4401-599-000-26
4401-599-000-26
    EXCELITASTECHNOLOGIES(埃赛力达)
    F-THETA-RONAR; TELECENTRIC; FUSE
4401-599-000-26 数据手册
LINOS F-Theta-Ronar Lens f = 75mm, 515-540nm, telecentric, fused silica, low absorption Part number 4401-599-000-26 Design wavelength λ (nm) 532 Effective focal length EFL (mm) 75.0 Back focal length BFL (mm) 94.1 Working distance WD (mm) 85.8 Flange focal length FFL (mm) 147.3 Beam diameter 1/e² truncated Øbeam (mm) 10.0 14.0 15.0 Recommended mirror distance m1 m1 (mm) 13.0 17.0 18.4 Recommended mirror distance m2 m2 (mm) 23.5 23.5 23.5 Recommended mirror distance m2mechanical m2m (mm) 19.4 19.4 19.4 Scan angle ±θx,y (°) 10.6 9.5 8.6 Scan area (edge length of scan field) 2x * 2y (mm²) 27 x 27 24 x 24 22 x 22 Spot diameter Øspot (µm) 7 5 4 DT (°) 1.3 1.4 1.3 Telecentric error (maximum deviation) Total transmission @ 515 - 540nm T (%) > 96 GDD (fs²) 3257 LIDT coating @ 532nm, 8ns, 100Hz (J/cm² ) 20 LIDT coating @ 515nm, 204fs, 50kHz Focused back reflex positions from first surface (J/cm² ) 0.6 (mm) 2.53 ; 2.72; 31.42 (g) 923 Group delay dispersion at λ Weight Protective glass PG 4401-599-006-00 Optical parameters calculated for a 1-mirror system Subject to technical change Qioptiq Photonics GmbH & Co. KG Königsallee 23 D - 37081 Göttingen All rights reserved O-LM_DS-4401-599-000-26_2020.09-V4 Not export controlled Page 1 of 2 Tel: +49 (0) 551 6935-0 lmp@excelitas.com www.qioptiq-shop.com Mechanical drawing Dimensions without tolerances are nominal values and drawing not to scale Spot variation over scanfield Spot radius in µm at 1/e² level for a Gaussian laser beam (M²=1) field size and mirror distances as given above for a 2 mirror scan system 10mm diameter at 1/e² truncated 15mm diameter at 1/e² truncated Notes For technical explanations, see our homepage. In a 1-mirror system, the entrance pupil (EP) is the position of the scan mirror. In a 2-mirror system, it is the point where the scan mirrors should be placed around symmetrically to reach specified performance. Qioptiq Photonics GmbH & Co. KG Königsallee 23 D - 37081 Göttingen All rights reserved O-LM_DS-4401-599-000-26_2020.09-V4 Not export controlled Page 2 of 2 Tel: +49 (0) 551 6935-0 lmp@excelitas.com www.qioptiq-shop.com
4401-599-000-26
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光隔离型放大器,具有高输入阻抗和低输出阻抗,适用于长线驱动和匹配负载。
3. 引脚分配:EL817有8个引脚,1脚为输出,2脚为参考地,3脚为输入,4脚为输出,5脚为参考地,6脚为输出,7脚为参考地,8脚为Vcc。
4. 参数特性:工作温度范围为-40℃至+85℃,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817内部包含光敏三极管和晶体管,实现电-光-电转换,隔离电压可达2.5kV。
6. 应用信息:适用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:采用DIP-8封装。
4401-599-000-26 价格&库存
很抱歉,暂时无法提供与“4401-599-000-26”相匹配的价格&库存,您可以联系我们找货
  • 1+43450.296641+5613.43955
