LINOS F-Theta-Ronar Lens
f = 420mm, 940-980nm
Part number
4401-525-000-21
Design wavelength
λ
(nm)
980
Effective focal length
EFL
(mm)
418.5
Back focal length
BFL
(mm)
494.6
Working distance
WD
(mm)
491.7
Flange focal length
FFL
(mm)
546.3
Øbeam
(mm)
m1
(mm)
25.6
37.0
Recommended mirror distance m2
m2
(mm)
27.5
30.0
Recommended mirror distance m2mechanical
m2m
(mm)
19.8
22.3
Scan angle
±θx,y
±17.3
±12.2
Scan area
2x * 2y
(mm²)
253 x 253
178 x 178
Spot diameter
Øspot
(µm)
37
26
Telecentric error (maximum deviation)
DT
15.5
10.8
Total transmission @ 940 - 980nm
Focused back reflex positions from first
surface
T
97
(mm)
1.9; 42.0; 61.1; 138.5; 139.7
Beam diameter 1/e² truncated
Recommended mirror distance m1
Weight
Protective glass
(g)
PG
1500
4401-524-004-00
Optical parameters calculated for a 1-mirror system
Subject to technical change
Qioptiq Photonics GmbH & Co. KG
Königsallee 23
D - 37081 Göttingen
All rights reserved
O-LM_DS-4401-525-000-21_2021.12-V1
Not export controlled
Page 1 of 2
Tel: +49 (0) 551 6935-0
lmp@excelitas.com
www.qioptiq-shop.com
Mechanical drawing
Dimensions without tolerances are nominal values and illustration not to scale
Spot variation over scanfield
Spot radius in µm at 1/e² level for a Gaussian laser beam (M²=1)
field size and mirror distances as given above for a 2 mirror scan system
20mm diameter at 1/e² truncated
30mm diameter at 1/e² truncated
Notes:
For technical explanations, see our homepage.
In a 1-mirror system, the entrance pupil (EP) is the position of the scan mirror. In a 2-mirror system, it is
the point where the scan mirrors should be placed around symmetrically to reach specified performance.
Königsallee 23
D - 37081 Göttingen
All rights reserved
Page 2 of 2
lmp@excelitas.com
很抱歉,暂时无法提供与“4401-525-000-21”相匹配的价格&库存,您可以联系我们找货
