD Power Factor Dimming Method Dimming Range Startup Time < 20% > 0.9 Forward-Phase, Reverse-Phase & 0 - 10V 1 - 100% (% of Iout) 300 ms typical up to 90% 90°C (measured (from 100% to 50% (from 100% to 50% typical at the hot spot) TRIAC/ELV Dimmer + Dim - Dim 0-10 V Dimmer PSB50 + LEDs Series - LEDs FEATURES In fo rm of max rated power of max rated power) Aluminum Case L 98.5 * W 26.2 * H 21.85 mm (L 3.88 * W 1.03 * H 0.86 in.) m ina ry •  Non-linear 0-10V dimming profile with dim-to-off pre-loaded by default (10V to 9.1V=100%, 1.5V to 0.55V=1%, 0.9 Power Factor (PF) 63 53 0.5 A @ 120 Vac 0.28 A @ 230 Vac 0.23 A @ 277 Vac 0.3 mA @ 120 Vac 0.6 mA @ 230 Vac Measured per IEC60950-1 0.7 mA @ 277 Vac mA Leakage Current At nominal input voltage and with nominal LED voltage From 100% to 50% of rated power At any point on the sine wave and 25°C Active limiting inrush current is available as an option. Please contact your ERP representative or send an email to SaveEnergy@erp-power.com. Meets NEMA-410 requirements A Inrush Current Input Harmonics Complies with IEC61000-3-2 for Class C equipment Total Harmonics Distortion (THD) 20% up to 90% - - ina ry % Efficiency Notes The rated output current for each model is achieved at Vin≥108 Vac & at Vin≥198 Vac for models with flying leads, and at Vin≥209 Vac for models with "-T" suffix. At nominal load In fo rm Typical Units Minimum Input Voltage Range (Vin) - Models with flying leads - Models with "-T" suffix At nominal input voltage and nominal LED voltage From 100% to 50% of rated power Complies with DLC (Design Light Consortium) technical requirements Measured with nominal input voltage, a full sinusoidal wave form and without dimmer attached. The AC input to the main DC output is isolated and meets Class II reinforced/double insulation power supply Isolation 3 - MAIN OUTPUT SPECIFICATION (@25°C ambient temperature) Output Voltage (Vout) Units Minimum Typical Maximum Vdc See ordering information for details See ordering information for details The rated output current for each model is achieved at Vin≥108 Vac & at Vin≥198 Vac. Output Current (Iout) mA Output Current Regulation % -5 ±2.5 5 % - - 10 ≤ 10% of rated output current for each model eli Ripple Current m Output Current Overshoot % Start-up Time ms Pr Dimming Range (% of Iout) Isolation Notes 1 100 300 500 At nominal AC line voltage Includes load and current set point variations The driver does not operate outside of the regulation requirements for more than 500 ms during power on with nominal LED load and without dimmer. Measured at nominal LED voltage and nominal input voltage without dimming Calculated in accordance with the IES Lighting Handbook, 9th edition The dimming range is dependent on each specific dimmer. It may not be able to achieve 1% dimming with some dimmers. Dimming performance is optimal when the driver is operated at its nominal output voltage matching the LED nominal Vf (forward voltage). Dimming performance may vary when the driver is operated near its minimum output voltage. Without any dimmer attached, and at nominal input voltages and nominal load Measured from application of AC line voltage to 100% light output Complies with ENERGY STAR® luminaire specification and CA Title 24 The main DC output is certified and tested per UL8750 Class 2 or LED Class 2 SaveEnergy@erp-power.com 3 www.erp-power.com PSB50 PSB40 PSB30 50 W 40 W 30 W at ion PSB50/40/30 Series 50, 40 & 30 W Programmable Constant Current LED Driver with Tri-Mode Dimming™ (TRIAC, ELV & 0-10 V) 4 - 0-10 V DIMMING CONTROL (@25°C ambient temperature) In fo rm In the PSB50/40/30 series, several 0-10V dimming profiles can be selected, such as a logarithmic profile, a non-linear profile with 1% minimum dimming and dim-to-off, and a non-linear profile with 10% minimum dimming and no dim-to-off. Furthermore, every point in the non-linear dimming profile can be programmed using the programming software. By default, the non-linear profile with 1% minimum dimming and dim-to-off (show in figure 1) is pre-loaded in the PSB50/40/30 series. Units Minimum Typical Maximum Notes +Dim Signal, -Dim Signal The PSB50/40/30 series operate only with 0-10V dimmers that sink current. The method to dim the output current of the driver is done via the +Dim/-Dim Signal pins. The +Dim/-Dim signal pins can be used to adjust the output setting via a standard commercial wall dimmer, an external control voltage source (0 to 10 Vdc), or a variable resistor when using the recommended number of LEDs. The dimming input permits 1% to 100% dimming. Dimming Profile (see figure 1) 100% of output current between 10 V and 9.1 V, Linear between 9.1 V and 1.5 V, 1% of output current between 1.5 V and 0.55 V, Output current off below 0.55 V. Isolation % V V V V 1 100 9.1 1.5 0.55 As a percent of the output current ina ry Dimming Range High Level Voltage - A Low Level Voltage - B Dim to Off - C Dim to Off Hysteresis - D Current Supplied by the +Dim Signal Pin Output Current Tolerance While Being Dimmed 0.5 +0.1 0.6 +0.2 mA 1 % ±8 The tolerance of the output current while being dimmed is ≤ +/-8% until down to 1.5V. The 0-10 V circuit is isolated from the AC input and meets Class II reinforced/double insulation power supply. Pr eli m Percent of Output Current
 (Normalized to Rated Current) 100% SaveEnergy@erp-power.com 1% 0% (V) C D B A 10 Dimming Voltage (V) Figure 1 4 www.erp-power.com PSB50 PSB40 PSB30 50 W 40 W 30 W at ion PSB50/40/30 Series 50, 40 & 30 W Programmable Constant Current LED Driver with Tri-Mode Dimming™ (TRIAC, ELV & 0-10 V) 5 - ENVIRONMENTAL CONDITIONS °C Maximum Case Temperature (Tc) °C Storage Temperature Humidity Cooling Acoustic Noise Mechanical Shock Protection Vibration Protection MTBF Lifetime °C % Minimum Typical Maximum -20 50 Notes 50°C is the non-derated temperature (Refer to section 8 "Output power de-rating at higher temperatures". In fo rm Units Operating Ambient Temperature (Ta) +90 -40 5 Convection cooled +85 95 Case temperature measured at the hot spot tc (see label in page 11) Non-condensing dBA 24 Measured at a distance of 1 meter, without dimmer per EN60068-2-27 per EN60068-2-6 & EN60068-2-64 > 200,000 hours when operated at nominal input and output conditions, and at Tc ≤ 75°C 50,000 hours at Tc ≤ 75°C maximum case hot spot temperature (see hot spot tc on label in page 11) 6 - EMC COMPLIANCE AND SAFETY APPROVALS m ina ry EMC Compliance Models with no suffix and with "-X" suffix: Compliant with FCC CFR Title 47 Part 15 Class B at 120 Vac & Class A at 277 Vac Conducted and Models with "-T" suffix: Compliant with EN55015 (CISPR 15) at 220, 230, and 240 Vac Radiated EMI IEC61000-3-2 For Class C equipment Harmonic Current Emissions IEC61000-3-3 Voltage Fluctuations & Flicker ESD (Electrostatic IEC61000-4-2 6 kV contact discharge, 8 kV air discharge, level 3 Discharge) RF Electromagnetic Field IEC61000-4-3 3 V/m, 80 - 1000 MHz, 80% modulated at a distance of 3 meters Susceptibility IEC61000-4-4 ± 2 kV on AC power port for 1 minute, ±1 kV on signal/control lines Electrical Fast Transient ± 2 kV line to line (differential mode) /± 2 kV line to common mode ground Immunity (tested to secondary ground) on AC power port, ±0.5 kV for outdoor cables IEC61000-4-5 Compliance Higher surge is available. Please contact your ERP representative or send an Surge email to SaveEnergy@erp-power.com. ANSI/IEEE c62.41.1-2002 & c62.41.2-2002 category A, 2.5 kV ring wave Conducted RF IEC61000-4-6 3V, 0.15-80 MHz, 80% modulated Disturbances IEC61000-4-11 >95% dip, 0.5 period; 30% dip, 25 periods; 95% reduction, 250 periods Voltage Dips cUL CAN/CSA C22.2 No. 250.13-14 LED equipment for lighting applications IEC61347-2-13 electronic control gear for LED Modules & EN55015 (EMC compliance) Pr CE CB ENEC Safety Agency Approvals UL8750 listed Class 2 (except PSB50W-0550-85) eli cUL Hi Pot (High Potential) or Dielectric voltage-withstand SaveEnergy@erp-power.com Units Minimum Vdc 2500 Safety Typical 5 Maximum Notes  Insulation between the input (AC line and Neutral) and the output  Tested at the RMS voltage equivalent of 1767 Vac www.erp-power.com PSB50 PSB40 PSB30 50 W 40 W 30 W at ion PSB50/40/30 Series 50, 40 & 30 W Programmable Constant Current LED Driver with Tri-Mode Dimming™ (TRIAC, ELV & 0-10 V) 7 - PROTECTION FEATURES ina ry In fo rm Input Over Current Protection The PSB series incorporates a primary AC line fuse for input over current protection to prevent damage to the LED driver and meet product safety requirements as outlined in Section 6.  Short Circuit and Over Current Protection The PSB50/40/30 series is protected against short-circuit such that a short from any output to return shall not result in a fire hazard or shock hazard. The driver shall hiccup as a result of a short circuit or over current fault. Removal of the fault will return the driver to within normal operation. The driver shall recover, with no damage, from a short across the output for an indefinite period of time. Internal Over temperature Protection The PSB50/40/30 series is equipped with internal temperature sensor on the primary power train. Failure to stay within the convection power rating will result in the power supply reducing the available current (fold back) below the programmed amount. The main output current will be restored to the programmed value when the temperature of the built-in temperature sensor cools adequately. Output Open Load Protection When the LED load is removed, the output voltage of the PSB50/40/30 series is typically limited to 1.3 times the maximum output voltage of each model. 8 - OUTPUT POWER DE-RATING AT ELEVATED TEMPERATURES The PSB50/40/30 series can be operated with cooling air temperatures above 50°C by linearly de‑rating the total maximum output power (or current) by 2.5%/°C from 50°C to 70°C (see figure 2). 110% 100% 80% m Percent of Output Power 90% 70% 60% eli 50% 40% 30% Pr 20% 10% 0% 0 SaveEnergy@erp-power.com 10 20 30 40 50 60 Ambient Temperature (°C) 70 80 Figure 2 6 www.erp-power.com PSB50 PSB40 PSB30 50 W 40 W 30 W at ion PSB50/40/30 Series 50, 40 & 30 W Programmable Constant Current LED Driver with Tri-Mode Dimming™ (TRIAC, ELV & 0-10 V) 9 - PHASE-CUT DIMMING ina ry AC Wall Power Percent of Output Current
 (Normalized to Rated Current In fo rm Dimming of the driver is possible with standard TRIAC-based incandescent dimmers that chop the AC voltage as shown in Figure 3, or with ELV dimmers. During the rapid rise time of the AC voltage when the dimmer turns on, the driver does not generate any voltage or current oscillations, and inrush current is controlled. During the ontime of the AC input, the driver regulates the output current based upon the conduction angle. The RMS value of the driver output current is proportional to the on-time of the AC input voltage. When operating with an incandescent dimmer, the RMS output current varies depending upon the conduction angle and RMS value of the applied AC input voltage. Figure 4 shows the typical output current versus conduction angle at nominal input voltage. Forward-phase (TRIAC) and reverse-phase (ELV) dimming work only at 120 Vac. The PSB50/40/30 series offers Tri-Mode Dimming™ compatibility with both phase-cut (reverse-phase and forward-phase) and 0–10V dimmers. Phase-cut dimming always has priority over 0-10 V dimming. Output Current versus Conduction Angle Chopped AC Input to Driver         Figure 3     Conduction Angle  Figure 4                                                             Pr      eli   m 10 - COMPATIBLE PHASE-CUT DIMMERS & DIMMING RANGE                                    Dimming compatibility charts are available for each model in the PSB50/40/30 series. Please contact your sales representative or send an email to: SaveEnergy@erp-power.com. SaveEnergy@erp-power.com 7 www.erp-power.com PSB50 PSB40 PSB30 50 W 40 W 30 W at ion PSB50/40/30 Series 50, 40 & 30 W Programmable Constant Current LED Driver with Tri-Mode Dimming™ (TRIAC, ELV & 0-10 V) 11 - 0-10 V DIMMING Typical Value A 9.1 V m Dimming Voltage 1.5 V 0.55 V D 0.7 V eli B C 1% 0% C D Pr Percent of Output Current
 (Normalized to Rated Current) 100% ina ry In fo rm The PSB50/40/30 series operate only with 0-10V dimmers that sink current. They are not designed to operate with 0-10V control systems that source current, as used in theatrical/entertainment systems. Developed in the 1980’s, the 0-10V sinking current control method is adopted by the International Electrotechnical Commission (IEC) as part of its IEC Standard 60929 Annex E. The method to dim the output current of the driver is done via the +Dim/-Dim Signal pins. The +Dim/-Dim Signal pins respond to a 0 to 10 V signal, delivering 1% to 100% of the output current based on rated current for each model. A pull-up resistor is included internal to the driver. When the +Dim wire (purple) is short circuited to the –Dim wire (grey) or to the –LED wire (blue), the output current turns off. If the +Dim input is > 10 V or open circuited, the output current is programmed to 100% of the rated current. When not used, the –Dim wire (grey) and to the +Dim wire (purple) can be individually capped or cut off. In this configuration, no dimming is possible and the driver delivers 100% of its rated output current. The maximum source current (flowing from the driver to the 0-10V dimmer) supplied by the +Dim Signal pin is ≤ 1 mA. The tolerance of the output current while being dimmed shall be +/-8% typical until down to 1.5 V. In the PSB50/40/30 series, several 0-10V dimming profiles can be selected, such as a logarithmic profile, a non-linear profile with 1% minimum dimming and dim-to-off, and a non-linear profile with 10% minimum dimming and no dimto-off. Furthermore, every point in the non-linear dimming profile can be programmed using the programming software. By default, the non-linear profile with 1% minimum dimming and dim-to-off (show in figure 5) is pre-loaded in the PSB50/40/30 series. In this non-linear 0-10V dimming profile, 10V to 9.1V=100% of the output current, 1.5V to 0.55V=1%,
PROG-JACK-USB 价格&库存
很抱歉,暂时无法提供与“PROG-JACK-USB”相匹配的价格&库存,您可以联系我们找货
PROG-JACK-USB
    库存:10
    PROG-JACK-USB
      PROG-JACK-USB
      • 1+152.761051+19.75413
      库存:8
      PROG-JACK-USB
      库存:10
      PROG-JACK-USB
