4401-464-000-21
4401-464-000-21
    EXCELITASTECHNOLOGIES(埃赛力达)
    F-THETA-RONAR; TELECENTRIC; ENTR
4401-464-000-21 数据手册
LINOS F-Theta-Ronar Lens f = 100mm, 1064nm, telecentric Part number 4401-464-000-21 Design wavelength λ (nm) 1064 Effective focal length EFL (mm) 100.1 Back focal length BFL (mm) 128.9 Working distance WD (mm) 126.0 Flange focal length FFL (mm) 195.2 Øbeam (mm) 14.0 Recommended mirror distance m1 m1 (mm) 17.0 Recommended mirror distance m2 m2 (mm) 28.5 Recommended mirror distance m2mechanical m2m (mm) 18.9 Scan angle ±θx,y (°) 17.0 Scan area (edge length of scan field) 2x * 2y (mm²) 57 x 57 Spot diameter Øspot (µm) 14 Telecentric error (maximum deviation) DT (°) 0.1 Total transmission @ 1064nm LIDT coating @ 1064nm, 9ns, 100Hz Focused back reflex positions from first surface T (%) (J/cm²) > 96 10 (mm) 2.3; 6.2; 6.5; 21.6; 66.7 (g) 1850 Beam diameter 1/e² truncated Weight Protective glass PG 4401-288-005-01 Optical parameters calculated for a 1-mirror system Subject to technical change Qioptiq Photonics GmbH & Co. KG Königsallee 23 D - 37081 Göttingen All rights reserved O-LM_DS-4401-464-000-21_2020.11-V3 Not export controlled Page 1 of 2 Tel: +49 (0) 551 6935-0 lmp@excelitas.com www.qioptiq-shop.com Mechanical drawing Spot variation over scanfield Spot radius in µm at 1/e² level for a Gaussian laser beam (M²=1) field size and mirror distances as given above for a 2 mirror scan system,vignetting ≤ 1% 14mm diameter at 1/e² truncated Notes For technical explanations, see our homepage. In a 1-mirror system, the entrance pupil (EP) is the position of the scan mirror. In a 2-mirror system, it is the point where the scan mirrors should be placed around symmetrically to reach specified performance. Entrance lens made of fused silica. Qioptiq Photonics GmbH & Co. KG Königsallee 23 D - 37081 Göttingen All rights reserved O-LM_DS-4401-464-000-21_2020.11-V3 Not export controlled Page 2 of 2 Tel: +49 (0) 551 6935-0 lmp@excelitas.com www.qioptiq-shop.com
4401-464-000-21 价格&库存
很抱歉,暂时无法提供与“4401-464-000-21”相匹配的价格&库存,您可以联系我们找货
