Datasheet
Photon Detection
C30617L-100 and C30618L-350 – InGaAs PIN Photodiodes
High Speed InGaAs PIN on Ceramic Surface Mount Substrate
Excelitas’ C30617L-100 and C30618L-350 PIN Diodes are high speed, InGaAs diodes that provide high responsivity for
high speed applications.
Key Features
• High Bandwidth, up to 3.5 GHz
• High responsivity at 1300 nm and 1550 nm
• Active Area diameter of 100 µm and 350 µm
• Low capacitance
• Compact, robust ceramic SMT package
• Customizations (e.g. filters) possible
• RoHS compliant
Applications
• High volume consumer applications
• LiDAR
• Telecommunication
• Instrumentation
• High speed switches
• Optical time reference for laser range finders
All specifications are referring to an ambient temperature of TA = 22 °C, λ = 1550 nm and typical VOP.
Table 1: Key parameters
Parameter
Operating Voltage
Spectral Range
Peak Responsivity
Responsivity
Symbol
VOP
peak
R1300
R1550
Min
1
960
0.80
0.95
Typ
5
1550
0.90
1.05
Max
10
1700
Unit
V
nm
nm
A/W
www.excelitas.com
C30617L-100_C30618L-350 revision 2021-01a Page 1 of 7
Table 2: Ordering Information
Parameter
Active Area Shape
Useful Area
Useful Diameter
C30617L-100
Circular
7850
100
C30618L-350
Circular
96200
350
Units
µm2
µm
Table 3: Absolute Maximum Ratings
Parameter
Average Forward Current
Total Power dissipation
Storage Temperature
Operating Temperature
Symbol
IF
Ptot
TS
TOp
Value
10
100
-60 … 125
-40 … 125
Units
mA
mW
°C
°C
Soldering Temperature3
TP
250
°C
Note 1: Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device.
Note 2: Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Note 3: For detailed reflow information, refer to Table 8.
Table 4: Optical Specifications C30617L-100
Parameter
Rise Time / Fall Time
Bandwidth
Symbol
tr / tf
f3dB
Minimum
Typical
0.07
3.50
Maximum
0.50
Units
ns
GHz
Minimum
Typical
0.50
0.75
Maximum
1.00
Units
ns
GHz
Table 5: Optical Specifications C30618L-350
Parameter
Bandwidth
www.excelitas.com
Symbol
tr / tf
f3dB
Page 2 of 7
Table 6: Electrical Specification C30617L-100
Parameter
Breakdown Voltage
Capacitance
Dark Current
Dark Noise1
Noise Equivalent Power2
Symbol
VBD
C
iD
iN
NEP
Minimum
25
Typical
60
0.6
很抱歉,暂时无法提供与“C30617L-100”相匹配的价格&库存,您可以联系我们找货
